Cox Pica 1/5 Scale Waco ARF
#476
RE: Cox Pica 1/5 Scale Waco ARF
ORIGINAL: mobyal
Gonna vent a little bit here. [:@] [:'(]
These d**ned wheel pant attachments are a real PITA. This is something that should have taken about 90 seconds per wheel to attach, but one fell apart in my hands as I was tightening the mounting screws. I have tried everything I know to do to reattach the wheel collar (brass) to the metal plate. JB Weld, epoxy, clean the metal on both surfaces, solder with a torch several times, and I can't get the collar and plate reattached.
ORIGINAL: Tripp2loo
Guys, everyone is right about those wheel pant collors, they will come apart. They are not soldered but glued [:'(]
I am lucky, mine came apart during engine testing on the ground, so no plane damage. I cleaned the surfaces up with the dremel and soldered them, and they seem to be pretty strong now.
Just a warning, if they haven't broke on you yet, THEY WILL.. fix 'em well you can...
Probably worth replacing these wheel pant retainers with some similar sized Dubro giant scale wheel pant hardware of better quailty, though.
#480
Hi every one this is my first post on this forum,I am a bit of a Waco lover I have built a couple of them .In my box of bits I have plans and templates for both the Pica 1/6 and 1/5 versions. Would any of you have experience with the Zenoah 20 cc electronic ign engine as far as installing one in either version .I would love to put it in the 1/5 version but not sure if it would have the power to pull it around O.K.I would be glad to here your thoughts.Roger (Australia)
#481
Roger,
Jump over to the Vintage and Antique, Waco YMF thread (mostly The Pica Wacos, but all Wacos are welcome) and look in the index (page 1) for engines. There are quite a few choices now as guys have tried different engines. Remember, the Pica kit (originally a Dave platt design) is from the 70's and engines have changed. From the guys that fly either the Pica (kit or plans built) or the Cox Pica version, they seem to feel that the Zenoah 20 cc is on the low side of power and the G26 is about perfect.
The V & A Waco thread is pretty large, but there is a ton of info in there. One member has taken the Cox 1/5th Waco, stripped it down, added some scale details, corrected the wing tips and recovered it with Koverall. Its the Red and Cream one in the completed models section and has the G26 in it.
Good luck on your next build
#482
Thanks for the advice much appreciated I thought it may have been a bit lacking in power I may try to fit it into the 1/6 version,it might be a tight squeeze though.
#483
For all those who want one, check on ebay WACO 1/5 COX PICA new in box to sell. Price starting at 500 usd.....
only 4 days to bid !
I have already one for my os 160 ft !
#484
ORIGINAL: Dominic-RCU
#485
ORIGINAL: kruzin55
Beautiful. What engine and did you use? Also, where did you get the dummy engine?
Anyone wishing to become a member of the Waco Brotherhood is welcome. Just post in the WACO YMF thread that John mentioned. We are taking orders for Waco Brotherhood Tee shirts now too.
Bill, AMA 4720
WACO Brotherhood #1
#486
VA
ORIGINAL: khodges
Highway Robbery at that price. It was overpriced at $369, the original price.
#487
No support to be had now, for sure, from Cox.
I thought the original 379.00 price from Cox was about right, or perhaps a little high. My feeling was that it was definitely worth about 100-120 bucks more than the typical H9 warbird ARF, despite the few issues that the Cox kit had.
If the cowl had been right, and the landing gear properly soldered instead of welded and if the upper wing had been correctly built with the flat center section, it would have been well worth the money, I think.
still..Cox gets some credit for increasing the worlds supply of completed and flying radio controlled Waco models!..
I love mine!
I love mine!
#488
UT
Does'nt anyone have any hopeful rumors that this Cox Waco might come back into production on a limited basis ?[] [ or at least, from another ARF mfg. ] MM
#489
VA
I haven't heard a thing.
I got so fed up w/ mine because of the mess w/ the wheel pant attachments that I put it up a year or so ago. haven't even flown it. But have it out, think I've solved the pant attachment problem a real PITA! and am putting the last touches on it now.
Shouls maiden in a week or two...
But then if something, like the gear, breaks? Damifiknow!
#491
ORIGINAL: sj3cub
Why is Cox not going to produce any more Wacos? 1/5, 1/6 ? Cox going out of business? []
I have a feeling that the Pica ARFs were an experiment that did not reward them financially as much as their typical flying toy project and they are likely not going to repeat it....alsthough I do wish they would!
Cox does have some new and innovative stuff coming...but Pica arfs seem to be on pernament hold.
#493
hi everyone iam new at this but i would like to have a 1/5 or 1/6 scale waco thare are some for sale on rcu but no one want to ship can someone help me
i would like to have a pica i live in houston tx i drive a truck so dont have time to put one togther please if someone would like to sale one and will ship it
let me know my name is micheal my email is [email protected] thanks for your time
#494
TX
I recently acquired a brant new Cox/Pica Waco ARF built but no motor mounted from an estate sale. I electrified it with a large Turnigy motor on eight lite polly cells. Prop is 19/12 and ESC is a 70 amp unit from Hobbycity. Absolutely a beautiful flying machine at 14.5 pounds. I had seen Thomases bird fly last year at a meet in Ft Worth and fell in love with her and stumpled onto this one when a friend passed. He had two other big birds hanging from the ceiling that also were never finished. A Top Flite Staggerwing and a 84 inch Gee Bee Y. All were built but I chose only one although the other two were picked up by friends immediately. I happened to have all the hardware already available and it was soon up and flying. I have over 20 flights on her now and every one is a joy. What did I pay for her you may ask? How about $250.00 and tickled pink to do so. She is still in my van after a great afternoon at the field. ed
#496
Ed,
Re-post your post over on the WACO YMF thread in Golden Age, Vintage and Antique RC. Be sure to include which size Waco (1/5 or 1/6) and what motor (part number or size) you used. I am interested (and I am sure others are) in going electric but know virtually nothing about them and would like to know more for the 1/5th Waco I am slowly building. Thanks.
#497
TX
After flying Master Scale for almost 30 years I fly now for myself. Flying wires and all the little nits are great but when having to assemble the bird each time I go to the field I feel they are overated. They add nothing to the flying capabilities and cannot be seen outside 20 feet. If I was back on the circuit you bet I would have them installed but for day to day flying I'll have to pass. I am a believer in the KISS principle and brought up on Murphy's Law. I currently fly three bipes and thats all my van can carry at once.
#498
My Feedback: (18)
Does anyone think that a 40cc gasser would be too much for this 1/5 power wise? I have a Zenoah G26 but not sure how good the vertical would be. I've had this Pica/Cox ARF for 2 years and it's time to build. I flew in one at Marathon Key Fla. I fell in love. I bought the kit. If you have never had a ride in a Waco over the ocean at 400' altitude during a sunset, head for Marathon Key.
[img][/img][img][/img]
#499
Steelie,
Yes, the 40cc will be to much. The 26cc is just about perfect for scale flight and will do loops with out a problem. It won't climb out of sight but nice hammerheads can be done. Fly it scale and you will be fine as there are not enough control surface area to even attempt any 3D BS.
I have had a few rides in Wacos (UPF & S3HD) but not over the keys at sunset. That would be way cool.
#500
My Feedback: (18)
skylarkmk1,
Thanks for that reply. Take a look at the Sweetheart YMF I got a ride in. I was editing by uploading a couple pics in my last post. Hard to believe this airplane was severely damaged from a hurricane. Had to be shipped for restoration/rebuild 4 or 5 years ago. If you google her 'N' numbers you can see what she looked like before the hurricane.
