E motor mounting dims
Hi All,
I was wondering, with all the outrunners around, how close are they to the same distance from back of mount (rear mounting) to back of spinner backplate (1)? And is there a standard bolt pattern for these rear mounts (3)?
Pletty
Rimfire
Axi(s)
Hacker
Hyperion
Eflight
Cyclone
anymore I'm missing?
After I drew the motor, what about the same for the front (2)?
Pletty
Rimfire
Axi(s)
Hacker
Hyperion
Eflight
Cyclone
IN
RE: E motor dims
Jason the AXI/F3A
back of motor to back of spinner backplate is 71 MM
spinner back plate to front of motor and this tapers so closest to prop shaft is 9mm and 15 mm is the outside of case.
the only demension different on the AXI 5320/28 would be the lenght and it is 61 mm
Steve Maxwell
Steve Maxwell
RE: E motor dims
Jason,
Plett Extra 30 Evo that dim is 67mm
Link to installation drawing on Plett website: http://www.plettenberg-motoren.com/U...0evo/Masse.htm
Malcolm
Malcolm
RE: E motor dims
The E-flite Power 160 is 72mm from back of mount to the front of the hub and 9mm from front of hub to motor. This is when mounted at the rear with front prop hub per your drawing.
Per the spec:
Weight: 650g (23.0oz)
Overall Diameter: 63mm (2.50 in)
Shaft Diameter: 8mm (.30 in)
Overall Length: 64mm (2.50 in)
Per the spec:
