Ultimate CX2 Mod Guide
Hey all! I've been seeing a lot of mod questions in the forums so I thought I'd prepare this guide. Ahem!! AHEM!!!!!!!! AHEM!!!!!!!!!!!!!!!!!!!!! Ok ready! Here goes:
Structural
----Stersman's Tail Boom----
-Lowers Weight
-Reduces Resistance
-Improves Wind Handling
PM: Stersman
E-Mail: [email protected]
URL: http://www.boomtownhobbies.com
----Stersman's Skids----
-Improves Durability
-Absorbs Impact
-Prevents Bouncing
PM: Stersman
----Assorted E-Flight Bodies-----
-Improves Look
URL: http://www.e-fliterc.com/
----Dimension Engineering EasyLights-----
-Makes a Great Searchlight
-Improves Looks
-Fly in The Dark
EasyLights: ~$15.00
URL: http://www.dimensionengineering.com/EasyLights.htm
----LiGlow V2 Light Kit-----
-Realistic Strobing Navigation Lights
-Improves Looks
-Fly in The Dark
-LiPO Low Voltage Alarm
LiGlow V2 (Partially Assembled): ~$40.00
LiGlow V2 (Fully Assembled): ~$50.00
URL: http://www.tjtrc.com/LiPoV2.html
Motor
----Dynam Vortex Motors----
-Increases Power
-Decreases Noise
-Decreases Temperature
-Decreases Battery Drain
-Cost Less
-May Require Break in
VTX-018 (Both Motors): ~$8.00
URL: http://www.bphobbies.com/view.asp?id=A1972394
URL: http://www.slickzero.com/Merchant2/m..._Code=VTXParts
----Xtreme Production's E-Sky Lama Bearing Motors----
-Increases Power with Silver Brushes (Optional)
-Decreases Noise
-Last Far Longer Than Stock or Vortex
-Cost Considerably More
-User Replacable / Exchangable Brushes
-Silver Brushes Option for 30% More Torque
ESL-001 (Left Motor): ~$16.00
ESL-002 (Right Motor): ~$16.00
URL: http://www.miracle-mart.com/store/in...edc33aa40737bd
----Main Motor Heatsink----
-Improves Looks
-Lowers Motor Temperature
-Lengthens Motor Life
-Extra Weight
EFLH1208: ~$4.00
Radio
----Spektrum DX7 Transmitter----
-Control 4-in-1's 6th Channel
-Substantially More Range
-Programmable Mixing
-Expensive
SPM2712-250: ~$350.00
URL: http://www.horizonhobby.com/Products...ProdID=SPM2710
Mechanical
----Micro Heli Aluminum Swahplate----
-Improved Looks
-More Durability
-Extra Weight
MH-CX012: ~$27.00
URL: http://www.microheli.com/mhshop/inde...0be8692c9ed46f
----Micro Heli Aluminum Lower Head----
-Improved Looks
-More Durability
-Extra Weight
MH-CX002LHB: ~$25.00
----Micro Heli Aluminum Upper Head----
-Improved Looks
-More Durability
-Extra Weight
MH-CX065: ~$20.00
----Micro Heli Aluminum Blade Grips----
-Looks Awesome!!
-Extra Weight
-Fly Like Crap Unless Properly Modified
MH-CX002BG1 (Lower): ~$30.00
MH-CX002BG2 (Upper): ~$30.00
----Micro Heli Aluminum Bearing Housing----
-Improved Looks
-More Durability
-Extra Weight
MH-CX027: ~$6.00
----E-Flight Aluminum Upgrades----
-Same as MicroHeli
----Dynam Vortex Shafts-----
-Decreases Blade Clacks
-Cost Less
VTX-003 (Inner): ~$5.50
VTX-004 (Outer): ~$3.50
----Dynam Vortex Flybar----
-Increases Power
-Decreases Noise
-Improves Response
-Costs Less
-Adjustable Weights
VTX-002: ~$3.00
----Hirobo Lama XRB Flybar Paddles----
*Remove Paddles from Flybar. Add Them to Stock Flybar*
-Improved Looks
-Better Responsivness
-Improved Stability
0301038: ~$9.00
URL: http://www.helihobby.com/html/LAMAXRB1.html
Power
----Mega Power 15C 850MaH Blade CX 2-Cell 7.4v LiPO----
*Recommended Battery*
-Larger Capacity
-Fits Stock Battery Mount
-Fits Stock Charger
-Costs Less Than Stock
MP850152STK (Fits Stock Charger): ~$17.00
MP850152 (Won't Fit Stock Charger): ~$17.00
URL: http://www.helidirect.com/product_in...oducts_id=2108
----DN Power 10C 900MaH Blade CX 2-Cell 7.4v LiPO----
-Larger Capacity
-May or May Not Fit Stock Charger
-Costs Less Than Mega Power
DNP10C9002S: ~$16.00
URL: http://www.readyheli.com/DN_Power_2S...np10c9002s.htm
----Any 3-Cell 11.1v LiPO----
-Larger Capacity
-Substantially More Power
-Won't Fit Stock Battery Mount
-May Fit Stock Charger
-Costs More
-Decreases Motor Life
-May or May Not Smoke 4-in-1
-Motor Heatsink Necessary
----FMA Direct CellPro 4S Balance Charger----
-Safely Charges Batteries in 50 min vs 2 hours
-Can Charge Pack Immediatly After Discharge (No cooling needed)
-Can Restore Overdischarged Packs
-Idiot Proof Automatic Charging Method
-Requires E-Flight Node Adaptor or Battery Pack Balance Node Change
LIPOCH4S03: ~60.00
LIPOCH4S03-A123 (A123 Compatible): ~65.00
URL: http://www.fmadirect.com/
Authors
-NeilT6
Special Thanks
-makatron
-bulls
-bigbore
-heyok
The Ultimate E-Flight Blade CX2 Mod Guide (Version 1.8)
Structural
-Lowers Weight
-Reduces Resistance
PM: Stersman
-Absorbs Impact
-Prevents Bouncing
PM: Stersman
-Improves Look
-Improves Looks
-Fly in The Dark
EasyLights: ~$15.00
-Improves Looks
-Fly in The Dark
Motor
-Increases Power
-Decreases Noise
-Cost Less
-Decreases Noise
-Improves Looks
-Extra Weight
EFLH1208: ~$4.00
Radio
-Expensive
Mechanical
-Improved Looks
-More Durability
-Extra Weight
MH-CX012: ~$27.00
-Improved Looks
-More Durability
-Extra Weight
-Improved Looks
-More Durability
-Extra Weight
MH-CX065: ~$20.00
-Looks Awesome!!
-Extra Weight
-Improved Looks
-More Durability
-Extra Weight
MH-CX027: ~$6.00
-Same as MicroHeli
-Cost Less
-Increases Power
-Decreases Noise
-Improves Response
-Costs Less
-Adjustable Weights
VTX-002: ~$3.00
-Improved Looks
-Improved Stability
0301038: ~$9.00
Power
-Larger Capacity
-Fits Stock Charger
-Larger Capacity
-Larger Capacity
-Costs More
LIPOCH4S03: ~60.00
***Note that This Guide is Frequently Updated***
Authors
-NeilT6
Special Thanks
-makatron
-bulls
-bigbore
-heyok
FL
RE: Ultimate CX2 Mod Guide
Neil, here is a 900 mAh LiPo for $16 DN brand. I don't know how good they are but IIRC there is plenty of info if a search is done.
Lon
Lon
Awesome! thanx for the tip, I was just about to order a Mega Power, but this one looks better!
*Guide Updated*
*New Version 1.2*
OH
Does anyone have any pointers on how to the setup the CX with DX7. I would imagine you would need the AR6100 receiver instead of the AR7000. Also, would the receiver from the CX2 work with the DX7 or is it complete different?
ON, CANADA
Would a three cell battery not fry the 4-1 and make short work of the motors as well??
I'm tempted to try but not to fussy on the idea of burning up a 4 in 1.
The reciever in the CX2's 4-in-1 is an AR6100 with slightly altered servo pins (A few connect to the mixer board). If you want to use the DX7 there was a thread listing all of the variables that needed to be entered. Other than that, a CX2's 4-in-1 would be all you need!
ORIGINAL: pstreck
Someone on these forums runs 3 cells all the time and doesn't have any problems. He says he's researched the 4-in-1 and found it rated to handle 3 cell packs. My theory is that E-Flight uses the same ESCs in all it's products. Anyway it would definatly shorten the motors life, but at $8 for a vortex set. well....
ORIGINAL: p01rogue
GA
Well, I posted this in the previous thread, but it was overlooked I supposed.
Buyer / User beware on the 11.1v cells on a CX2.
I have seen a 4-n-1 completely fried (smoking) through use of the 3 cell packs.
In both cases, the heli would fly like a monster for about 2 minutes (even under normal power levels, I'm not saying it was being flown hard) and then the 4-n-1 just smoked out, wrecking the heli in mid-air.
Yours may or may not do it. I don't know, and I really don't care enough to test it on MY personal 60$ 4-n-1.
Someone on the boards said he had good luck with it, my friend did not, it seems to be a risk you have to take on a case by case basis, I guess.
Hmmm..... Interesting. Perhaps some of the older 4-in-1 units used lower voltage ESCs. I'm not sure, in that case it seems to be some 4-in-1s are 11.1v certified and some are not. Are you sure he wasn't flying a CX's 4-in-1?
Either way in light of this new info I'm upgrading my guide and am going to allocate the $70 I could spend on a new 4-in-1 for trying a 3 cell pack on a CellPro 4S LiPO Charger.
GA
Older units?
The CX2 is not even 2 months old, I'm not sure how much "older" or how many newer version 4-n-1's could possibly be released yet.
Also, a CX 4-n-1 will not operate a CX2, the 2 runs on the spektrum radio. He would have had to swap his whole setup, and I know he is using stock equipment.
I'm not saying don't do it - I'm just saying that there are risks that may be associated, as with any modification.
BTW - Good guide so far!
BC, CANADA
Hey neilt6,
Any chance of adding part numbers to your list? That would sure help someone like me avoid ordering the wrong part.
Awesome work!
Cheers,
Al
Awesome work!
Cheers,
Al
Thanx!
Exactly. I was wondering if he had been running a CX's 4-in-1 so that he could use some expensive FM radio he might have had.
ORIGINAL: bzinfinity
Older units?
Older units?
Sure! I'll add them tonight along with approximate prices!
ORIGINAL: heyok
Hey neilt6,
Awesome work!
Cheers,
Al
Hey neilt6,
Awesome work!
Cheers,
Al
GA
Any info on 4-in-1 interchangability for the CX? I know it won't switch with the CX2 because of the Spektrum thing but the Vortex is susposed to work (I think)....are there any others that will/might work? Last time I saw a vortex 4-in-1 it was like $35.
Ya, I've heard the vortex units work well in the CX's. As for the CX2, you could stick it's 4-in-1 in a CX providing you had a Spektrum transmitter, either the stock one or the DX7.
neilt6,
I run a 3 cell lipo in my CX and CX2 all the time.
The only time I burned a 4in1 is when I decided to see just how much it could take so, I ran 2 batts. back to back......it smoked about half way into the second pack.
Oddly....the CX seems to run better with a 3 cell. It hasn't "glitched" but once or twice and the tail drift isn't as bad either.
The CX2 is just flat out awesome with a 3 cell. No great "improvements" other than power and flight time.
I can say, it's been about a month or more now since I started using the 3 cell lipo in these and I haven't had any trouble other than the one time.....and seriously doubt that would have happened if I hadn't pushed it.
I see... Unless some came from E-Flight weak... I dunno I'd really like to try that someday though. Any chance you could post a video?
ON, CANADA
Anybody have a donor 4-1 for a cx experiment?
I'll hook it up to my cx and fly the hell out of it on video with a fresh 3 cell and we'll see what happens.
I'll go through as many packs as I have to in order to see if the 4-1 will hold up and if so what will the lifespan of the motors be.
I'll then post video and results.
Or could somebody else please do this?
I'd like to know!
I'd like to know!
Well, like I said..... I run a 3 cell lipo down completely (well, I don't destroy the thing) from a fresh charge and I haven't had any problems with that. (yet) I've been running it for a while now. I only lost a 4in1 when I tried to run 2 fully charged packs back to back.
My motors are fine. My 4in1 in the CX1 is fine. I have no plans to use a 2 cell again. If I can find time (and help) I'll make a video sometime.
It sounds like it may be a good idea to open up your 4-in-1 to dissipate heat if you're going to use a 3 cell. At least if you want to run multiple packs back to back.
BC, CANADA
How does the length of your flight time with a three cell pack compared to a two cell pack?
I would expect that you could stay in the air a little longer with three cells. Is that what you found?
Al
Al
