Gremlin Help
The 131 mph was not theoretical, was on radar. But this is how I did it. Went to a high split S, hammered the throttle all the down then cam across the field.
All I'm really trying to say is it's hard to beat the Gremlin for a $35.00 plane. I beef up the front ends of my Gremlins. I put plywood under the fuse where the motor mount is and cover the front in epoxy, sheet w/ fiberglass.
Happy flying
Dan
Happy flying
Dan
Dennis
OK if your really interested we should move this to its own topic and not continue to hijack this one do you agree?
Sorry if I have been taking a bit long to answer I have been working on a new design for indoor flying. Made for cheap Hobby King parts durable enough to take a licking and keep on ticking. Its not as light as a competition machine but its made for beginners and intermediate flyers that will no doubt have some hard contact with others/walls/floors and ceilings. Its made from the fan fold foam used under siding. These fly outdoors well too. Will test fly it this Sunday.
Dennis
Dennis
MI
131 mph on radar with .35 os engine. and my os.46 AX II gremlin is even faster. A friend of mine
uses a racing .40 engine w/a tuned pipe that is the fastest gremlin on our field.
#31
I do know the Gremlin was a great first combat ship but within a year or two of combat very few were flying them any more as other designs were more competitive. Our club decided to fly combat with the only restrictions being a .25, design was wide open. Within one summer no more Gremlins everyone was into speed and maneuverability and the Gremlin didn’t cut it even with a Jett .25 with pipe. It went as fast as the Wedgie but weighed more and as a result could not keep up in the turns or climb.
As far as cost the wedgie is cut from the lightest 2 inch thick by 24 inch by 8ft foam found at Home depot at the time about 8 bucks. You could get 2 compete from one 8 ft sheet then with a few sheets of 3/32 balsa and water based contact cement the wing was covered. A little ply for the tank and motor mount and some aileron stock and it was ready to cover about 40 bucks and you could have two ready to go.
Dennis
#34
MI
MI
No problem Tbobflow. Here is my email. I could give u many tips including pictures if u want . I've built and crashed many of these Gremlins.
[email protected]
[email protected]
#39
Ah a few pictures of one of the original Gremlin Killers HE HE HE HE!!!!!!!!!!!!!!!!!!!! Notice the leading edge still has old contact cement on it and the canted engine to allow the exhaust manifold to clear the wing. All electronics are inside the wing. The blood streaks are in memory of those I have mid aired with and survived. The others not so lucky HE HE HE!!!!!!
#40
MI
Foam wing with hardwood leading edge. If you get the $75.00 kit It's ready to cover all the wood is glued on.
Would be easier and faster to email me directly, than using this post. What engine u going to use?
[email protected] put in the subject line gremlin help
Dan
Dan
#42
The guys at the US Nats used some kind of sticky goop on the leading edge of the wings. It would come off and have to be reapplied every other flight or so. The pit guys didn't like it for sure. A notch in the rudder, and wing is pretty common to snag the streamer too. Some clubs outlaw sharp leading edges.
#43
Dennis
#44
Dennis
#46
Now on that note Randy if you wish to be able to build one from scratch I can start a new topic that will allow you to build one with all the latest improvements. A simple yes or no thanks will be sufficient.\
One other thing to note is that the plans on-line or hard copy remain free domain.......Anyone can copy, change or pass them on as long as its free.
Dennis
#49
Dennis
