Copperhead Venom 45
#927
WI
RE: Copperhead Aviation Venom 45-30
Thanks Tim! Fortunately I am done with the packets. I have been using Moble Synthetic at 50:1 ever since. I can't find Penzoil for air cooled engines around here.[]
#929
ORIGINAL: Flyer Freq
Cheers,
#930
My Feedback: (7)
TX
ORIGINAL: dmajchrzak
3d-aholic,
Thanks for that link, it explains everything and has good real-world data from Scott.
Guess I'll start looking around for a local source for the Pennzoil 2-cycle air-cooled oil.
Thanks!
3d-aholic,
Thanks!
Scott sells the 8 oz. bottle for $2.95. http://www.brillelli.com/brillelli_004.htm
By the time you take into account finding the source and driving to 3 places that don't have it but said they did, you'll probably pay for shipping.
#931
ORIGINAL: 3d-aholic
FYI.
3d-aholic,
Thanks!
3d-aholic,
Thanks!
Cheap enough, buy a few!!
#933
My Feedback: (146)
MN
Forgive me for chiming in so quickly again. But I started to do more looking around at Opti-2 and found this little tidbit in the forums...
I guess it IS petroleum based... my mistake if I indicated otherwise.. I wonder if this "stickiness" is the cause of some issue?
- Dave
" a few things about Opti-2
It sticks to everything in the engine. every thing is coated with a sticky oil
It is drawn to heat, like solder, so the hotter a spot gets the more lubrication it gets.
And it is not synthetic.
Opti-4, for 4 cycles is in every new BMW off the assembly line."
- Dave
#934
What type of Mobil oil should be used? I did a quick google on Mobil oil 2 stroke with no luck.
32:1 breakin? 40:1 thereafter?
What would idiots like me do without these forums....
It may be a China thing, I will check today and let you know. No question is bad, asking is how we all learn!
We are getting ready to start a production run here and as it goes along, I will post pics of our factory in this thread. Here is one of our building.
Cheers,
#935
ORIGINAL: Scott Ellingson
That is the problem with the Opti IMO. It sticks were the heat is and causes rings to stick. It is a black nasty coating. Here is a pic. It is a 46 piston with less than 3 gallons through it. I could not find the one with a little over 3 gallons through it. I had to remove the ring in 3 pieces. Penzoil is great for break-in. Bel-Ray, Mobil 1 2T are good afterwards. Actually the Penzoil is fine all the time. I have a few people using it. One with over 20 gallons and no problems at all. I was sucked into the Opti pit and paid the price.
- Dave
- Dave
Thats Nasty!!
#936
My Feedback: (40)
NH
Dave, I got a case (minimum order) of Mobil 1 Racing 2T from AV Lubricants in Groveton (Groveport?) OH (6 1-qt bottles). It took a penetrating search to sniff them out. This is the oil that MVVS specifies for their 2-stroke gassers, Pe Reivers says he uses it for all his gassers, 32:1 all the time. Good enough for Pe is good enough for me. PM me and I'll be happy to part with a quart if that's any help to you. Six quarts will probably last me the rest of my life at the rate I'm flying these days.
Seems to me I found Pennzoil small bottles at Walmart last time I looked.
#937
TX
- Dave
- Dave
#938
TX
Scott,
Just so you'll know, I remove stuck piston rings by submerging them in a little container of HEATED up Berryman B-12 Chemtool. I've never had one that wouldn't un-stick! If you decide to try this, don't use an open flame.
#939
My Feedback: (7)
TX
ORIGINAL: mfuess
I have a Brillelli 46 that has at least 20 gallons run through it, and except for a little brown on top it looks brand-new. All I have ever used in it was Pennzoil 2-Cycle oil at 32:1. My Venom 45 in my Pitts Monster has well over 200 flights and the piston is still shiny on the skirt and a little brown on top. Same oil... You couldn't pay me enough money to switch to another lubricant.
I think I may stick with Pennzoil as well. If you take a look at the Ultralight oil tests link I posted, they test against a popular synth. as well. You can see that the synth is nearly as good as Pennzoil in some places and better in other places....however the buildup is worse basically because they are mixing it at 50:1. The article describes that they intend to run the tests at 50:1 even though a lot of folks using synth mix at lower quantities. A lower ratio would probably leave a lot less buildup then maybe even the Pennzoil at the expensive possibly of engine life. So there is a bit of a toss up there between the petroleum based lubes and the synths.
#941
TX
There's way too many brain cells being burned up here, on what's the "best" oil.
ALL manufacturers of 2-cycle oil carry total liability of their product performance. If their product is used precisely as recommended, and you experience engine failure specifically because of their product. It's the Mfg's responcibility to repair or replace the engine. I've had 2 engines replaced over the years by a 2-Cycle oil mfg. (Names intentionally omitted). The engine mfg also carries the same legal burden, if a particular lubricant is recommended and failure occurs with said product.
Read the LABELS and determine if its the CORRECT lubricant for your application.
#942
Nice little free calculator here some might find useful, won't tell you the best oil for your application, but it will help you get the correct ratio's...!!
http://www.mbdrafting.co.uk/Software-1/Software-1.htm
Paul.
Paul.
#944
TX
ORIGINAL: 3d-aholic
In other words, Pick an Oil that others swear by....and roll the dice.
#945
Hi Guys
Has anybody tried or experimented with different pipe or can set ups with the Venom..? I fly from a noise sensitive site, so i might need to quieten things down a bit, but i don't want to loose too much performance if any. just wondered if anybody has played or experimented with it.
Thanks for any help.
Paul
Paul
#946
ORIGINAL: norbert001
Hi Guys
Paul
Hi Guys
Paul
I tried a bunch of different designs on the pipe and found the current design to be the best. If you stick with about the same volume or greater, it should yield good results. I have a guy at our field that has a DB meter permanently attached to his hand, so I know what you mean!!
Cheers,
#947
Thanks for that Tim, got a few different props to try out first, I shall then take it from there if needs be.
Pretty sure a ZDZ 50 manifold pipe will fit,( The gasket looks the same anyway) so i've got a starting point if i need to go down that route.
Cheers Paul
Cheers Paul
#948
TX
Hi Guys
Paul
Hi Guys
Paul
Your Venom muffler is quieter than most factory supplied mufflers. With the correct prop, you will be well within AMA guidlines. We have a noise restriction at our field and I haven't had any issues with it. But if you still need a little less db, simply close off one of your exit stingers. This will reduce your engine noise by a good 4 to 6db without cutting too much power. A good quality cannister muffler would be OK but they cost a fortune and then you still have to find a header that will fit your engine & airplane. Try the simple things first.
#949
Mark;
That was going to be my next question..!! concerning the stingers, hopefully i won't have to do it, didn't know whether it would create to much back pressure.
A correctly propped engine and a few lessons in good throttle management should help quieten things down a bit...!! [sm=thumbup.gif][sm=biggrin.gif]
Cheers
Paul
Cheers
Paul
#950
TX
Mark;
Cheers
Paul
Mark;
Cheers
Paul
