Golden Age, Vintage & Antique RC Want to discuss some of those from the golden age, vintage rc planes or even an old classic antique vintage rc planes, radios, engines, etc? This is the place for you. Enjoy!
WACO YMF
Old 04-29-2013, 05:10 PM
  #16251
WacoNut
WacoNut's Avatar
Default RE: WACO YMF
tmac,
Your Waco is looking great.
The cowl blisters are a PITA to deal with. I have never tried decals but I have tried vinyl mask on them and it is hard to get them to conform. I like to paint all my markings when I can. You may find it hard to match up paint to your stripes on the fuse.
Not sure what kind of decals you have but you could try applying heat from a hair dryer while you work the decal down around the blister. The compound curve makes this very hard to do.
Later!!
Anthony
Old 04-29-2013, 05:18 PM
  #16252
tmac48
tmac48's Avatar
HI Nut, thanks for your comments and advise re the decals on the blisters, I have tried all the methods that you have suggested with varying degrees of success . I think I will talk to professional painter/sign-writer and see what he suggests .
tmac
Old 04-29-2013, 05:42 PM
  #16253
WacoDream
WacoDream's Avatar
tmac - congratulations on your beautiful WACO. Really nice work.
Old 04-29-2013, 06:50 PM
  #16254
tmac48
tmac48's Avatar
Thanks Dream
tmac
Old 04-29-2013, 08:28 PM
  #16255
jymster
My Feedback: (9)
jymster's Avatar
ORIGINAL: tmac48
It has been a while since my last post,a lot to do with not enough time to do it all. Have been applying some more detail but having a devil of a time trying to get the decal to conform to the rocker bumbs on the cowl, may have to resort to painting. Any ideas from anyone who have been there and done that.
tmac
Hi tmac,
You could try a decal softening solution. I think the plastic kit guys use this for compound curves. You can find articles on the web about it.
Some product links:
[link=http://www.horizonhobby.com/products/decal-softening-solution-1-oz-BAD16802]http://www.horizonhobby.com/products/decal-softening-solution-1-oz-BAD16802[/link]
[link=http://www.micromark.com/decal-softeningandsolvent-solution-1and2-fl-oz,9125.html]http://www.micromark.com/decal-softeningandsolvent-solution-1and2-fl-oz,9125.html[/link]
Try YouTube for some tutorials.
Hope this helps.
Old 04-30-2013, 01:19 AM
  #16256
FMBB
Hi tmac,
nice built do you take any orders for painting Wacos? I have one close to be ready for painting, may be the shipping might be a bit too expensive to down under. One question are you confident that the flying wire suspension points at the lower root rib will cope with the loads? The load introduction will not be along with the longitudinal axis of the parts if they are not strong enough they at least may bent. The forward attachment is ok as the load will be along the axis. This point is important if you loose the wires you will loose the ship if you are not very very lucky. In one of the previous versions we used only one screw to fasten a fairing which accepted both flying wires. As sh... happens, the screw was a bad screw[&o] (air inside the material one could see that on the threaded part which still was installed) head came off and all two flying wires were lost. This resulted in an unrestorable crash. This was the reason why we changed the system to two screws now to prevent such a problem in case you get that bad screw out of hundred.
Peter
Brother#170
Old 04-30-2013, 01:40 AM
  #16257
Stickbuilder
Stickbuilder's Avatar
Anthony,
You can always enter the Pro-Am class at Top Gun. Not too much detailing required there. Only thing needed is a photo of the full scale plane to show it did exist. No static judging either. It's a great stepping stone to scale competition.
Bill, Waco Brother #1
Old 04-30-2013, 04:58 AM
  #16258
tmac48
tmac48's Avatar
Hellow FMBB, I thought for a moment that you were going to say that you had a 40% WACO kit ready for me. I do appreciate your concern about the flying wire anchor points, but I can assure you that they will be fine. 4 mil stainless eye screws 40 mil long screwed and glued, the arnt going no place.
PLEASE DO A 40% ER
REGARDS TMAC
Old 04-30-2013, 05:03 AM
  #16259
tmac48
tmac48's Avatar
jymster, thanks for that info, very interesting, apparently white vinegar can be used as substitute for the decal softener solution.
Regards tmac.
Old 04-30-2013, 06:28 AM
  #16260
FMBB
Hi Tmac,
just in the course of developing another bipe close to a Pits but no Pits the original was built in the 30s and was famous for its capabilities doing aerobatics, so another scale project but not a 40% Waco. A 40% Waco would require a lot of effort to keep it below the 25 Kg limit we have here in Europe. Above the 25 you will need a special permission to fly your model and the airfield has to be certified too, so it will be not so easy to fly it during fly meets on other airfields again you have to ask for a permission (that's the old world problem too many guys you have to ask for permissions but that's due to the high density of residential areas I guess).
Peter
Waco brother #170
Old 04-30-2013, 06:52 AM
  #16261
LesUyeda
Banned
For masking the blisters, there is a stuff called "liquid masking tape". Paint it on (several coats), cut the pattern with an X-acto, and peel off what you want colored. Google it, and you will come up with a bunch of choices.
Les
Old 04-30-2013, 10:03 AM
  #16262
mrdhud
My Feedback: (48)
mrdhud's Avatar
I’m finally getting the aluminum landing gear installed and sheeted with balsa. I have to figure out how to mount the 1/8†music wire to the gear any ideas would be appreciated.
WacoDream,
You progress is looking good I know what you mean about getting inspired with these big Waco’s. See you at Top Gun.
Tmac,
Your detail work is fantastic I especially like your wind screen.
ID:	1877726   Click image for larger version
ID:	1877727   Click image for larger version
Old 04-30-2013, 11:28 AM
  #16263
EJWash1
EJWash1's Avatar
Hi All,
I'm in the process of building a Dave Platt (not Pica) 1/6-scale (60") YMF-3. I'm at the tail feathers and I'm looking for the horizontal stab incidence setting. Neither the plans nor the instruction manual mention it. I measured the angle between the fuselage crutch and the horizontal stab using a digital incidence meter and got +.6-degrees.
Thank you in advance.
Old 04-30-2013, 12:10 PM
  #16264
Dash7ATP
Dash7ATP's Avatar
ORIGINAL: tmac48
tmac
Give Kirby Graphics a call. @ 513-332-2422. He did the markings for my 1/5 scale Waco. He specializes in only model grap[hics and uses a very thin vinyl for his stuff. You can look at my model and see how my cowl came out. I'm very pleased.
Joe
ID:	1877766   Click image for larger version
ID:	1877767   Click image for larger version
Old 04-30-2013, 02:44 PM
  #16265
Jim Henley
EJ,
The 1/5 scale is +2 Degrees according to the Pica manual. I would think +6 would be way more than needed.
Old 04-30-2013, 03:10 PM
  #16266
WacoNut
WacoNut's Avatar
Bill,
If I can can keep from re-kitting my Waco this summer I just may ask for an invite next year to Top Gun in the Pro-Am class. I am sure it is a good time.
tmac,
Best of luck with the blisters. Make sure you let us know how you handle them.
Joe,
I will have to look up Kirby Grahics, I see it is a 513 area code, that is Cincinnati which is local to me. Definetly have to keep that in mind fo rfuture builds.
Later!!
Anthony
Old 04-30-2013, 03:50 PM
  #16267
EJWash1
EJWash1's Avatar
ORIGINAL: Jim Henley
EJ,
Thanks Jim,
Right now the horizontal stab platform is at +0.6 (6/10) of one degree. Even though the plan or instruction manual doesn't spell-out the required incidence, I measured the plan and there is in fact some positive incidence.
Old 04-30-2013, 10:53 PM
  #16268
WacoDream
WacoDream's Avatar
mrdhud - thanks.  I'll be at Top Gun on Saturday.  Hope to see you
Old 04-30-2013, 11:36 PM
  #16269
Stickbuilder
ORIGINAL: EJWash1
EJ,
Thanks Jim,
Some is not enough. You need about 2.5 degrees positive incidence for good flying.
Old 05-01-2013, 01:19 AM
  #16270
tmac48
tmac48's Avatar
Dash, they look really great, if I could get mine to that standard I would be moor than happy. I have sent them off an
email, the only thing that bothers me is that the decals I have are very good quality and very thin. anyway I am willing to try anything at this time.
Regards, tmac
( PS. have a bottle of decal softener on the way to try also. )
Old 05-01-2013, 01:25 AM
  #16271
tmac48
tmac48's Avatar
Dash, did they go on without any softener?
Regards, tmac
Old 05-01-2013, 03:13 AM
  #16272
Dash7ATP
Dash7ATP's Avatar
ORIGINAL: tmac48
Regards, tmac
I must admit that the vinyl is a little thicker than a water slide decal. The nice thing about the vinyl is you still apply it using a liquid to apply it which allows you to lift it if it's not exactly in the right place. You can also soften it with a little heat (actually, just warm it slightly ) and it goes around the blisters very nicely. You only need 14 sets of the darts for the blisters, and Dennis gives you about twenty just in case you mess up one or two figuring out how to apply them. I only needed one extra..... Good luck with what ever you go with.Joe
Old 05-01-2013, 07:21 AM
  #16273
EJWash1
EJWash1's Avatar
ORIGINAL: Stickbuilder
Thank you Bill. Do you know if that goes for the 1/6-scale as well? From what I can tell, the 1/5-scale is an enlargement of the 1/6-scale (which I'm building). Like I posted, stab, or wing for that matter, is not depicted nor discussed anywhere on the plan sheets or the instruction manual. Built to spec, the stab platform comes out to +0.6-degrees.
Any feedback from those that have built the 1/6-scale, either the Dave Platt or the Pica version?
Thanks.
Old 05-01-2013, 10:48 AM
  #16274
Stickbuilder
Okay, Here is the roster to date.
WACO BROTHERHOOD MEMBERSHIP:
#1 stickbuilder
#2 Hughes500
#3 Jim Henley
#4 mmattockx
#5 CTflyboy
#6 michaelj2k
#7 Ronj10
#8 gwulle
#9 jim schroer
#10 Skinny Bob
#11 Doug
#12 Pimmnz
#13 HarryJ
No. 14 Old Git
#15 ChrisMH
#16 Nerevar
#17 Ricatic
#18 Clay H.
#19 Tripp2Loo
#20 KHodges
#21 Bill Hogue (WACO One)
#22 Mangolo (Waldo)
#23 av8ter
#24 yel914 (Rick)
#25 damifino
#26 skylarkmk1
#27 Jacque
#28 Edwin
#29 AROPLANE
#30 WacoNut (Anthony)
#31 BQuartucy (Bob Q)
#32 AERORON
#33 funkymusic
#34 Live Wire (Larry)
#35 obo (Bob)
#36 Jackk36 (Jack)
#37 fatherrooster (Jim)
#38 Ilikebipes
#39 Kestrel0222
#40 CROWMAN17 (Marc)
#41 redcesar
#42 S. Christensen (Scott)
#43 Bill Deidrich
#44 Mike Barbee
#45 mrdhud (Dan Hudson)
#46 SoCalSal
#47 Todd (NightStalker)
#48 argon (Bob Gonzalez)
#49 mango 12 (Scott)
#50 skyjet 1
#51 ZIG
#52 Didg
#53 MarvinE255 (DOC)
#54 Joe Norris (Full Scale WACO Pilot)
#55 vasek
#56 SuperCub Man (Jim)
#57 Black Drape (Ron)
#58 aminiet (Angel Minet)
#59 Snowball
#60 doc zinger
#61 jagnweiner (Scott)
#62 Meesh (Bob)
#63 BigBoy99 (Bernie)
#64 stifts (Steve)
#65 RCWalker (Wallace)
#66 Mobyal
#67 lazyace
#68 bladerunner1955 (Don)
#69 trlambsr
#70 Big Bird (Ken)
#71 Tony V (Tony)
#72 red 1
#73 412t1 (Sean)
#74 Mr Lucky (Ben Warner)
#75 RICKSTUBBZ (Rick Stubblefield)
#76 ffdg (Fred)
#77 tomcraig
#78 Michou41a Michel
#79 Watzscale (Dick Watz)
#80 Devens
#81 msilvestro (Mark)
#82 Cheechukranch (Lewis)
#83 kruzin55 (Chris)
#84 lynchr (Ron)
#85 airplanegeek
#86 TexasSkyPilot
#87 Garthwood (Charles)
#88 RCBOATMANIAC (Dave)
#89 Thomas B
#90 George Werber
#91 frequent flyer (Don)
#92 adamiani Alex
#93 Kvlasblom
#94 geertdewit (Geert)
#95 Wobble Wing (Bud Halverson)
#96 Joe Gulik
#97 T.L.A.R.eng
#98 kurrikan
#99 Nathan King
#100 nine o nine (Mitch Epstein)
#101 dsquire (Don)
#102 Mr. WACO (Charlie Nelson)
#103 Ken Acosta
#104 denoferth (Dennis)
#105 germrb (Bob Germaine)
#106 J.D. Ramsay
#107 ccrebidoux (Chris)
#108 LarryN (Larry)
#109 X3heimmr (Marty Heim)
#110 Lou Melancon
#111 BEARMX (Barry Waters)
#112 Sir Crashalot (Bob J)
#113 RPSBLS (Bob)
#114 Squeakalong (No name given)
#115 Uminchu (Dave)
#116 Avaiojet (Charles)
#117 Mud Duck (Shaun)
#118 XTRA230 (Rob)
#119 3drc tim
#120 Cubman
#121 Ekim (Mike)
#122 tom czenthe (Mr. Tom)
#123 curt switzer (Mr. Curt)
#124 bbogart (Bruce)
#125 skypup50
#126 RCplanman
#127 froghair1
#128 lrayj (Lonnie)
#129 codiddley
#130 king arthur 1953 (Ron)
#131 sdstick06 (Shawn)
#132 hopkimf (Michael Hopkins)
#133 Cricklewood (Chris Kerrigan)
#134 montiu
#135 carbunkle
#136 Wolfinwisc
#137 mamoose124 (Mike)
#138 pbunster (Paul)
#139 Paul of the North (Paul)
#140 eagledancer (Todd Bixby)
#141 Cottco RC
#142 Neil K (Neil Kilchriste)
#143 Aerowoof
#144 Phlip (Phil Duncan)
#145 flyinjay (Mark)
#146 Cursor (Rick Allison)
#147 Teus
#148 Steve Percifield
#149 rootsgroup
#150 johnboy151A (John Shrick)
#151 georgewaldrop (George Waldrop)
#152 rkflyingboats (Bob)
#153 reyn3545 (Mike Reynolds)
#154 PanHeadAndy
#155 Amscat (Andy)
#156 Skipb (Skip)
#157 Dirtydingus (Jim)
#158 cdbarker (Carl Barker)
#159 TJDNC (Thomas Dugan)
#160 Gunner3 (Bob Faetsch)
#161 fishinchickens (Neil Abbot)
#162 pittsdriver (Don)
#163 rc wings (Marko)
#164 greybeardaviation
#165 tokpilot
#166 davivgeorge212 (David G)
#167 lanny haff
#168 Dick Pettit
#169 abergmann
#170 FMBB Peter Barth
#171 Redbiscuits (Gary)
#172 ross felix
#173 biplano (Oscar Aitken)
#174 RBACONS
#175 flightstick (Gary)
#176 Mark Wolf
#177 paulemv (Paul T. VanDenburgh)
#178 scubajohn
#179 jerry325i (Jerry)
#180 mogman (Dave)
#181 DRCRAIG (Craig
#182 JRM23 (John)
#183 jn4dflyer (Larry)
#184 acerc (Robert)
#185 Jstephen1h
#186 MormonMike
#187 Skillet92
#188 MinnFlyer (Mike B.)
#189 cocobear (Dave Johnson)
#190 AncientCityFlyer (Mike)
#191 Cannonball200 (Eddie)
#192 Bkyrdflyer (Jeff R)
#193 althepal88
#194 oppie
#195 kim seyler
#196 ceije
#197 Airboss 45
#198 lablover
#199 ZebraOne
#200 GEORGE QUINN (posthumous Brother)
#201 Tmac48
#202 wreck-em-rich (Richard)
#203 cherry629
#204 Errol Levin
#205 n6iap Jimm
#206 Jason Mansfield
#207 Ken Mansfield
#208 sevans16
#209 rccrasher65 George
#210 Claude McCullough (posthumous Brother)
#211 Blackwidow (Tom)
#212 Handyman220 (Paul)
#213 rone1948 (Ron Elliott)
#214 catflyer
#215 ma mulcahy (mike)
#216 wingstrut
#217 wed-subawu
#218 p40warhawk67 (Daniel)
#219 Dash7ATP (Joe)
#220 Carl Hammond (posthumous Brother)
#221 Lins
#222 RCjunky67
#223 Jaybird (Jay)
#224 peterduplessis (Peter)
#225 dadrivet
#226 Stevemyers (Steve Myers)
#227 Rainbow1
#228 jymster James
#229 VOX (Albert)
#231 BobH
#232 jhambright (JohnH)
#233 Chuck l (Chuck)
#234 lashbuick
#235 WacoDream (Mike)
#236 lovehydro
#237 DinoR
WACO Sisterhood Roster:
S-1 Janelle (Lady Stickbuilder)
S-2 Sissy Nightstalker
S-3 Barb Barbee
S-4 LadyMango (Lynda)
S-5 BUMBLE GEE BEE (Gabi)
S-6 Sue Watz
S-7 Joanie Allison (Lady Cursor)
S-8 Lady RCBOATMANIAC (Christine)
Bill, AMA 4720
WACO Brotherhood #1
Old 05-01-2013, 10:49 AM
  #16275
Stickbuilder
ORIGINAL: EJWash1
Thanks.
EJ, that seems to be pretty much universal regardless of scale size.
