RE: New SV Gassers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: New SV Gassers
Page: <<   < prev  24 25 26 [27] 28 29 30 31 32 33   next >   >>
Login
RE: New SV Gassers - 4/18/2008 2:48:18 PM
blw
Status: offline
Sean has a point, and let's not get into a situation where the thread is hijacked to another brand. I know the XYZ talk is important too, but....well, you know.
_____________________________
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to jstanton)
       Post #: 651
RE: New SV Gassers - 4/24/2008 10:41:36 PM
ozzmanace
Status: offline
what is the reed assembly? i have run about three tanks thru mine but it doesn't seem to be running right. could you explain about the reed.
(in reply to blw)
       Post #: 652
RE: New SV Gassers - 5/1/2008 12:50:43 AM
ozzmanace
Status: offline
wow, either the moderator put a stop on this thread or nobody knows what a reed assem. is. it's been over a week since i posted the last thread. what's up guys.
(in reply to ozzmanace)
       Post #: 653
RE: New SV Gassers - 5/1/2008 2:07:56 AM
freeonthree
Status: offline
They are little valves (flaps) between the carb and the crankcase. They allow fuel in, but don't allow crankcase pressure to enter the carb as the piston is going down.
Click to see fullsize image.
Click for fullsize
< Message edited by freeonthree -- 5/1/2008 2:36:57 AM >
I dont crash, I just land hard
       Post #: 654
RE: New SV Gassers - 5/1/2008 2:38:44 AM
freeonthree
Status: offline
There ya go, I added a picture of a reed assy to my last post for you.
(in reply to freeonthree)
       Post #: 655
RE: New SV Gassers - 5/1/2008 2:39:48 AM
ozzmanace
Status: offline
thanks. i guess that's why the other carbs didn't work.
       Post #: 656
RE: New SV Gassers - 5/1/2008 2:47:24 AM
freeonthree
Status: offline
Remove the carb, then the reed assembly (noting it's position), and flip it over and look at the reeds. My engine was hard to start and would only idle. It would die if I gave it any throttle. Then we found the broken reed. Note which gasket goes where.
       Post #: 657
RE: New SV Gassers - 5/1/2008 2:52:51 AM
ozzmanace
Status: offline
freeonthree, i just test flighted a ultimate bip. i have to say i'm hooked. i've tested everything else. turbines, electrics, 540-trainers. that was the most fun i've had yet. right before i told you this i ordered a 120 ultimate for myself. i'll put the infamouse 26cc motor on it. the one i test flew had the same motor on it. it wasn't running good. i mentioned some of the pointers i got from this thread and the sob ran great. thanks all!!
       Post #: 658
RE: New SV Gassers - 5/1/2008 10:18:14 AM
sean sutherland
Status: offline
Another happy owner good to hear these little engines are finally being accepted, i know mine has accepted me !
TMPro World Wide
       Post #: 659
RE: New SV Gassers - 5/1/2008 2:34:41 PM
rfmullig
Status: offline
Which Ultimate Bipe did you get? What company?
R
       Post #: 660
RE: New SV Gassers - 5/1/2008 3:28:10 PM
freeonthree
Status: offline
These little 26's are the ultimate little engine's in my opinion. I don't think I even need more than my one gasser now. I never get tired of flyin my Stearman with the SV26.
(in reply to sean sutherland)
       Post #: 661
RE: New SV Gassers - 5/1/2008 11:49:01 PM
ozzmanace
Status: offline
it's the nitro models version
       Post #: 662
RE: New SV Gassers - 5/1/2008 11:52:00 PM
ozzmanace
Status: offline
i also have one in an balsa usa neuport 17. but it's still in the works
       Post #: 663
RE: New SV Gassers - 5/2/2008 12:04:16 AM
freeonthree
Status: offline
No, it a Great Plane, and it's about 1/4 scale roughly, they don't tell ya...
       Post #: 664
RE: New SV Gassers - 5/7/2008 12:36:22 AM
ozzmanace
Status: offline
well whoever will take credit, it looks awesome. the one i flew had a 16/8 prop. it seemed to need alittle more prop. but i dont know about an 18/6 like the add says. any thoughts?
       Post #: 665
RE: New SV Gassers - 5/7/2008 2:20:56 AM
jstanton
Status: offline
I use a APC 17x8 and it will take e little larger prop so a 18x6 should work fine.
Jim Stanton
Millington, TN 38053
       Post #: 666
