Der Jager 1/3 scale
Cheers
David
good luck in your search
give balsa usa a call i am sure they will at least let you know what the cg is
Just got it back out of the store and and started to build but guess what...
Can't find the plans that the chap gave me, the top wing span is abnout 80 in.
Any ideas what size the Balsa USA one is ? need to buy some plans...
Cheers,
Chris
Cheers
David
Planning on a Quadra 42 - but recently seen a couple of builds with Zenoah 62's in ... so now I'm wondering if thats going to be enough
Chris
Cheers
Hmm might give the Quadra 42 to the wife then for her Stampe...
She was going the Zenoah 38 route - but I dont recon the Quadra will be over much for it.
Just need to save for a new engine then
BTW - the current build has a single servo for the elevators - thinking of doubling up - thoughts ?
Chris
Cheers
blue a scale copy of a full sized or your own rendition of this classic
bird.
BTW see you are from Hemet, say hi to my friend Pat Smith next time
you see him.
Nice work Jim! Looks great in blue and white for sure. I would love to build one from kit if one ever becomes available to me. They are getting as rare as hens teeth! What is your power plant and how does she handle? Mine has been completed and flown a few times and is a real pleasure to see and It handles quite nicely and is very visible with red in the paint scheme. It likes a touch of power on landings for sure as the stall can come on pretty quickly if your not paying attention! I did manage to nearly "re-kit" mine with a landing gear failure this past summer-have a look on You tube. http://youtu.be/GkwK2fU_bCY Truth be know I didn't give the lock-tite long enough to cure on the wheel collar set screw! Simplest damn things..lol. At any rate the damage was quite minimal and I was greatly relieved after a full inspection to see she will fly again another day. I had to pull the firewall and tank to de-clunk it if you know what I mean! Happy flying and safe landings all!-
Cheers
from Lazer-Works in Wichita Falls, Texas. Cowl & wheel pants from
Fiberglass Specialties, will have the landing gear cut and bent @ TNT
Landing Gears as per the drawings on the plans. Will do a built-up
rendition of the ABS turtle deck that was supplied with the kit as it
is not offered by any of the glass companies. Will probably do my
own paint scheme, as Jim says, their aren't any out there to copy
from.
Bill D.
With all of the re-issues BUSA has done, I wonder if they would consider bringing this one back? Such a cool airplane and lots of great engine choices now for this size.
being considered, couldn't say when it might happen or not.
A couple years ago I was told that Marshall White, the designer of the Der Jager
had an issue with Balsa USA over the production of the model kit and that is why it was
discontinued. However since his passing, Marshall's son, if I have heard correctly,
thinks the model is great, and being there aren't many full sized versions still
in existance, would be a flying memorial to his father and has given his blessing
to re-issue the kit if they decide to do so.
Who knows when or if it ever will appear again, but they did bring back the 1/3rd
scale Fly Baby Bipe. Now if they would only bring back the Der Jager and the
Fly Baby Monoplane.
Bill D.
I had to order a new set of plans form Balsa USA - came in record time too- all the way to the UK.
I'm hoping to get mine sorted next season but i'm saving for a new engine first, orgionally I was going to use a Quadra 42.
But advice on here seems to point to a nice zenoah 62.
Chris
the short kits that Lazer-Works is cutting and his plans are to use a DLE-50, should
have plenty of power for those that want out of sight vertical, but the plan was
designed origanly for a Quadra 35 and flew very scale with it, after all this is a
"Sport Homebuilt" not an all out areobatic purpose built plane.
And while I'm on here does anyone have a spare turtle deck they might want to
part with, not for me but the guy in Texas, he isn't a computer type, so I said I
would ask for him.......
Bill D.
Lazer-Works will spoil you, "Action Ed" is a great guy to deal with, always
has time for his customers, been dealing with him for almost 3 years now
he is my first choice when I need cutting done, he will listen to what you
have to say and if you find a way to improve one of the kits he cuts he is
always open to your suggestions, what ever you need he will do, be it, a
large or small project give him a call and discuss it with him, if he doesn't
answer immediately he may be in the middle of a set up, leave a message
or call him back later. I also find he is very competitive in his pricing.
Bill D.
Is there enough information on the BUSA plans to copy all the wing ribs and fuselage formers to scratch build? I looked at lazer-works and the short kit is only $156. I plan on ordering the plans soon, and I was just curious.
John
The short kit that is availalble from Lazer-Works was done from an exisiting kit where all of the ribs and
formers were scanned into their programing for cutting. Having owned the original kit many years ago
I think with all of the scalloped traling edges on the wings, that the price for the laser cut kit is well worth
it for the time and accuacy.
Having said that it would sure be nice if Balsa USA would decide to re-release this beauty.
Bill D.
