Noise and interference
Hi every body
i have a 36% the world models katana 100 cc.
When the assembly of the plane was finished , I have lots of noise and interference in all of the servos.
1× rg7318 receiver
1× dualsky duo pro regulator
2× multiplex Digi 5 Titan on elevators
4× savvox 0220 servo on ailerons.
So anybody can help me how I can spoil the noise on my system.
lots of thanks
1× rg7318 receiver
lots of thanks
I check it and say you what I see.
Nope! I said to eliminate each item one at a time to test. But if this only happens with the engine running focus on plug wires as stated above first. I read your question as if the noise is always there and not just when the engine is running. While regulators aren't common for problems, a poorly designed one can do this.
Lots of thanks
I test it
I test it
Problem was fixed
HiFirst I fastened all the plugs onto the receiver
And then I kept the regulator as far away from the receiver as possible.
The problem was fixed and I did several tests at different times
Thanks to all the friends for the tips
Good luck
Good luck
