juno rc f-20 tiger shark
GA
i just recived a juno rc f-20 tiger shark and from what i can see the spars are balsa i do not see any hard wood for them can some one help.[sm=spinnyeyes.gif][sm=spinnyeyes.gif]
RE: juno rc f-20 tiger shark
Dragonfly,
What you have is correct. The spars are balsa. No need for hardwood. However, as stated in the instructions...............glass the center section with 6 oz. cloth and resin. I like Z-poxy b/c is sands so easily, but you can use whatever you need.
Setxws6,
The Juno R/C kit has no foam. Perhaps you are thinking of the old DC kit (ARC version) which did have a foam wing.
Setxws6,
My Feedback: (67)
Dragonfly,
Looks like you have the trailing edge shim in backwards. You're building wash in instead of washout. I built one of these last year and found the directions are wrong. I told Juno and he knows about the problem. Change it if you can before you finish.
GA
I dont think its going to matter anyway the guy who gave me the kit lost some very important stuff out of the kit. most of the formers for the fuse. i am missing about 8 formers i am going to see if i can cut them out but i have not had sucsses in the past with cuutting parts from scratch.
