Ratchet to smooth throttle on 16IZ
The ratchet you can do. You need to contact service and get the small plastic piece to make it smooth.
The switch is harder to do yourself. Best bet there is to send it in to service to have them do it.
Follow this link then go to "repair service"
https://futabausa.com/
When the rachet spring mount on my RealFlight controller broke the throttle had no resistance and would drop back to full down when the controller was held up. I thought the controller was a modified Futaba transmitter.
No idea what Real Flight uses. You might try opening it up and taking a look, but it is not a Futaba serviceable item.
