Winter project - Skymaster Large BAE Hawk
RE: Winter project - Skymaster Large BAE Hawk
Hi.
I use the New V7 lights from Flugmodellbau. http://shop.strato.de/epages/1545266...22Nova%20V7%22
I ordered a kit for the Airworld Hawk http://shop.strato.de/epages/1545266...lectSubProduct
But ask for the new V7 lights. They are the best and brightest IMO.
Fitted the missiles and rails. Great for orientation and could not notice any difference in flying.
Next time, i will try with the drop tanks as well.
This is one great flying airplane
#31
I have flown the C-Arf Hawk as well.
Flies great too, but feels different.
The SM hawk flies more scale IMO and feels more massive in the air which is excactly what i like.
The C-ARF Hawk flies lighter and feels more like a sport jet. Looks more like a sport jet also, so depends on what you are after. Bothe are great planes, but different...
#33
Hi all
two Skymaster Large Hawks maiden flight from Taiwan on last week,
the BAe Hawk Powered by K-180 (Mr. Chang) & Hawk 100 Powered by K-170 (Mr. Dung) ,
the Bae Hawk color scheme with Staale's same
#35
My Feedback: (21)
Hello,
I have one of these Hawks on order and I have a few questions.
While looking a different build threads, I notice that all the servo arms being used are of the heavy duty nylon type. Are these type arms strong enough for use on a jet ? Or would I be better off with aluminum arms with ball links ?
I plan on using Futaba 9157 Servos all around. Will Dubro Heavy Duty servos arms be what I want to use if I have to use the nylon type arms?
Also, Is there anything to watch out for while building this jet ?
#36
My Feedback: (44)
Hey Joe, Look at post 516 and onwards of the following thread... you may want to reconsider the Du Bro arms
I have been flying Hi-Tec servos, I have never had a problem with the heavy duty nylon arm that come with them
http://www.rcuniverse.com/forum/m_10...21/key_/tm.htm
That's cool your getting a Hawk, you can come to Titusville and fly with me when I get my COMP ARF Hawk done, and Cliff (FLYAWAY) has a older Skymaster Hawk he will be flying also!
#37
My Feedback: (21)
Rich,
Thanks for that info.
I was not liking what I was seeing in the build threads showing nylon arms. I prefer the aluminum arms and I even doubled up the control horns in my Tuono to make me feel comfortable. So basicly, I should continue to change or modify whatever I think needs to be done to feel better about linkage hookups.
Also, Your Tittsville event is when ?
Hope to get to fly with you guys some weekend.
#38
hi joe
i also used nylon arms on hitech servo's in my s/m hawk 100
no problem. all servo's are 7950 hitechs
ken
kmrc jets
ken
kmrc jets
#39
I find that ball links are often too big to work with jet applications. My preference is to use SWB aluminum arms with nylon inserts, which allows the arm to be used with thin metal clevises. With that said, I've used nylon arms with jets with no issue. For my 3D/IMAC planesI use aluminum arms because the loads are much greater.
#41
Dantley, got a photo of the inserts and actually the whole setup? As you know, I just went through ALL my jets andd go rid of my DuBro HD arms. Much to my horror, some of the splines that had seen blue-loctite had really worn down and were in critical shape...
With a new SM Hawk 100 build upcoming, it makes sense to try out your approach...or stick with JR HD Nylon arms. But I am curious about the SWB w/nylon inserts.
Shaz
Shaz
#43
My Feedback: (44)
ORIGINAL: sskianpour
Shaz
Shaz
Here is a link to the SWB site showing the arms
http://www.swbmfg.com/productimage.php?product_id=35
http://www.swbmfg.com/products/Futab...or-Clevis.html
Product Description
SWB’s the original aluminum Double-Loc Servo Arm
These arms are not only designed to clamp around the output shaft,
but they also make up for any inconsistencies in the output shaft sizes.
These arms are made for using DuBro Clevis (included).
They have a insulation bushing for Delrin, NO Metal to Metal contact!!
#46
Thanks Rich!
I wish they had 1/2" and 3/4" arms. I try to get my arms as close to servo as possible so I can ensure the greatest travel and therefore not having to limit my resolution with the ATV/Control Throw settings on my Transmitter. I generally drill into an aluminum arm if it is too long and just make a "new hole" kind of like if your belt is too large or too small.
Shaz
Shaz
