15cc Gas RCGF engine information thread
#502
Hi, after buying a new un runned engine, I was wondering if anyone on this thread, ( I did see one asking and one cleaning out the 'airways' ) is anyone else actually doing some work on his motor to get some power out of it ?, I will be stripping my new motor this week and cleaning up the engine ports to see what sort of rpm i can get out of it,,,
#508
I started stripping the motor, there is some work to do to align the crankcase to the cylinder, which has an inside diameter of 30.9mm (so it's around 17cc ) the piston rings aren't square but rounded, hence the extra 1000 rpm claimed with 'Bowman' rings. the cylinder bolts weren't tight and some sort of red 'goo' was used to ( two drops ) probably to keep the joint in place, which will be scraped out before any damage is done, the engine itself is well lubricated.
#509
It's a simple 'reed valve', you can get the fibre glass or carbon sheet from most chain saw and go-kart shops.
I have reworked the carb side to line up with it, amongst other 'tweaks' ,,
#510
Can anyone out there tell me what RPM they get on the RCFG 15cc, with an APC 14 X 18 Prop ?.
Opps, 14 X 8 APC prop,,,
#514
Opps I forgot the 20% French taxes ($6) and customs charges ($18) so at around $50 ,,,
I have contacted "gaviscool" on ebay, and waiting to see if he can supply one, .
I have run it a couple of minutes, and as you can imagine it's not enough time to bed the ring in, and has virtually no compression,,
Last edited by paulinfrance; 12-27-2015 at 02:08 AM. Reason: gaviscool piston rings
#519
2 thoughts.
1st, could be wrong, but thinking that's not a lot of prop for that engine. Is the thought there to run it at a relatively light load? I do that with ABC engines, but ringed engines I usually run the prop I plan on using it with for break in (or something relatively close) with big heat/cool cycles.
2nd, will you be using mineral/dino based oil to attempt a little quicker break in (vs. synthetic)?
I haven't had any trouble with RCGF rings - but I don't have a 15 either. -Al
#520
Mine is on the old 60-size Hangar 9 P-40. It has a 13x8 3-blade and a Hobbyking Pitts-style muffler. It unloads nicely in the air. I use a 32-1 oil mix of a synthetic blend.
I have never tached it but would guess it's above 9k in the air.
Also, I have a 12 ounce tank in the plane and a 30 minute flight at cruise settings is normal. It's my go-to plane to warm up and get rid of the jitters before I fly one of my 60cc fighters.
#521
I have run it for about 350ml of 5% fuel mix, it starts and runs well I am getting these rpm's on,
APC 'sport' 13 X 6, 10.500
APC 'normal' 14 X 8, 8.450
both started the afternoon 500 rpm's less and now it has got quite a bit of compression, the only problem is the Vibration !, that's with a capital "V" !, I have NEVER had an engine vibrate as much as this RCFG !, it was fixed to a thick plank and clamped ( 3 record professional ones ) to our model tables which are old 50mm concrete table tennis tables and even that shook !, and the cramps vibrated loose in less that 1 minute !, so tomorrow I will strip it and have a go at balancing the crankshaft.
Last edited by paulinfrance; 12-27-2015 at 10:26 AM. Reason: Opps APC 13 X 6 not 11 x 6
