walbro cleaning, paint thinner ,poliuretanic thinner is sure?
Hello
I have a walbro carb from a weedeater featherlite clogged with dirt, hairs, rubberish deposits on the inner filter, small circular screen inside.
If I remove all covers and needle valve , can I flush with thinners ?
Is sure? Or it have other rubber parts inside I can damage.
In my country I have no many options.
I know the circular screen can be removed and changed but I have no spare parts.
In the needle valve side have a metal plate with 2 philips screws, can I remove it? It help ?, one screw have the screwdriver seat broken.
This carb is installed in a reconditioned unit, but work 4 year without problems.
Many thanks for your time
Jose
Argentina
Jose
Argentina
OK
RE: walbro cleaning, paint thinner ,poliuretanic thinner is sure?
If they are available, use a regular carburetor cleaner. If you have a Yamaha dealer, their carburetor cleaner is amazing.
fokker38cc
1) Look on the carb for ID numbers, norlmally on side opposite the adjust needles. Normally, two letters and 2 or 3 digits (sometimes followed by a letter).
2) You can find schematic of the carb here: http://wem.walbro.com/walbro/family2.asp Also the repair / diaphram kit Number
3)
I believe you will need both screws functioning to hold the gasket and diapharm properly. No leakage allowed. Both sides of carb are designed to be removed for service.
3)
dbryan and mikenlapaz
Many thanks for your answers
In this weekend I will dissasembled more the walbro and clean with more time.
The site with exploded view of carbs is of big help.
See you later
Jose
See you later
Jose
