Reload this Page >
Great Planes PT- 17 Stearman ARF
Old 01-31-2013, 07:10 AM
  #551
RipG
RipG's Avatar
Default RE: Great Planes PT- 17 Stearman ARF
Did not use them so just talking here...  Considering the kit uses CA hinges, I would think that 1/8" hinges would be sufficiently strong.  There is plenty of thickness in the joint to use, the 3/32", however.
Old 02-20-2013, 12:35 PM
  #552
Linkan2
more video PT17 Stearman
http://www.youtube.com/watch?v=38SLpmwj-ug
Lars
Old 06-02-2013, 01:16 PM
  #553
cmgtech1
Recently purchased one of these from a flying buddy. What a sweetheart to fly!!!
Old 06-02-2013, 01:57 PM
  #554
RipG
RipG's Avatar
ORIGINAL: cmgtech1
It's also a sweetheart to build. I didn't realize what a great first airplane this was until I built my second!
Old 06-14-2013, 09:25 PM
  #555
cmgtech1
A few pics of my PT-17 in flight.
ID:	1891749   Click image for larger version
ID:	1891750   Click image for larger version
ID:	1891751   Click image for larger version
ID:	1891752   Click image for larger version
ID:	1891753   Click image for larger version
Old 06-14-2013, 10:06 PM
  #556
j301
My Feedback: (12)
j301's Avatar
Hey, you put one of the pictures upside down! Reminds me, I need to get mine out to the field soon!
Old 07-15-2013, 12:25 AM
  #557
jp928
I have to say that it only took me 10 mins to get all the wing covering wrinkles out, so things seem to have improved...
jp
Old 07-25-2013, 01:24 PM
  #558
Zampa
ORIGINAL: haymanns
ORIGINAL: Chuck54sd
I put a Saito 200 R3 3-cylinder radial engine on mine.... and it is a joy to fly..... but nowhere near as cool as Linkan2's UMS 7-35 radial engine.
That is the definition of AWESOME !!!!
-Chuck
I have that same R3 engine and pt 17 arf,and was wondering about the combo.How did the cg work out?Did you lower the tank?It would be greatly appreciated if you could post a few pics.please!
I was going to ask the same question as I like the pt-17 + Evo 7-35 radial combo very much. I already saw the helpful photos of the engine installation from Linkan2, but would like to know how the CG turned out.
Federico
Old 08-15-2013, 10:20 PM
  #559
jp928
Any body know what the interplane struts are made of please? I hate so many fiddly bits (small screws and nuts) for assembly, so i would like to tap the strut holes (6-32 looks like a good fit), and just use cap screws.
TIA
jp
Old 08-16-2013, 06:25 AM
  #560
I_Fly
Federico
The struts are steel covered with fiberglass and filler (autobody type filler). I'm not sure that I understand your concern but if you are trying to elimiate the nuts and bolts holding the brackets I would not. The steel struts are not thick enough to be tapped and used in place of the nut (in my opinion). Although the bold and nut sizes are not true to scale they do replicate the full scale setup. It's held together the same way.
Carl
Old 08-17-2013, 09:23 PM
  #561
ChrisPetersen
I maidened mine this weekend with a Saito 325 5cyl radial. Awesome! It's feels like the perfect power plant. 6 flights logged. It just putts around at half throttle which gives it that Harley grunt. Very happy with it.
Old 08-18-2013, 03:23 AM
  #562
smkrcflyer
smkrcflyer's Avatar
Chris, I would like to see a picture of the 325 on the plane.
Old 08-19-2013, 07:51 AM
  #563
ChrisPetersen
This is the only pic I have at the moment. I have a video of it ticking away in the pits but the new format I can't figure out how to post it.
Old 08-22-2013, 03:51 AM
  #564
smkrcflyer
smkrcflyer's Avatar
Chris,
Looks good on there I would have through it would look big. How did it balance out? Did you add tail weight?
Old 08-22-2013, 08:27 PM
  #565
ChrisPetersen
I Did have to add some in the very tail above the wheel. 8oz ish,. But not too bad. I located the battery for the onboard glow as far back as I could. The saito 325 is by no means a power house but it gives about perfect power for this plane. Maybe I am just not used to draggy biplanes but even with this bigger engine I still want to get up a head of steam before any maneuvers. The sound makes it worth while! I wish there was some way to put video on here without having to youtube it!
Old 08-23-2013, 01:42 AM
  #566
jp928
Carl,
Thanks for the strut info. The chance of losing a nut on assembly seems pretty high to me, just want to reduce the assembly time and make it easier. I might experiment with jb-welding nuts on the struts. Scale is not really a consideration - I bet the surfaces on the full size are all bolted fittings, nothing like the way we build models, so why would we have to follow only some full size practices?
jp
Old 08-23-2013, 08:20 AM
  #567
j301
My Feedback: (12)
j301's Avatar
Originally Posted by jp928
Carl,
jp
On mine I used thread lock on the nuts and bolts and left them just loose enough to allow the brackets to swivel a bit (not "dangle" loose). When I take off the struts the brackets stay with the strut and I only remove the screw from the wing. Once the struts are off I put the screws back in the wings so I dont lose them. I thought about getting some sticky back magnet material and putting it somewhere in the fuse, but I dont thing its strong enough. There really isn't a way to lessen the amount of set up this bird takes and thats too bad as I would pull it out more often if there was!
Old 08-23-2013, 10:44 AM
  #568
mikejdad
My Feedback: (39)
Purchase an enclosed trailer. Great for hauling your big birds without disassembly( except for regular inspection) and they make great storage containers.
Old 08-23-2013, 11:23 AM
  #569
j301
My Feedback: (12)
j301's Avatar
Would love to, but I would be forced to park it in the sun, and here in AZ, that equates to an EZ-Bake oven on wheels. I've seen people do it, but personally I don't like the idea of storing balsa, gas, batteries, and heat shrink covering in 150+ degree temps. Perhaps one day I will be able to build a 'carport' for it, got to get my kid thru college first! ( not much play money over the last few years!)
Old 08-29-2013, 01:38 PM
  #570
Heli-NuBee
I just ordered a GP Stearman. I plan to power it with my ASP 400 five cylinder radial engine, I know that it will be over powered but one can always throttle back.
Best wishes and good safe flying.
Heli-NuBee (AKA Roger the radial rabbit)
Old 08-29-2013, 04:32 PM
  #571
ChrisPetersen
HeliNuBee I bet you like the combination. The coolest thing is that you will be able to fly around at half throttle, I think radials sound sooooo good at that setting. especially on a classic bipe.
It should handle the weight. I have the boat anchor saito 325 on mine and it handles it really well.
Old 08-29-2013, 06:17 PM
  #572
Heli-NuBee
Hey Chris, I'm sure I will be happy with the Stearman. I had the ASP 400 Radial engine in a CMP 80" Zero but the landing gear supports were to weak. The plane was quite heavy and it flew well but the landing gear mounts broke after each flight. I also have a GP Super Stearman powered by an FPE 40CC gas engine that performs very well. I also had a GP Curtis Hawk (before it decided to self destruct) powered by a PTE 36 gas engine that performed well too. Since I have experience with other GP Bipes, I think the PT-17 will work out well with the ASP 400. I do enjoy my radials, I have the ASP 400, a Saito 200 in a Sea Fury, a Saito 450 in a Gilmore Red Lion, and an UMS Evolution 777 in a BH Corsair, all are a lot of fun.
Old 08-30-2013, 04:06 PM
  #573
mikejdad
My Feedback: (39)
I fly mine with an OS120 FS pumper with a flex pipe. Flys well and scale like and of course it's not overpowered. The OS flex pipe gives it a nice rich tone that isn't offensive at all, from a noise standpoint.
Old 09-09-2013, 01:34 PM
  #574
Heli-NuBee
I started my PT-17 Stearman build yesterday. I can't hardly wait to get that ASP 400 5 cylinder radial engine back in the air. It sounds so good.
Old 09-09-2013, 06:27 PM
  #575
smkrcflyer
smkrcflyer's Avatar
Heli-NuBee,
Make sure you post some pictures of your build.
