mechanical mixer
mechanical mixer
I have a plane called a crossbow (see picture under name) and it has a mechanical mixer for aileron/elevater. The mixer uses plastic ball links and I really don't trust that they will stay connected while it flies, which is why I have only tried to fly it once (It was greatly out of balance but survived). What I would like to know is;
Is there anything I can do to either make sure the links will stay attaced, or is there some other mixer I can use. Be aware, I have the MOST BASIC 4 channel radio (airtronics. Yes, Yes I now, they aren't the best but it came with my first plane and I can't afford a new one) and can't afford any new controllers so the mixer will have to be in the plane itself.
Thanks.
Thanks.
RE: mechanical mixer
If you can change the ball links go to the ones which have 2/56 screws through the center.(metal ones) used in cars I think. I think if you look around you may be able to get an electronic mixer. V tail mixer would work. I woulg go for the electronic mixer if you can.
Cheers.
Cheers.
On my V35 it takes a special tool to take them apart, I would not worry unless they are getting old and brittle. With out the tool you break them.
Thanks everybody.
Jim, I think the sullivan ball links will work perfectly, they look like they won't come off easily. Ghost, I have looked for electronic mixers but the only ones I have found won't work with my radio or won't fit.
RC Outlaw, I have tried to post the current links so you can see it is not hard for them to pop off.
AZ
I do not think the ball links you have will pop off. In general, I dislike them, precisely because they are so difficult to get off and on. I also dislike the friction they impart to any control system. In your installation (I saw the photo several msgs down-thread), I don't care for the installation of the nyrod housings, as they are not lined up correctly to the connection points on the mixer on the servo. This creates extra strain, servo drag, and increases battery drain, as well as imparts "stickiness" to the mixer itself as it moves. Other than an electronic mixer (can be had for about $20), you can also do away with the servo-mounted mixer entirely and use a sliding servo setup; I prefer sliding the servo because the connections to the rods are less finicky and the servo can be mounted anywhere you can mount a servo, they run friction free, and cost nothing. I use such a design all the time in V-tails and flying wings. You can find "how-tos" for sliding servos in many places on the web. One more thing: do not let peopel berate your Airtronics 4-ch radio. I have had 2 4-ch Vanguards for almost 20 years that have and continue to run flawlessly. Just because the old servo leads don't match to more modern radios is nothing of concern: make up some jumpers with Dean's Pins (3-pin) to go from Rx to Servo to mate up with with any servo you care to use. CHange the connectors on any old-style Airtronics servos you have to match, and you are compatible across the board, from any system to any system. Have fun. Jim
Canard flyer,
As Jim said. Just make up some addapters and then you can use any types of servos. Attachet is a coppy of a clipping that I have been using for years. Just save or print it out. I would still go with the electronic type if you can. Good luck.
Cheers.
RC Outlaw,
RC Outlaw,
Cheers.
Thanks again for your help.
I checked with tower hobbies and they have the great planes elevon mixer for the slinger arf. Is that the type of mixer you mean.
I checked out the sliding servo concept and it looks great but how would I make sure that it moved smoothly? Also, althought there is room, it looks like it would require quite a bit of modification to remove the fixed servo tray to place a sliding tray.
How does the electronic mixer work? I can see how both servos are plugged into it but only one servo is truely hooked up to the control surfaces.
Please excuse the lack of knowledge, I have not used anything like this before.
Thanks.
Thanks.
Hey, that's great. The other diagrams I saw involved just some smooth type mount that the servo could move on. The enforced nyrods look like a great way. I am going to try that out, thanks.
OH
Hey Canard Flyer,
I got an "E-Flite" electronic mixer for the elevons I'll send you post paid, if you want it. I got tons of stuff, and I have got to get rid of some of it.
PM me if you want it, I'll dig it out. (I just moved so it may take a day)
Let me know.
Let me know.
Canard flyer.
See the quick drawing for hooking up the mixer. I used the sane setup on the CRUSADER 2 RCM Plan #1030 many years ago.
Cheers,
Cheers,
My Feedback: (7)
Ace used to make a Christy Mixer (electronic) that I used in my flying wings years ago. It was added between your receiver & servos and mixed two channels. But, I don't know if they still offer them...
OH
ORIGINAL: jettstarblue
Hey Canard Flyer,
Let me know.
Hey Canard Flyer,
Let me know.
I bought it before I had a radio w/mixing (Hitec Laser4 non computer).
