Reload this Page >
Der Jager 1/3 scale
Der Jager 1/3 scale
Old 09-04-2009, 10:55 PM
winged1
Default Der Jager 1/3 scale
Hellow fellow flying gents. I'm currently restoring a beautiful bipe and am without plans. The Der Jager arrived without outer wing struts and I would love to know the manufactures specs on C of G as well. Anyone have the plans pinned up somewhere!?Any direction would be greatly appreciated!
Cheers
David
Old 09-06-2009, 07:46 AM
eagledancer
Default RE: Der Jager 1/3 scale
balsa usa still sell the plans for this plane.
good luck in your search
give balsa usa a call i am sure they will at least let you know what the cg is
Old 09-24-2009, 06:04 PM
Bill Diedrich
Bill Diedrich's Avatar
Center of Balance is 5 11/16" from leading edge of top wing. Checked my plans this evening.
Old 03-29-2010, 04:27 PM
brand1068
I know this is an old post, But i bought a partbuilt Der Jager last year.
Just got it back out of the store and and started to build but guess what...
Can't find the plans that the chap gave me, the top wing span is abnout 80 in.
Any ideas what size the Balsa USA one is ? need to buy some plans...
Cheers,
Chris
Old 03-30-2010, 11:00 AM
winged1
It's likely a Balsa USA at 80" and the plan and manual are still available. I managed without them. You will be very pleased with this beaut! What are you powering it with? Kindly advise.
Cheers
David
Old 03-30-2010, 11:04 AM
brand1068
Excellent ! thanks for that i'll get one ordered from Balsa USA then.
Planning on a Quadra 42 - but recently seen a couple of builds with Zenoah 62's in ... so now I'm wondering if thats going to be enough
Chris
Old 03-30-2010, 11:20 AM
winged1
Glad I could help. The 45 will fly it but you will be far happier with the G-62. Just watch the prop/ground clearence. slight mod may be needed depending on your prop selection. A three balde would be optimum.
Cheers
Old 03-30-2010, 11:41 AM
brand1068
Ok - plans and manual - orderd from Balsa USA.
Hmm might give the Quadra 42 to the wife then for her Stampe...
She was going the Zenoah 38 route - but I dont recon the Quadra will be over much for it.
Just need to save for a new engine then
BTW - the current build has a single servo for the elevators - thinking of doubling up - thoughts ?
Chris
Old 03-30-2010, 12:02 PM
winged1
Single is fine as long as its third scale rated. Mine is riged this way and it has no difficulty when I pull the big G's!
Cheers
Old 12-14-2010, 10:25 PM
multienjim
My Feedback: (26)
multienjim's Avatar
A few pics of my der yager. It is a balsa usa kit also.happy landings all JIM.
ID:	1534357   Click image for larger version
ID:	1534358   Click image for larger version
Old 12-15-2010, 05:44 AM
Bill Diedrich
Definately a beautiful rendition of the Der Jager, is the white and
blue a scale copy of a full sized or your own rendition of this classic
bird.
BTW see you are from Hemet, say hi to my friend Pat Smith next time
you see him.
Old 12-16-2010, 06:14 PM
multienjim
My Feedback: (26)
multienjim's Avatar
It is my own design. its hard to locate any pics of real der jagers tochoose a paint job you like. I will tell pat you said hi.
Old 12-17-2010, 10:56 AM
winged1
Nice work Jim! Looks great in blue and white for sure. I would love to build one from kit if one ever becomes available to me. They are getting as rare as hens teeth! What is your power plant and how does she handle? Mine has been completed and flown a few times and is a real pleasure to see and It handles quite nicely and is very visible with red in the paint scheme. It likes a touch of power on landings for sure as the stall can come on pretty quickly if your not paying attention! I did manage to nearly "re-kit" mine with a landing gear failure this past summer-have a look on You tube. http://youtu.be/GkwK2fU_bCY  Truth be know I didn't give the lock-tite long enough to cure on the wheel collar set screw! Simplest damn things..lol. At any rate the damage was quite minimal and I was greatly relieved after a full inspection to see she will fly again another day. I had to pull the firewall and tank to de-clunk it if you know what I mean! Happy flying and safe landings all!-
Cheers
Old 12-17-2010, 12:22 PM
Bill Diedrich
Getting ready to build one after the new year, purchasing the short kit
from Lazer-Works in Wichita Falls, Texas. Cowl & wheel pants from
Fiberglass Specialties, will have the landing gear cut and bent @ TNT
Landing Gears as per the drawings on the plans. Will do a built-up
rendition of the ABS turtle deck that was supplied with the kit as it
is not offered by any of the glass companies. Will probably do my
own paint scheme, as Jim says, their aren't any out there to copy
from.
Bill D.
Old 12-17-2010, 02:43 PM
vertical grimmace
vertical grimmace's Avatar
With all of the re-issues BUSA has done, I wonder if they would consider bringing this one back? Such a cool airplane and lots of great engine choices now for this size.
Old 12-17-2010, 03:42 PM
winged1
Sounds great Bill-post some pictures when you can if you please. I was actualy thinking out loud about exactly what virtical grimmace just wrote! How does that happen!!?? I had looked far and wide for info as well as a paint scheme, to very little avail. I do have a few photo's of the real deal and some great models as well-I'll post them when I have a few minutes.
ID:	1535381   Click image for larger version
ID:	1535382   Click image for larger version
ID:	1535383   Click image for larger version
ID:	1535384   Click image for larger version
ID:	1535385   Click image for larger version
ID:	1535386   Click image for larger version
Old 12-19-2010, 05:07 AM
Bill Diedrich
ORIGINAL: vertical grimmace
I spoke with someone at Balsa USA several months ago and they said it was
being considered, couldn't say when it might happen or not.
A couple years ago I was told that Marshall White, the designer of the Der Jager
had an issue with Balsa USA over the production of the model kit and that is why it was
discontinued. However since his passing, Marshall's son, if I have heard correctly,
thinks the model is great, and being there aren't many full sized versions still
in existance, would be a flying memorial to his father and has given his blessing
to re-issue the kit if they decide to do so.
Who knows when or if it ever will appear again, but they did bring back the 1/3rd
scale Fly Baby Bipe. Now if they would only bring back the Der Jager and the
Fly Baby Monoplane.
Bill D.
Old 12-19-2010, 09:13 AM
brand1068
I've got a part build of the BUSA Der Jager.
I had to order a new set of plans form Balsa USA - came in record time too- all the way to the UK.
I'm hoping to get mine sorted next season but i'm saving for a new engine first, orgionally I was going to use a Quadra 42.
But advice on here seems to point to a nice zenoah 62.
Chris
Old 12-20-2010, 07:41 AM
Gizmo-RCU
My Feedback: (27)
A neighbor had a fully scale that was a really nice plane. He managed to kill himself with it as he was really over his head, tip stall on a pull out at low level. Snapped and went in straight down.
Old 12-22-2010, 01:42 PM
Bill Diedrich
Spoke with a gentleman up around Wichita Falls, Tx. that is building one from
the short kits that Lazer-Works is cutting and his plans are to use a DLE-50, should
have plenty of power for those that want out of sight vertical, but the plan was
designed origanly for a Quadra 35 and flew very scale with it, after all this is a
"Sport Homebuilt" not an all out areobatic purpose built plane.
And while I'm on here does anyone have a spare turtle deck they might want to
part with, not for me but the guy in Texas, he isn't a computer type, so I said I
would ask for him.......
Bill D.
Old 12-24-2010, 06:05 AM
JNorton
JNorton's Avatar
Bill,
A little off the subject but how have you found Lazer-Works quality? They have many offerings at good prices. I'd just like a little reassurance before I order.
John
Old 12-24-2010, 06:24 AM
Bill Diedrich
As I just wrote in another post:
Lazer-Works will spoil you, "Action Ed" is a great guy to deal with, always
has time for his customers, been dealing with him for almost 3 years now
he is my first choice when I need cutting done, he will listen to what you
have to say and if you find a way to improve one of the kits he cuts he is
always open to your suggestions, what ever you need he will do, be it, a
large or small project give him a call and discuss it with him, if he doesn't
answer immediately he may be in the middle of a set up, leave a message
or call him back later. I also find he is very competitive in his pricing.
Bill D.
Old 01-08-2011, 07:09 PM
johnboy151a
My Feedback: (68)
johnboy151a's Avatar
Is there enough information on the BUSA plans to copy all the wing ribs and fuselage formers to scratch build? I looked at lazer-works and the short kit is only $156. I plan on ordering the plans soon, and I was just curious.
John
Old 01-08-2011, 11:17 PM
yyk1966
A short kit is available here http://lazer-works.com/misc.html
Old 01-09-2011, 05:01 AM
Bill Diedrich
ORIGINAL: johnboy151a
John
If your asking if the plans have all of the ribs and fuselage formers on the plans, the answer is they do not.
The short kit that is availalble from Lazer-Works was done from an exisiting kit where all of the ribs and
formers were scanned into their programing for cutting. Having owned the original kit many years ago
I think with all of the scalloped traling edges on the wings, that the price for the laser cut kit is well worth
it for the time and accuacy.
Having said that it would sure be nice if Balsa USA would decide to re-release this beauty.
Bill D.
