Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Q-40 Racing
Reload this Page >
Build a Miss Ashley - Revisited
Q-40 Racing Discuss AMA 422 and any other variants of Quarter 40 racing
Old 02-26-2018, 05:11 PM
  #126
sahartman21
Default Build a Miss Ashley - Revisited
The gear length should be between 1 3/4" to 2 1/4" (to the axel). Start at 2 1/4" and verify that there is approximately 1/2" prop clearance when the wing is at zero incidence.
On the second model the wheels did not have bearings. The axels were moved forward and the gear were shortened to reduce nose over during a power push. Full up elevator was required during this style of launch.
ID:	2256282   Click image for larger version
Old 02-27-2018, 09:55 AM
  #127
sahartman21
I added some tail weight to balance the model at 3 7/8" back from the front of the wing saddle.
The tape was later removed and I plan to use about 0.35 ounces of lead-epoxy mix (the weight of the lead tape used) instead of the tape. This will be installed at the rear of the model inside the fuselage.
ID:	2256356   Click image for larger version
ID:	2256357   Click image for larger version
Old 03-03-2018, 11:54 AM
  #128
sahartman21
The first flights on the Miss Ashley were uneventful. The model needed some aileron trim and some down trim to fly to my satisfaction. I also added some tail weight to increase the elevator sensitivity and quickly turn back on #1 pylon. In my opinion this version of the model, standard long nose, tracked better than the one that I shortened the nose in the earlier thread.
On race day the model flew better than I did and my first couple of races were flown very wide around #1 pylon. An adjustment was made and during the next race the course was better around #1 but I had a midair between #2 and #3 pylon. We must have just barely touched the models as I didn't realize there was a midair until I inspected my model after the race. I was missing half of the horizontal stabilizer and therefore the backup model was brought out.
Both models were fast as any that I raced. Unfortunately my flying skills were not quite up-to-par but I managed to get a 1:10 for an 11 lap race. The good thing is that I managed to finish the Phoenix QM40 Classic and bring home both of my models.
ID:	2256709   Click image for larger version
Old 03-03-2018, 12:04 PM
  #129
sahartman21
I've continued on my other Miss Ashley. The cutout template was taped on and I used a model knife to mark the location of the cuts.
The template is a big success and it saved me significant time on cutting out the hole. Below are the pictures:
ID:	2256711   Click image for larger version
ID:	2256712   Click image for larger version
ID:	2256713   Click image for larger version
ID:	2256714   Click image for larger version
ID:	2256715   Click image for larger version
Old 03-08-2018, 05:51 PM
  #130
sahartman21
Below are links to the carbon fiber products used in the model:
7 and 14 thousandths carbon fiber laminates:
http://www.cstsales.com/carbon_laminates_48.html
Carbon Fiber Tow (12K)
http://www.cstsales.com/carbon_tow.html
This site provides tanks and motor mounts
http://www.darrolcady.com/Jett_Produ...t_products.htm
Old 03-11-2018, 02:44 PM
  #131
sahartman21
I've been continuing on the second model.
Below are some pictures showing progress on the tail surfaces.
ID:	2258839   Click image for larger version
ID:	2258840   Click image for larger version
ID:	2258841   Click image for larger version
Old 03-18-2018, 03:53 PM
  #132
sahartman21
This evening the horizontal stabilizer was attached to the fuselage.
Old 05-11-2019, 09:46 PM
  #133
fly4food18
My Feedback: (15)
Great builds. Thanks for posting.
Now I want one to sport fly.
Brian
Old 05-12-2019, 06:12 PM
  #134
sahartman21
Brian
Here is a sport or Warbird Class version of the model:
https://www.theworldmodels.com/store...ctric-Retracts
Old 05-12-2019, 09:02 PM
  #135
fly4food18
My Feedback: (15)
That is a nice looking plane. But I still like the kit built stuff better.
Maybe be I am just old school.
Old 10-26-2022, 09:09 PM
  #136
Kevin Matney
Kevin Matney's Avatar
Default can i get a copy of your mold to mark it in the mold
Originally Posted by sahartman21
For this next group of 4 Miss Ashley's a jig was made for the tail alignment.
  • Some plastic wrap was placed over an earlier model's tail.
  • Multiple layers of fiberglass cloth and epoxy resin were applied.
  • After the resin dried the jig was trimmed as desired.
Old 05-06-2023, 05:25 PM
  #137
Kevin Matney
During the Ashley MM build thread the fuselage nose cone was identified as having some down thrust. This is also seen with the pictures here.
The nose cone measured about 2 to 2 1/2 degrees of down thrust compared to the wing.
I reduced the down thrust by shaping the nose cone with a Dremel tool. I marked a 1/32" cut on the top of the nose cone and used the tools to reduce the down thrust. It now has a small amount of down thrust, possibly 1 degree.
This process took about 15 minutes to accomplish and was not difficult to address.
Great Looking square on the engine. Were did it come from?
