DL-50 engine
#3677
WV
RE: DL-50 engine
69,
I have one off the new ones that I have converted and it has held up just fine... I would suggest that you have the local machine shop weld on a small bung to hold the threads better but that is all you will need...
Good Luck,
Ed
Good Luck,
Ed
#3678
RE: DL-50 engine
Well i will order one and give it a shot I have one of troy built models smoke jets it looks like it will spay a very fine stream should work great. I just hope the muffler last a little longer.Thanks 69
#3679
WV
RE: DL-50 engine
69Runner,
I use the same tap and it works fine.. Just an additional suggestion, dial down the smoke oil volumn to 50% right off... And then adjust to the desired level. I have found that both pumps that I have tried (TME and Sullivan) that they pump way more Oil then needed...
Good LUck!
Ed
Good LUck!
Ed
#3680
My Feedback: (85)
RE: DL-50 engine
ORIGINAL: thevirginian
Paul, are you serious with the 7650 on a 22x8? Mine turned "only" 7200 withthe same prop. And with a 22x10 it dropped to 6700. Now those numbers where measured from aTBM wooden prop.
Kevin
#3682
NY
RE: DL-50 engine
ORIGINAL: chuck l
Kevin,
I think your tach needs calibrating! Just kidding, that's impressive. What are you running for a muffler? Any idea what the static pull is?
Chuck
Kevin,
Chuck
#3683
RE: DL-50 engine
ORIGINAL: cmoulder
Hmm... what is TOO HIGH when it comes to RPM's for a 50cc?[sm=confused.gif]
ORIGINAL: chuck l
Kevin,
Chuck
Kevin,
Chuck
#3686
My Feedback: (85)
RE: DL-50 engine
ORIGINAL: chuck l
Kevin,
Chuck
Kevin,
Chuck
Tach is brand new and checked agianst others...Works fine...[sm=thumbs_up.gif]...Exhaust system is a Chip Hyde header with one of his pipes...Prolly adds a couple of hundred RPM....I have no idea what the static thrust is but it pulled the Chip Hyde Vision vertical forever...Engine and pipe are now mounted on an EF Yak...
Kevin
#3687
SD
RE: DL-50 engine
Okydoky you all have me convinced that the DL-50 is a good engine. I will be ordering one for a 27% G.P. Cap 232. It should be in the 13-14 pound range. What Vess prop do you think? I know.. its been asked before but there is 148 pages of info here! Also, has anyone run Avgas in the DL-50? Thanks guys.
#3688
My Feedback: (42)
NC
RE: DL-50 engine
Mr. Vess told me that the best prop for a 50cc engine for Three D flying is the 23 A he flys at our club from time to time, I would think that you would want to do Three D with that cap?
#3689
RE: DL-50 engine
ORIGINAL: rockitboy
Mine is a Pitts Bipe at 15.2#, and it will rip.......
#3691
My Feedback: (42)
NC
RE: DL-50 engine
As Mr. Vess had explained to me that the 23 A is not an 8 and it si not a 10 because of the twist that the prop has, then he went into the science of the twist of the prop at that point he lost me, I will say that the prop has done me well on my two 3D birds,
#3694
TX
RE: DL-50 engine
I have been running this engine for over a year now and it has been a nearly flawless motor. Only time it didnt run right was my fault messing with the needles.
I run a Vess 22A on mine. A lot of people will swear by certian props. As far as top rpm... I could care less about that as I am more concerned with how the engine performs on transition. What really matters is... what does the plane like? I am flying a 27% Ultimate. Lots of drag so it need lots of pull (traction). So the lower pitch prop is perfect for this plane. I havent tried a 23A or 22B and I am sure this engine will pull either just fine. It has the power to take it staight up on demand at most any attitude without any lag even after extended low rpm run and thats important to most any seasoned pilot.
BTW from what I have experienced so far the Vess is one of he quieter props out there.
Cant really go wrong with this engine from a value point($390 shipped including accessories). And certianly no problems with the service from Bob Kramer (DLUSA.COM)who markets them localy here in Texas.
Wayne
Wayne
#3695
VA
RE: DL-50 engine
I have a DL50 on order for my GP Ultimate. Unfortunately it is the Chinese lunar new year and DL is getting no shipments from China. It's been around 10 days since I placed my order and Bob at DL told me they will hopefully get a shipment at the end of this week. That's fine with me but the only problem I have is that they charged my credit card at the time of order without informing me they had no engines to ship.
#3696
TX
RE: DL-50 engine
Steve,
I hear yah on the credit card charges. I am sure Bob would credit your card if you asked. But since he said the next shipment is due soon I wouldnt get to worried.
WG
WG
#3697
LA
RE: DL-50 engine
Hey guys, im new to this forum. Im about to make the switch from glow to gas, ive been reading post on the DL, man yall have me hooked on that engine now. Im gonna call and order it on Feb 28th, man really pumped up about it, its going to be my first gasser!!!!!!!!!
#3700
LA
RE: DL-50 engine
Man tell me about it, im running a moki 1.8 on a edge 540t and boy does that thing drink down a gallon off fuel. Guys ive been reading alot of post on the dl and it seems to be a fine lil engine, oh and im glad to hear that its a user friendly engine to get started with. Thanks for replying guys...
Moki
Moki
