Batteries & Chargers Nicads, Nickel Metal Hydride, Lithium, LiPoly, Chargers, Cyclers, etc...
How to convert an ATX power supply to rc use
Reply
Old 01-24-2014, 11:57 PM
  #401
Tommygunn792
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fair enough but it seemed like a hell of a wallop for 5 or 12Volts, presumably it's the current that gives it the kick?
Concerning having a load to the PSU, I don't turn it on unless the charger is plugged in or some other item I'm powering.
Tom.
Tommygunn792 is offline
Old 01-25-2014, 07:35 AM
  #402
Zrock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the belt you felt might not be teh 12 or 5v it may be the incoming 112v on that side its hard to say.. Putting a load on the 5v side increases and steady's the voltage on the PS
Zrock is offline
Old 01-28-2014, 12:05 AM
  #403
Tommygunn792
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zrock,
As long as it is all normal then fine. Mind you the click/tick noise is a small concern but at the moment I'm putting that down to components energising.
I got belted with 230V, I'm in Italy!
Tom.
Old 01-28-2014, 06:03 AM
  #404
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Tommygunn792 View Post
Zrock,
Tom.
Tom, I sent you a PM.
karolh is offline
Old 01-28-2014, 08:43 AM
  #405
Zrock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ouch... the clicking your hearing could be some sort of built in voltage converter? Im not to familiar with electricity over their
Zrock is offline
Old 03-13-2014, 07:46 PM
  #406
ProStreetCamaro
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey gentleman what do you think of this psu? 500watts and 40a on the single 12V rail. I am looking for a good solid powerful psu to power a 400watt Turnigy. I want to charge 2 X 2s 500mah and sometimes 2 X 3S 6000mah packs. charger http://hobbyking.com/hobbyking/store...arehouse_.html
psu http://www.microcenter.com/product/4...us_Power_Suply
ProStreetCamaro is offline
Old 01-06-2017, 12:22 AM
  #407
WhuteverMichael
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
howdy Im way new here how exactly do I save this thread to my pf? plz and ty
WhuteverMichael is offline
Old 04-27-2017, 12:40 AM
  #408
crapshooter
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
guys, i just bought a new pcu / atx power supply to convert into a power supply for my lipo charger. my issue is it will only turn on for about 2 secounds before turning off. i have done the proper conversion of using 4 yellow wires / 4 black wires for 12 volts and done the green wire to black wire join i have also installed a 10 ohm - 10 watt sandbar resistor on a black wire to red wire [ 5 volts ] i have tried to get this working but it won,t let me. any tips ? its a 550 watt atx. HELP.
crapshooter is offline
Old 06-13-2017, 03:45 PM
  #409
dmccormick001
dmccormick001's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Most ATX PSUs have a small gauge brown wire that is a "sense" wire, it must be connected to the 3.3 volt (orange) rail. Look at the 24-pin connector that goes to the motherboard, you'll see that it is wired together with one of the orange wires. If you have removed that connector, you may have to solder the brown wire to the spot on the PCB where the orange wires are/were.
Also, some chargers have large capacitors in them that charge up when the charger is turned on, so you have to turn the charger on BEFORE you power up the PSU, or it will trigger the over-current sensors in the PSU and it will shut down.
dmccormick001 is offline
Old 03-27-2018, 11:36 PM
  #410
Seased
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You are always a great help to everyone here! Thank you for this.
Seased is offline
Old 01-22-2019, 02:50 AM
  #411
king bily
I suppose the assumption was that you would read the section on remote sensing carefully -- it does reference sensing on the +5v and +12v rail. I have also seen one supply with a sense wire on ground.
I've converted around 80 or so supplies and run latch and voltage level tests on well over 200. There is a lot of variation across models - some supplies will latch and hold without a preload; some will not. A few will run without reconnecting the sense wires; the majority will not. Stability under load varies considerably -- Antec and Sparkle have performed well. To cover all the bases in the conversion process places some burden on the reader to be equally diligent.
If there is mis-information in the conversion, I would appreciate knowing.
king bily is offline
Old 01-22-2019, 12:55 PM
  #412
init4fun
init4fun's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
andrew
Excuse me "King Bily" , BUT , , is there ANY reason why your post is an exact cut and paste of Andrew's post from 2007 ???? Maybe the fact that your a BOT has something to do with it ????
Consider your Bot butt reported , and hopefully banned real soon ......
init4fun is offline
