Links-Tips/Repairs/Mods CX-CX2
I'm trying to collect links to all helpfull tips-repairs-mods for the CX-CX2. If you have or know of any please post it here so I can add it to my list. This is what I've collected so far.
Tips/Repair/Guides/Mods
Soloboss - Guide
http://www.heli-max.net/mediawiki/in..._and_CX2_Setup
Dacaur - Guide/Disassembly/Brushless
http://www.dacaur.com/bladecxhelp.html
Gear Mesh Guide
http://www.rcheli411.com/pages/howto.php?howto=7&page=2
Klondikes - Swashplate Leveling Guide
http://www.rcgroups.com/forums/showthread.php?t=642401
Flying Tips
http://www.krshobbies.com/tips.html
Flight School
http://www.dream-models.com/eco/flying-index.html
Quattro1975 - Bents Shaft Repair
http://www.rcuniverse.com/forum/m_6791546/tm.htm
Mrasmm - Motor Break-In Guide
http://www.heli-max.net/mediawiki/in...Break-in_Guide
Eat2muchrice - Carbon Fiber outer shaft
http://www.rcuniverse.com/forum/m_6832682/tm.htm
Goldslinger - Carbon Fiber Flybar
http://www.rcuniverse.com/forum/m_6626959/tm.htm
Neilt6 - E-Flight Blade CX2 Mod Guide
http://www.rcuniverse.com/forum/m_5298052/tm.htm
Eat2muchrice’s - Cheap Battery Test and Fix
http://www.rcuniverse.com/forum/m_6970199/tm.htm
CX2 Videos
Installing Aluminum Parts Video
http://www.youtube.com/watch?v=7W3waOA9ANc
Eat2muchrice - Warped blade test
http://youtube.com/watch?v=_7PwNTXOWMs
Eat2muchrice - Blade boil fix
http://youtube.com/watch?v=RmNv8OlG6GQ
RCFEIND’s - Balancing Blades
http://www.youtube.com/watch?v=15h9G...eature=related
RCFEIND’s - Landing Skid Mod
http://www.youtube.com/watch?v=Mz0caJ3eqsE
NightFlyyer's - Gerneral setup and tunning guide
http://www.youtube.com/user/NightFlyyer
Others
Xtreme Product Weights
http://www.rcuniverse.com/forum/m_66...tm.htm#6644467
LED Resistor Finder
http://led.linear1.org/1led.wiz
Flight Log
http://www.lammers.ca/FlightLog/Download.htm
Stores
Michael
http://www.ushobbysupply.com/index.p...sort=2a&page=1
Jamie
http://shop.boomtownhobbies.com/main.sc
I only wanted to list UShobby and Boomtown cause these two are also strong members in this forum. Everyone speaks Very HIGHLY of them both. If I left someone out please forgive me and let me know.
Soloboss - Guide
Gear Mesh Guide
Flying Tips
Flight School
CX2 Videos
Others
LED Resistor Finder
Flight Log
Stores
Michael
Jamie
RE: Links-Tips/Repairs/Mods CX-CX2
I've found this site for anyone who wants to make custom navigation led lights and need to figure out what resistors to use.
Stole this from J-Michael
Might as well put in a link to my carbon fiber shaft.
Carbon Fiber Outer Shaft
CO
Got a few questions about the some of the popular mods
1 if I get ***xtreme*** extended shaft do I need their head or can I use the aluminum one from eflight?
2 if I get the ***xtreme*** Blade grip set will I need anything more, or will my aluminum eflight upper and lower rotor heads work?
3 will the motor heat sink ***eflight*** for the stock motors work for the Xtreme 180's? how much lighter (if any) are they from stock?
4 how much lighter is boomtown's C.F. boomkit than stock? is it more/less durable than xtreme's?
5 who's skid set is more durable boomtown or Xtreme? are either lighter than stock? if so (/not) what is the difference
6 is the 850 7.4v w/ 15c going to give me longer flight times? will I notice more power? are they heavier than stock?
7 does anyone sell the C.F flybar or do I have to make it?
sorry for the gambit but these are a few of the questions I just wasn't able to get an answer to using search
thanks in advance=)
edit's in ***xxxx**** sorry that I was vague before =)
thanks in advance=)
Thats a lot of questions there
* 1. Who's extended shaft? You must read the fine print, most of the stores will tell you what you need to work with what. Not sure?
* 2. Yes, they should work just fine. You would also want to get the xtreme blades with them (both upper and lower)
* 3. Yes. the e-flite heat sink will fit on Xtreme motors, The motors are also about 2g's lighter then stock.
4. Don't know the exact weight but I think Boomtown's is the lightest and probably a little more durable (less parts then xtremes)
5. I think Boomtown gives a lifetime warrenty on their skids and claim them to be indistructiable.
6. Yes that battery will give you longer flight times and you will feel more power
7. No you have to make your own. I havn't seen anyone selling one yet. Check out the soloboss guide up on top, he tells you how to make one.
If you want more advise you should create this in a new thread. More people will see it and post more responces.
Here is a link with Xtreme weights.
Awww. forgot this one too.
Goldslinger’s Carbon Fiber Flybar
[link=http://www.youtube.com/watch?v=Mz0caJ3eqsE]interesting skid mod[/link] I'm gonna give it a try as I seem to be brreaking way to many skids trying hard manuevers in cramped areas.
Thanks green for adding to the list. I've also added this guys blade balancing videos.
Its all updated at the top.
What about RADD'S SCHOOL OF ROTARY FLIGHT?
I think its a must for just getting your mind in gear even though its not strictly a coaxial tutorial
Green : I thought u got some indistructable skids ? You havent broke em have you ?
Thats a good one, wish I read that before I started flying Its very long but i'm glad I found the short version of it at the bottom.
Up she goes into the list, Thanks.
Now this is a strange one but i would put forward a youtube member
David Herbert
This guy invented the ETRM Helicopter we have before us today, the wisdom and knowledge this guy passes on is inspiring
Have a look through, honeybee cx2 etc all covered
Its not so technical, but very good info in a friendly manner
David Herbert
ORIGINAL: Coyote64
I posted that about 2 hours before I sent the order to Boomtown. Ya, the indestructable skids are a #1 mod iMO. That modlooks like it will help with vertical breaks in the legs b ut the horizontal lowers, particularily the fronts will still be vulnerable.
The xtreme ones may look neat but these ones have a 1 year warranty not to break and arent heavier than the stock skids whereas the Xtreme ones look to be a fair amount heavier. Plus when this xteme canopy craps out eventually I will be going back to the stock canopy, probably the marine one so these skids will suit it more I think. I wish they made the whole heli out of this plastic, if they did you wouldn't need replacemenet parts. [&:]
If only lol
OR
ORIGINAL: Coyote64
David Herbert
David Herbert
Mr. Herbert's (Science Class) videos are my favorites! Of course, the guy is part of my generation
FL
What happened to the heli-max.net domain? None of those links are working. Did I miss something, because some of those links look like they would be a great resource!
Thanks!
Nabby
Thanks!
Nabby
