New SV Gassers
Old 09-25-2008, 02:59 PM
  #801
HeliTB
HeliTB's Avatar
Default RE: New SV Gassers
I agree with you Charlie. I paid $175 from HK shipped and the 644 carb cost me $35 for a total of $210, that's still cheaper than what I can get it for in the USA ($210-$225 not including shipping) without the better carb with choke and larger venturi.
But I still agree.
Old 09-25-2008, 03:30 PM
  #802
Charley
ORIGINAL: HeliTB
But I still agree.
I have to admit that I bought the SV26 on a lark. I had the $$ and thought "What the H."
My engine runs fine, has no choke but needs one to start from cold. On the bench, I put my thumb over the carb and flipped it a few times. Still wouldn't flip start. So I spun it with my starter and it fired up. After that it would flip start.
I figured to make a choke plate, pivoting off one of the mounting bolts.
CR
Old 09-25-2008, 04:45 PM
  #803
chutt
chutt's Avatar
ORIGINAL: lotech
ORIGINAL: chutt
Hi!
I received my SV 26cc from HobbyCity last week. Is my first gas engine.
Beautiful engine, but I have some questions about his Walbro carb.
I take some pictures of his carb...
Point 1: what line I connect in this tube?
Point 2: in this tube I suppose that I connect the fuel line coming from tank. It´s ok?
Point 3: from where this tube comes?
Last questions... This carb don´t have choke. This bulb have the same finality? What´s the procedure do start this engine? How can I start this engine in a full cowled airplane?
Thank you!
Andre.
Andre, the #1 is to put pressure to the tank on weedeaters, plug it. #2 is for the fuel line from the tank!!! If you start this engine with a electric starter you will have no problems when cold
with no choke.. I made a choke plate for mine to help hand starts!! Hope this helps,,,,, Lotech
Hi Lotech,
thank you to reply!
On number 1 tube, I can let it without line plugged?
One friend tell me that this kind of gas engine (with stand off mounts) can not be breakin in a stand, only on the plane, because of the vibration... this is true?
How much oil I need to add to gasoline to breakin period? And how much time to breakin this engine?
Sorry for the stupid questions (), but is my first gas engine and it came without manual! [:@]
**Lotech, can you upload some pictures of your homemade choke plate?
Thank you all!!
Cheers,
Andre.
Old 09-26-2008, 11:39 AM
  #804
HeliTB
HeliTB's Avatar
chutt...Break in 20:1 to 25:1 for 2 to 3 hours, then you can run 40:1. Not sure I agree with your friend regarding breaking in on a stand or plane. Not sure of the vibration either. I would think the vibration would be more abusive to the plane.
Old 09-26-2008, 07:58 PM
  #805
mikeboyd
ORIGINAL: HeliTB
Agree on your recs. I have one of HC's XYZ 28cc's Spec A, which was about $235 with shipping (as platinum member, forbidden to disclose our few dollars saved) Bought it nearly a year ago on a lark. Now running Amsoil Sabre at 65:1 with an APC 18X6W prop. Starts easily and flies my GB Wildstick great. I also bought another Wild Stick on close out from Tower and put the SL 52cc on it. Still running it on breakin fuel, but improving with every flight. I have bought over six various engine from HC, with no issues at all on any of them. The use of the Walbro carbs from Japan, really takes allot of the mistery out of these sweel little engines. I also have two DL-50's that are real powerhouses and very reliable so far.
I'm still laughing all the way to the bank, to put money in savings for more planes!!!
Old 09-26-2008, 08:13 PM
  #806
mikeboyd
ORIGINAL: mikeboyd
ORIGINAL: HeliTB
Agree on your recs. I have one of HC's XYZ 28cc's Spec A, which was about $235 with shipping (as platinum member, forbidden to disclose our few dollars saved) Bought it nearly a year ago on a lark. Now running Amsoil Sabre at 65:1 with an APC 18X6W prop. Starts easily and flies my GB Wildstick great. I also bought another Wild Stick on close out from Tower and put the SL 52cc on it. Still running it on breakin fuel, but improving with every flight. I have bought over six various engine from HC, with no issues at all on any of them. The use of the Walbro carbs from Japan, really takes allot of the mistery out of these sweel little engines. I also have two DL-50's that are real powerhouses and very reliable so far. I am very impressed with my SV 50CC twin, so far!!
Old 10-05-2008, 10:14 AM
  #807
chutt
chutt's Avatar
Hi guys!
Thank you for all the help!
I have a question... Hobbycity do not sell SV 26cc more?
On Hobbycity page , there is only SV 50cc and 100cc to sell...
Cheers,
Andre.
Old 10-05-2008, 10:44 AM
  #808
sam.s.man
Ya.., i notice that too...Pity, I like that engine..Wonder where else can we find it...
Old 10-05-2008, 11:42 AM
  #809
asharog
RC Showcase carries them now
http://www.rcshowcase.com
Old 10-05-2008, 12:32 PM
  #810
sam.s.man
Y I knew that all along...but the price...
Old 10-06-2008, 11:58 AM
  #811
Charley
ORIGINAL: sam.s.man
Well gee; didn't you know the RCS version is a "better" and "improved" version?
CR
Old 10-06-2008, 12:18 PM
  #812
sam.s.man
ORIGINAL: Charley
ORIGINAL: sam.s.man
CR
For $100 different..?Na...
Old 10-06-2008, 07:42 PM
  #813
chutt
chutt's Avatar
Hi all!
My SV 26cc came with a 2 bolts propeller hub, so I need to drill two holes on the prop... Can I use a Master Airscrew without problem?
Somebody using attach system with Master Airscrew propellers?
Cheers,
Andre.
ID:	1047224   Click image for larger version
ID:	1047225   Click image for larger version
Old 10-07-2008, 10:43 AM
  #814
Charley
ORIGINAL: chutt
Hi all!
Cheers,
Andre.
Methinks you're going to need a prop with a solid hub or at least one without all those surface voids.
Where and when did you get that engine? That's some prop drive adapter. More pics purty-please.
CR
Old 10-07-2008, 04:37 PM
  #815
chutt
chutt's Avatar
Hi Charley!
Thank you!
I bought this engine from HobbyCity, on the begin of September, and payed U$150,00. I did not run the engine yet, but it is very well made... HobbyCity do not sell the SV 26cc more, they only sell the SV 50cc and 100cc. SV 26cc have been sold now by RCS, or RCShowcase ([link]http://www.rcshowcase.com[/link]).
Here is some pictures of my SV 26cc...
Cheers,
Andre.
ID:	1047688   Click image for larger version
ID:	1047689   Click image for larger version
ID:	1047690   Click image for larger version
ID:	1047691   Click image for larger version
ID:	1047692   Click image for larger version
ID:	1047693   Click image for larger version
ID:	1047694   Click image for larger version
ID:	1047696   Click image for larger version
Old 10-07-2008, 04:47 PM
  #816
lotech
hello again.
hobby city now offers the FTL 26 !
we have one and are planning on flying today with it in a KMP corsair.
I'll let you guys know how that goes.
It is a little more than the SV but, looks better (as in stronger billet crankcase) , and runs very well!!
About the same weight, and a side carb.
Old 10-07-2008, 10:27 PM
  #817
sam.s.man
That looks like a HH26 engine NOT SV26 that was advertised! Hobby City..as always...well, you know what I'm trying to say...
There's another Hong Kong HS, some items, are much cheaper than HC..This HH26 is sold here.. http://www.sunnyhobby.com/index.php?...0&productname=
Old 10-08-2008, 01:51 PM
  #818
lotech
Hello Sam,
Is the service from them better?
Also we didn't get the corsair running last night [&o]
My friend forgot to charge the battery [:@]
hopfuly this weekend she'll go up !
Old 10-08-2008, 02:03 PM
  #819
sam.s.man
No idea lotech... But the guy, Lewis, seems to be friendly...
Old 10-08-2008, 10:01 PM
  #820
Charley
ORIGINAL: chutt
Hi Charley!
Thank you!
I bought this engine from HobbyCity, on the begin of September, and payed U$150,00. I did not run the engine yet, but it is very well made... HobbyCity do not sell the SV 26cc more, they only sell the SV 50cc and 100cc. SV 26cc have been sold now by RCS, or RCShowcase.
SNIP
Andre.
Hi Andre,
Yes, RCS got the distributorship for SV in the USA and then the factory quit selling to Hobby City. Same thing happens over and over. Those engines are "junk" when sold direct from China but the quality improves when a US distributor gets in place! The quality is so much better that they cost ~$100 more! I should have bought a couple more of them from HC when I had the chance!
Thanks for the pics.
CR
Old 10-09-2008, 12:21 AM
  #821
lotech
ORIGINAL: Charley
ORIGINAL: chutt
Hi Charley!
Thank you!
SNIP
Andre.
Hi Andre,
CR
sorry charlie, but tell me how the Q improves??? service ,yes.
And these "cheap" engines are not "junk"(did I read you wrong?)
"cheap" yes.....
Old 10-09-2008, 12:22 AM
  #822
sam.s.man
ORIGINAL: Charley
...but the quality improves when a US distributor gets in place! The quality is so much better that they cost ~$100 more! ...
Yupp! The quality automatically improves by sooooo much (actually by 67% - ((250-150)/150) * 100%), simply by reselling it in the US !!
Old 10-09-2008, 12:24 AM
  #823
sam.s.man
lotech,
read between the lines...
Old 10-09-2008, 12:33 AM
  #824
lotech
We flew the FTL26 on the corsair tonite!!!
The plane weighs 12.86 Lbs. It was great for a engine that's not broken in yet!!
not awesome,but my friend insisted on a 14x9 3 blade on a new engine.
no overheat but, you could tell it didn't like it!!!
rough guess it was doing about 75-80 mph on the level .
On the ground tach was 7500.
btw HELLO Sam !!!
HELLO Charlie!!!
Old 10-09-2008, 12:50 AM
  #825
sam.s.man
Hello lotech...
Nice warbird you have there...I'm building one too, CMP warhawk P-40 140 running on ASP180FS-AR..
