OFFICAL RC18R THREAD
#101
RE: OFFICAL RC18R THREAD
Im not to much into the idea of spending $150 for a charger and power supply nor am I fond to buying cheesey looking power supplies. I do like the charger mousesi2k posted but i do want to spend 50 bucks for a power supply. Im aiming for $100 bucks or less on the charger and power supply combined. And I want to be able to charge lipo and nimh batteries on the charger at about 1A.
#102
wth you mean cheesy power adapter ...those are great adadpter for the price ... plus you get a 1 year warranty ...
i found my power adapter in is pile of junk in my garage haha
charges 3lipo FINE but 8 celled nimh doesnt work that well lol
#106
CA
Well, got my parts today w00t! Order was sent Tuesday morning and i resived it today! Anyways, everything installed super easy, DP Draglink, TheToyz shock set, and a 3Racing CF battery strap to finish the cf chassis i already have from 3Racing.
Here are some pics that i took with my cell phone lol.
The Kamino's Mods (was origonally an RC18T)
3Racing CF Chassis with Motor Heat Sink and Cooling Fan
3Racing CF Battery Strap
DP Draglink (black)
TheToyz Aluminum Adjustable Shocks
AE Titanium Turnbuckles
AE Factory Team ESC Heat Sink
Losi Xcelorin 9400KV Motor and ESC
The Lancer's Mods
Dp Draglink
Losi ESC Heat Sink
DP Draglink (black)
The Lancer's Mods
Dp Draglink
Losi ESC Heat Sink
#109
CA
Radioshack used to have the perfect on for like $25 bux. Thing is that they recalled it and now there cheapest one is like $55 i think. I searched online for the one that i use but cant seem to find it x_x. I bought it at Frys Electronics and it is made by Samlex. I believe its cost ruffly $30 bux.
This is the power supply that my cousin uses (which is radioshacks cheapest priced one) with the same Multiplex charger i have.
http://www.radioshack.com/product/in...entPage=search
#110
CA
you chould go with the power supply i got (works great) and then get a charger that can charge both NiMH and Lipo...thing is i dont know of anything like that under 50 dollars..
#111
CA
i gotta problem now with my rc18r..
my dogbone keeps poping out of the part where the dogbone connects to the tire pops ot when i turn. i have the springs in the diff but i just suddenly started to happen. so if you could help me out on this i would really appericate it
thanks,
brian
thanks,
brian
#112
CA
Have you taken the dogbone all the way out? Its possible the little stubs have worn out on the dogbone itself. If that looks compairable to the others then check out the axles and see if maybe the area where the dogbones go hasnt worn out. And i know you said you have the springs in, just check and make sure you didnt lose one or that its for some reason didnt flatten out or something.
#113
CA
well there all fine and i checked jsut the spring was all the way in and like the spring was leterally inside of the diff so i havent run it because its dark out so ill try again tomorrow morning
#116
CA
Its super easy to install. I installed 2 in about 10 mins max. Thetoyz has two links on how to install. One is a Quicktime clip. The other is a PDF(requires adobe reader) of the installation manual. They are located in the middle of the page under the small picture of the Draglink.
http://www.thetoyz.com/cart/thetoyz_...at_name=RC18R#
EDIT: took my images out so not to go over bandwidth limit x_x
#119
CA
I've read pretty much everywhere that the MIP dif is an awsome upgrade. Me myself, i still have the stock diffs though if one was to go out, then i would probley upgrade them all. Thats just me.
#121
CA
yz..i have about 70 bucks and i have to spend 25 on a lipo cut off..and like 15 or connectors for my lipos and stuff so that 40 bucks outta stuff..so ill have enough get a 1 diff from them
#122
I have MIP diffs on my mini T but never mind on my last post i really pushed and got it threw but I shed a little blood in the process.
#124
It finally budged, My question is: Why does it seem alot harder to turn everything now? Is this the effect I should have or should it be the same as before?
