preflight
WA
preflight
I have read a few of the posts and realized that I am far from alone in experiencing the disastrous effects of a poor preflight. I am a victim of the "oops, didnt remember that one," too. I had a preflight written out, and before maidening my GP Cessna, I thought I remembered everything. That was the killer, I thought. I didn't read the list that I had written.
I got so caught up in the fact that the engine was finally running perfect, the weather was exceptional for the season, and it was tracking great, that I forgot to check all the surfaces. My elevator was reversed, and I found this out with a bang upon take off.
It is such a bone head mistake that I am embarrassed to post it, except for the fact that it might stick in someone who reads this mind so it wont happen to them.
May all your flights return in as many pieces as they left.
JJ
Enough of the sob story. Here is my usual preflight, post as many of yours as you can, and perhaps the perfect preflight ritual can be realized through shared success and misery. It is also important to note that I fly in an area that has only one other R/C Pilot. I dont have to worry about freqs, etc.
1. Batteries RX/TX
2. Function check, Aileron, rudder/nose, elevator, throttle, flap, retract, etc...
3. Clevis and Clevis keepers (these little devils have hurt me before, just a habit)
4. Extend antenna on TX
5. Wind direction/ strength
Any additions to this are welcome, and I am sure that there will be many. Please remember I meant this as a tool to help the majority, none of us know it all. Please try and keep the comments constructive rather than demeaning.
JJ
1. Batteries RX/TX
RE: preflight
For computer radio users:
- check if you selected the right model BEFORE turning the TX on. Just in case you switch from gas to electro as the engine might start running as soon as the TX is turned on.
- check if the throttle stick is in idle before turning the TX on.
Bart
IN
RE: preflight
Bart
Bart
Also, all the switches need to be in the correct position before starting or flying. It can get ugly really fast if they aren't.
[sm=disappointed.gif]
Rod
RE: preflight
When assempling the plane a couple things i look for
servos tray is it loose (i hade one come un done im my traiener thankfull it didnt do much as it was wedged in place but still somthing i cheack
engine/firwall give the muffler a shack you should have no play in it if you do eather the muffler is loose or your engine/motor mount/firwalll has a problem at that point its a good idea to remove the cowl.
RE: preflight
Yesturday one of my planes failed preflight for a simple little screw fell out and the strut rod between the horizontal and virtical stabs. The plane is a Sig Somthing Extra and it probably would be just fine but I have other planes to fly so I parked it for the day. anyway:
Fuel topped off (I never go up with a partial tank as it's to hard to guesstimate flight time)
1ST!!! Do you have your frequency pin!
MO
RE: preflight
Forgot to turn to low rates on a really, really manuverable Spad plane. Re-kitted sortof $3 worth of new gutter pipe for the fuz and away we go again.
Ronnie
Ronnie
RE: preflight
I think more to the point is to turn-on the Tx BEFORE turning on the model. That way you can check that the right model is selected before doing yourself or anybody else some damage.
Just for interest, this is a basic pass/fail point when taking the BMFA (British Model Flying Association) certificates. The BMFA are the people that underwrite most peoples insurance here in the UK. Very safety minded aorganisation, but it certainly strikes me as sensible to do it in that sequence, particularly as computer radios seem to go through some kind of state of suspended activity (1/2 sec?) when first turned on.
Just my 2 penn'orth
cheers
Rick
Just my 2 penn'orth
cheers
Rick
ORIGINAL: barto
Bart
Bart
RE: preflight
#! "Function Check" is important; BUT be sure that the controls are working in the CORRECT WAY!!!
Wiggling the ailerons does NOT confirm that Left is Left and Right is Right... know what you are looking at! []
#2 Do a range check every morning; before the first flight! [X(]
#3 Weekly if not Daily check all retaining bolts on the engine, A loose engine is not a happy engine.
RE: preflight
ORIGINAL: spad
ORIGINAL: barto
Bart
Bart
Yep, that's actually what I meanth but it was kind of late
Bart
RE: preflight
ORIGINAL: barto
Bart
ORIGINAL: spad
ORIGINAL: barto
Bart
Bart
Bart
cheers
Rick
