What has more power, a Saito 1.80 or a Moki 1.80?
Moki 2.10
We just had one of our anual funflys today at our field. A guy there had a Moki 2.10 in his Hangar 9 540 and it performed great. Very sweet running and reliable engines.
Good Luck,
MIke
Good Luck,
MIke
The moki will almost certainly have more horsepower, its a 1.8 2-STROKE.
The saito, being a 4-STROKE, will have less hp but will probably turn a bigger prop and be quieter.
My Feedback: (8)
Originally posted by Jim D
Not quite, my Moki 1.8 turns an 18x8 Pro Zinger around 8300 RPM on FAI fuel, tuned pretty rich. The Saito 180 is not even in the ballpark with it on 18 inch props.
The 2 stroke will still of course produce more power than the 4, it will just do so turning a smaller prop at a higher rpm.
MN
Definately the Moki, but I wouldn't overlook the O.S. 1.60FX.
The o.s. will outperform the Saito also, and is a fantastic starting and running engine.
One of the best places to resolve this sort of question is www.rcfaq.com.
A look at the RPM data base will show that the 25-30 cc engines all seem to produce their maximum power around 9000 RPM.
NC
RE: What has more power, a Saito 1.80 or a Moki 1.80?
Glad that you mentioned the OS 1.60. I'm thinking of putting one on an ultrastick (pre-lite). Any ideas on who this might work? Everyone swears by the Saito 1.80, but I'd like to try a two stroke on it for power to weight ratio issues.
thanks
xkadet
thanks
xkadet
My Feedback: (41)
I've tried both engines in my Kangke CAP232 25% and the Moki 1.80 is waaay better, trust me. I would use a Perry pump if I were you. That way the engine runs the same mixture full to empty tank and the CG is perfect for the entire flight. That's my setup and it's very impressive. Hovering is at just under half throttle on my 14 lb plane. The Moki will burn less fuel so you can use a 16 oz tank for about 9-10 minute 3D flying with an ounce or two left. WOT is about 8 minutes with an ounce left. Also the Morgan 0% nitro fuel is about $9 a gallon vs the 30% heli that you need on the Saito ($25 a gallon). Use a Bambula 18-8 wood or Menz S 19-8. I love these engines. A gallon of fuel will last me a couple of weekends flying both days.
The Moki will turn one to two prop sizes higher than the Saito 180.
My Feedback: (41)
ORIGINAL: Phil Cole
So my experience is that the Moki is a very good glow engine for aerobatics. The 4-strokes have even better torque delivery but that don't have the brute power of the Moki and use a lot of expensive fuel.
I would definitely overlook the OS160FX. It will pull the H9 Edge around but not much else.The OS160FX has very poor low end performance.The Saito 1.8 and the Moki 1.8 are both a better choice. My choice would be either the Moki 2.1 ( use the left stick) or even better a YS 1.4 FZ and up if the budget will take it.
ORIGINAL: daven
MI
Some hard rpm figures that I have personally taken:
Moki 180 w/ 5% nitro
APC 18x6W @ 9400
Pro Zinger 18x8 @ 8600
MA Scimitar 19x8 @ 8000
Saito 180
APC 17x6 w/ 15% nitro @ 9700 rpm
APC 18x6W w/ 30% nitro @ 9000 rpm
Saito 180's main advantage is its light weight. But if the plane needs nose weight to balance, which may very well be the case for H9 Edge, then Moki 180 is better choice. I think the sweet spot for Moki 180 3D would be the Bolly 19x6 carbon prop. It's expensive, and presumably heavy. Or go for Mejzlik 20x6, which should peak @ 8000 rpm.
APC 18x6W @ 9400
Saito 180
My Feedback: (14)
The OS 160FX will make almost the same power as the Moki on the same fuel but weighs much less.
This thread is kind of funny. There is no realistic comparison between the Moki and the Saito. The Moki weighs over a pound more with muffler and makes much more power on no or low nitro compared to the Saito.
A flyer at my field has said plane with a Saito 1.80 and it does fly it ok ,but he keeps looking over my Moki in a katana and would like to change but he has already spent the dallars on the wrong choice.
My Feedback: (41)
That's no problem. I took my Saito 180 out and installed the Moki 1.80. I sold the Saito 180. Takes a little work but worth it in the end.
ORIGINAL: Vortec
ORIGINAL: JoeAirPort
My Feedback: (41)
The Moki has total authority as far as throttle goes. This CAP232 was 13 lbs 4 ounces with the Saito 180 and 14 lbs with the Moki 180. It was just too heavy for the Saito. Now it pretty much just blasts forward when you go WOT. Vertical is very very good. You pull up and it goes to the clouds in no time. Hovering is way better. It's about half throttle now. I didn't even attempt it with the Saito 180 since I only did one flight with it and was not comfortable with the power it had. For 3D the Moki 1.80 is the ticket for an ARF 13 -14 lbs. The Saito would be good for about 11-12 lbs max for 3D. You do have to always manage your throttle when you have that much power (the Moki). The other nice thing is that the Moki 0% nitro fuel is only $9 whereas the Saito 180 fuel is $15-25 a gallon. The Moki also burns less fuel so I only run a 16 ounce tank on my 14 lb CAP. That's pretty good for an engine this size. The Moki runs K&B 1L plugs that are $2.50. That Saito use a type F plug which around $8-10. The Moki sounds pretty cool too.
It's just the perfect power plant for a plane this size and weight IMO.
ORIGINAL: FlyHard
What change did you notice in your models flying after the switch to the Moki
