Reload this Page >
Turbine Enforcer
Turbine Enforcer
Old 12-30-2004, 12:14 PM
joeflyer
My Feedback: (48)
Default Turbine Enforcer
Due to popular request (Bob) I'm posting a couple pictures of my winter project. I needed to find a home for my recently acquired Ram 500. After looking into some of the various kits available I decided to build another Enforcer. My Byroblaster Enforcer is a blast to fly, and with close to 100 flights now I'm very comfortable with it's flight characteristics. So this seemed like a good choice for my first turbine. Also I just happened to have a spare kit sitting in the basement.
I'm almost done framing it up and expect to have it ready to fly in the spring. It will have many of the same mods I made to my DF version. The most noticeable differences are the wider fuse, to accommodate a 50 oz. Dubro tank on the CG and the aluminum motor mount. The wing will be fully sheeted once everything is in place. A removable cover will go over the rear fuse for easy access to all of the equipment.
Joe
ID:	208348   Click image for larger version
ID:	208349   Click image for larger version
Old 12-30-2004, 03:51 PM
CFII1974
CFII1974's Avatar
Default RE: Turbine Enforcer
Joe,
That should be a lot of fun. You'll have to post a few pic's when it is done.
Dave
Old 12-30-2004, 06:08 PM
Crazy4Flight
My Feedback: (540)
Crazy4Flight's Avatar
OK so I twisted Joe's arm a little....
First twist was to get Joe to buy a turbine since he has been wearing a RAM hat and T-shirt for some time now.
Second was to get a turbine an airframe to reside in.
Bob
Old 12-30-2004, 07:28 PM
b17flyer
My Feedback: (32)
There was a converstion here in Colo? that wasn't completed about 2 yrs ago thet showed up at a jet rally. I too had a byro-enforcer and can't help but really enjoy the way it flys. Hope the turbine version is similar. Will be looking forawar to this thread.
Most of my d/f stuff is on the way out. But the byro-enforcer could always come back
Of course not if i can aquire another turbine.
good luck
Old 12-30-2004, 07:56 PM
klave
My Feedback: (17)
Hey joe the TURBO TAZ looks great. I can't wait to see it fly, what kind of landing gear are you
going to use, a good size air brake would be nice so you can leave some power on at final apr.
I'm sure it will be built perfect and clean just like the rest of your jets.
chris
Old 12-31-2004, 12:42 AM
joeflyer
My Feedback: (48)
Hi Chris,
Good to hear from you. Have you gotten your Ram 1000 back from RTI yet? I just sent my ECU in to Bob Price to be updated to the latest level. Should have it back in a day or two.
The turbo will have spring air retracts, 3/16" wire struts and BVM wheels/brakes. I was planning on kicking the rudders out board as a speed brake. I'm now realizing that will tie up too many channels and mixes on my 8103. Seems like a good excuse to upgrade to a 9303. Any opinion as to which would be more effective: outboard rudders or speed brake on the bottom?
Joe
Old 12-31-2004, 09:57 AM
Crazy4Flight
My Feedback: (540)
Joe,
I would go with the speed brake on the bottom:
1) more effective area available for drag, as well as reducing the lift generated.
2) you still have rudder control for crosswind landings.
Bob
Old 12-31-2004, 03:15 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Very nice Joe. Can you post a closed up picture of the engine mount from above?
Thanks.
CARS II
Old 12-31-2004, 03:26 PM
CARS II
My Feedback: (7)
CARS II's Avatar
And Joe, thank you for all the imput for my project.
CARS II
Old 12-31-2004, 05:25 PM
klave
My Feedback: (17)
Hey joe I like to have alot of rudder control on final, because I try to leave my right stick alone
when I feel I have established a good flair, Im for the air brake myself. I extended mine, I think mabe to mutch but it sure slows it down when I need it, I was trying to accommodate
are field. I got my ram back from RTI carlos says it is a true 28 lb 1000 now, I also have a speed limitter now so I can contain myself from killing the bird. I think a F-15 style air brake
would be neat for your jet, thats what I like about the hot spot.
chris
Old 01-01-2005, 12:41 AM
Mokulele
My Feedback: (9)
CARS II,
Here's a couple of shots of my Enforcer's engine mount.
Larry
ID:	209075   Click image for larger version
Old 01-01-2005, 01:08 AM
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you Larry, very nice.
I'm sending you a PM of my project, I'm thinking if I should build me another one but turbine this time. mmmmmmmmmmmmmmmmmmm.............
CARS II
Old 01-01-2005, 03:56 PM
joeflyer
My Feedback: (48)
Bob/Chris,
OK, you convinced me. I'll put a speed brake on the bottom. It would have been easier if I made provisions for one earlier. I'll figure something out.
Exactly where are yours located on the Rookie and Top Cat? I'm thinking that it belongs 1-2 inches in front of the CG.
Anyone have a recommendation?
Joe
Old 01-01-2005, 04:04 PM
joeflyer
My Feedback: (48)
Cars,
Here's a couple of shots of my engine mount. It looks a lot like Larry's because I got the idea from him. Mine is made out of .064 aluminum. Thinner guage would work, but that is what I was able to find. I'll probably put a few holes in it to lighten it, but I'll wait to see how the finished plane balances out.
ID:	209335   Click image for larger version
Old 01-01-2005, 06:29 PM
Mokulele
My Feedback: (9)
Joe,
Here's my speed brake layout. It works well and it pitches the nose up a bit when deployed. The well area also gives you access to things such as the brake valve and fuel tank. The well cover just pops in and out for service.
Larry
ID:	209371   Click image for larger version
ID:	209372   Click image for larger version
Old 01-01-2005, 09:04 PM
Crazy4Flight
My Feedback: (540)
JOE
THE SPEED BRAKE on my ROO bigger than plans 2.75" x 11.75"
LE location is about 10.5" ahead of CG (CG is about the LE of Robart retracts)
(yes gear are offset since mounts were glued in wrong: one off by 10mm )
actuation by JR DS-8411 servo
Bob
just thought if you get the 9303 Tx you could add canards tooo!!
Old 01-02-2005, 01:43 AM
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you Joe, you know I end up with the same engine angle purely by chance and wow!!! it flys perfect no need to change the engine truss angle.
CARS II
Old 01-10-2005, 05:50 PM
cheche106
Hi all,
This is a good thread. I built one of these last summer, with a Moores Super 66. It is super fast and stable.
A real blast to fly.
Thanks, Chet Trott
Bermuda.
ID:	213272   Click image for larger version
ID:	213273   Click image for larger version
ID:	213274   Click image for larger version
ID:	213275   Click image for larger version
Old 01-10-2005, 09:10 PM
b17flyer
My Feedback: (32)
[X(]
Awsome Kit Bash........I LIKEY
Old 01-10-2005, 09:41 PM
joeflyer
My Feedback: (48)
Chet,
Very cool! Is that a modified Enforcer? Kind of looks like a Reaper.
Is that your gas tank on the bottom?
Joe
Old 01-10-2005, 11:17 PM
cheche106
Hi Joe,
This is a Balsa USA Enforcer Kit. The tank on the bottom was for extra fuel.
I don't use it any more. I modified the kit to use a larger tank inside. This motor needs fuel.
The jet weighs 16lbs, and the motor has 22lbs of thrust. I have Dave Brown Carbon fiber ribbon
on all spars, and trailling edge. She turns very tight!
I got the idea to build this kit from you Joe, as I had seen your ByroBlaster on RCU early last Year.
Chet.
ID:	213439   Click image for larger version
ID:	213440   Click image for larger version
ID:	213441   Click image for larger version
ID:	213442   Click image for larger version
Old 01-11-2005, 01:08 AM
Mokulele
My Feedback: (9)
Great looking Enforcer Chet. The Enforcer has got to be the most versatile jet there is. I certainly enjoyed flying mine. It flew first with my Schreckling FD 3/64. Great match except if the grass was too long it would not take off. I then installed a RAM 750 but I had to kill the engine to land it. Too much idle thrust and it would not land. I finally installed a RAM 500. It flew with it till I retired the Enforcer. It weighed 12.5 lbs dry with the RAM 500.
Larry
Old 01-11-2005, 08:24 AM
erbroens
erbroens's Avatar
[sm=thumbup.gif] best looking enforcer ever, and it should fly
better with that canard too... nice concept!
Enrique
Old 01-11-2005, 09:46 PM
joeflyer
My Feedback: (48)
Chet,
You did a great job. I agree with Larry, the Enforcer is a very versatile air frame and seems to be a favorite among kit bashers. It has been quite successful as a pusher prop, ducted fan, and turbine powered plane.
I assume that you fully sheeted the wings. Are they glassed or monokoted?
I haven't made much progress on mine the last couple of weeks. I'll post a few more pictures after I make some progress.
Joe
Old 01-12-2005, 01:11 PM
L Turner
Hey Chet,
Nicely bashed Enforcer! Where, by the way, do you guys fly in Bermuda? Nice old tarmac! Don't suppose you could host some visiting pilots from up north (Wisconsin) could you?
