Reload this Page >
Show your overpowered plane...
Old 06-30-2004, 04:51 PM
Shortman
My Feedback: (21)
Shortman's Avatar
Default RE: Show your overpowered plane...
Now thats overpowered, thats up there with a 27lb powered ZDZ 160 champion which is 1lb lighter then a DA 150 and more power, some 75+lbs of thrust haha.
Old 07-01-2004, 04:50 AM
RustyTumbles
RustyTumbles's Avatar
Thats Unreal I love it!!!!!!!!!!!!!!!!!
Old 07-01-2004, 06:43 AM
Henke Torphammar
Henke Torphammar's Avatar
Aggressor with a Hacker C50 (3kW AUW 12lb, 25lb+ thrust)
http://henke.rchomepage.com/aggressor/aggressor2.htm
also fun is my sp400 plane with 500watts...
[link=http://www.vaxjorc.com/Files/Memberfolders/henriktorphammar1197/vip500.wmv]VIP 500watts video[/link]
Old 07-01-2004, 06:58 AM
Spacey
Spacey's Avatar
Now that is kewl!
Old 07-01-2004, 08:16 AM
JBrannon
JBrannon's Avatar
My most over powered plane was a .60 size H9 stick with a Saito 150 on it.
Joe
Old 07-01-2004, 10:32 AM
  #31
Welsh3D
not belonging to me, but GP pitts with ZDZ 80RV.... 16lb weight, ~48lb thrust!
Old 07-01-2004, 11:36 PM
  #32
KI6HNB
KI6HNB's Avatar
I had an Eaglet 50 with a Magnum .40 on it. Untill the tail feathers blew apart.
Old 07-02-2004, 01:15 AM
  #33
DKjens
My Feedback: (50)
DKjens's Avatar
I built from plans a Sledge some time ago, but with a balsa covered foam wing and fuse. I first had a GMS47 on it but it was ultra pig tail heavy, so I put a GMS76 on it, what the heck. It stayed together, but everything it did was a blur he he. I also had a UCD60, first with a YS120NC, cool, then with a YS120SC, very cool and just the right amount of power if you ask me.
DKjens
Old 07-02-2004, 02:18 AM
  #34
DMehalko
My Feedback: (42)
DMehalko's Avatar
None of this nonsense compares to my Sig Kadet LT-40.
O.S 1.60FX in the nose and it wieghs about 7 pounds WET.
David
Old 07-02-2004, 03:35 AM
  #35
Henke Torphammar
it´s hard to overpower without over weighting too.... for 3D a smaller engine often work as well as a large as it is lighter...
Old 07-02-2004, 09:52 AM
  #36
Ryan Nau
My Feedback: (54)
Ryan Nau's Avatar
Dave Patrick Models Extra 330L with a DA 50 and 24x8 prop. Goes straight up rolling really fast and hovers right above idle. And not heavy either with the motor for its size.
Old 07-02-2004, 10:46 AM
  #37
TD1
Midwest Cap 80" with a ZDZ 60,
Sig Wonder with a OS 32 SX (takes a .15),
Thunder Tiger Stick 40 with a OS 91 FX, Hover just above idle,
Old 07-02-2004, 08:19 PM
  #38
RevGQ
RevGQ's Avatar
Sorry that I have no picture, waiting for my digital camera to come. I fly a GP Cap 232 with a GMS .76 bolted on the nose. The plane weighs 6.3 lbs. and rips through the sky. Didn't have to cut the cowl, except at bottom for cooling and pitts muffler, and needle valve opening at top.
Old 07-02-2004, 08:33 PM
  #39
kennyandannie
All of these planes look awesome.
I have been accused of overpowering my birds in the past.
How about my Midwest Super Stearman with an OS BGX-1 3500!!!
I have pics, but I haven't figured out how to import them to this forum
Kenny
Old 07-02-2004, 09:55 PM
  #40
1fish
1fish's Avatar
ORIGINAL: Ryan Nau
Dave Patrick Models Extra 330L with a DA 50 and 24x8 prop. Goes straight rolling really fast and hovers right above idle. And not heavy either with the motor for its size.
Yep thats what I have also I just got it this week and only flown it a couple of times, the motor is still new but has MORE than enough power goes up 'till I tell it to stop, it will hover at about 1/4to 1/3 throttle at 15 lbs it is quite over powered with the 5 horse D/A
The two on the bottom is my H9 cap with a bisson 52cc 3.2 also tons of power @18 lbs wet and 26 lbs of thrust...
ID:	149722   Click image for larger version
ID:	149723   Click image for larger version
ID:	149724   Click image for larger version
Old 07-02-2004, 10:11 PM
  #41
3littlefonzies
3littlefonzies's Avatar
thats a beautifull engine
Old 07-03-2004, 11:20 PM
  #42
Swat Cop
Swat Cop's Avatar
I have an Ohio RC Extra 300 (88"W/S, 20 pounds) with a ZDZ 80. The plane accelerates nicely going vertical, most other flying is at 1/4 throttle.
I also have a Dave Patrick Edge 540 with a ZDZ 50 which is definatlely a vertical rocket at 15 pounds but not quite as over powered as the Ohio RC Extra.
ID:	150037   Click image for larger version
ID:	150038   Click image for larger version
ID:	150039   Click image for larger version
Old 07-04-2004, 05:27 AM
  #43
joel_jones
My Feedback: (111)
joel_jones's Avatar
got a edge540 profile and put a os91. now that is power.
Old 07-04-2004, 07:04 PM
  #44
phinox7
My Feedback: (15)
I have a modeltech .60 p-51 mustang it is the same size as the Top flight 1/7 scale mustang. I used the Top flight canopy becals it is more scale OK back to the point. it has a YS 140 sport on it. I had to move the firewall back and use the Top flight coul. It will out run all the ducted fans I have pulled up to and racing the hanger9's with the saito 100 is to much fun.
Old 07-05-2004, 08:09 PM
  #45
Cybertom
Cybertom's Avatar
How about this, a 28lb Flair Stearman with a 10HP Robart raidal...
Old 10-19-2004, 01:18 PM
  #46
$n4IL
World Models CAP 232 with GMS .76 (under construction), should hover no problem.
I hate adding lead to my planes. So many ARFs are tail heavy without modifications, I have just given up and take the upper limit of the recommended 4 stroke displacement and put a 2 stroke of that displacement in all my planes. They tend to balance perfectly with this formula. You don't HAVE TO use full throttle, but it's nice to know you have it when you need it.
Old 10-19-2004, 02:39 PM
  #47
DMehalko
My Feedback: (42)
DMehalko's Avatar
Ithink i win, jk, there are some seriously overpowered birds here
Old 10-19-2004, 04:13 PM
  #48
IowaSilvia
My Feedback: (97)
I have a chvy 350. in a Funtana 90. [:-]
Old 10-19-2004, 05:56 PM
  #49
STEVE LENZ
My Feedback: (45)
STEVE LENZ's Avatar
I just used my U-CAN"T -DO to break in my new Saito 150 H (Hemi-Head) soon to go on? X-mas will tell.
Old 10-19-2004, 06:04 PM
  #50
crash_expert
crash_expert's Avatar
Taco .25 with an OS .91 four stroke. A little squirley on the ground past 3 clicks and a hand full to fly. Landings are all dead sticks. To scared to try a power on landing. Flew it twice to win my bet and then stuck a .52 fout stroke on it.
