Reload this Page >
Eflight Blanik 4.2m with turbine?
Old 11-02-2014, 08:55 PM
  #226
ZivBit
ZivBit's Avatar
Originally Posted by sysiek
Do you guys think this will be OK power for my blanik after I see the video with p120 and the performance was just OK I decided to install my p160 Se for better vertical performance and 80oz fuel tank for good 6 minutes. just wandering is this will be okay power for vertical climb.?
Hello Sysiek,
I think it is far too much for this glider. You will risk breaking the tail, rudder and elevators due to excess heat and thrust on the stabs.
I have one with the P100 on it and flies just great. This glider is not built to take the abuse of a P160...
BRG,
Ziv
Old 11-02-2014, 09:26 PM
  #227
mullerr
200 would be better for vertical, 160 may not give unlimited!
Richard
Old 11-02-2014, 09:34 PM
  #228
jet junkie
please show us the vid with the p120
thanx
Old 11-02-2014, 09:49 PM
  #229
sysiek
My Feedback: (176)
sysiek's Avatar
I don't have one ,I have two p-160's my do twine and seal the center part of fuselage for fuel
Old 11-02-2014, 09:53 PM
  #230
sysiek
My Feedback: (176)
sysiek's Avatar
Oh that was p-20 my bet than I stick to my original plan and instal the vt-80 ,that was joke with the p-160 ?
Old 11-02-2014, 10:10 PM
  #231
jet junkie
yea the p20 is a bit lame really...vt 80 will be great....my P100 makes it rock and roll ...the speed takes time to build up though, but once its moving it feels good..slows down nice with full flaps...I make new horns for the flaps so can get past 90 degree down with them...slows up really well
Old 11-02-2014, 10:37 PM
  #232
chrigui
my first four flights was done with vt-80 detuned to 6kg...
Old 11-02-2014, 10:40 PM
  #233
sysiek
My Feedback: (176)
sysiek's Avatar
I did flown one with k-80 and was just ok the vt -80 have little more power and much faster-respond with better fuel economy ,the k-80 blanik will have k-100g next week it should do better with k-100 ,I wish the will do the blanik v tail instead the scale one.
Old 11-02-2014, 11:00 PM
  #234
chrigui
Old 11-02-2014, 11:09 PM
  #235
sysiek
My Feedback: (176)
sysiek's Avatar
O I like the motor mouth a lot ,did you make this one and maybe more for sale?
Old 11-02-2014, 11:27 PM
  #236
chrigui
Old 11-02-2014, 11:57 PM
  #237
jet junkie
funny you should say....im working on the design right now...
https://www.youtube.com/watch?v=EC1cVEp1wXo&list=UU44DH8GWvMgg5zGis5FPVTw
I planned on using the original tail fins, but needs at least another 20% surface area so will be making another plan, have 2 idea's in the mind at the moment...will keep you posted..
Old 11-03-2014, 05:52 AM
  #238
sysiek
My Feedback: (176)
sysiek's Avatar
I think two ruders will work better ,I was thinking about the same and using the two rudders instead the original elevators .+extend the fuselage a nother 3-6" usually the v tails glider a little longer
Old 11-14-2014, 12:37 AM
  #239
chrigui
flight test with VT-80 brushless -- detuned to 6kg trust
camera looking rear to check possible vibration/flutter on stab and tail
https://www.youtube.com/watch?v=yy9k9hhFpHM
Old 11-14-2014, 12:42 AM
  #240
jet junkie
retune to full power mate!
Old 11-14-2014, 12:53 AM
  #241
chrigui
AHHAHAHA ...this is relax flight
i used only max 1/3 stick gas for entire flight
Old 11-20-2014, 10:12 AM
  #242
blaster66
Hi Guys,
Just took delivery of the Blanik, Anyone know what the root airfoil is ?
Or better still anyone with a dxf for rib ?
Cheers
Phil
Old 11-24-2014, 06:22 PM
  #243
zonker123
My Feedback: (21)
zonker123's Avatar
I picked up Pablos' Blanik airframe a couple months back and put a Jet Central Super Bee on it.
Having a ball with it!!
From last weekend.
Take care.
Mike
http://youtu.be/BbqG7ZdC0Vk
Old 11-26-2014, 04:50 PM
  #244
croweville
My Feedback: (23)
croweville's Avatar
Hey All,
Seems to be a GREAT package with the combo that you chose...
TTYL,
Bruce
Old 06-29-2015, 05:51 AM
  #245
Capt D
Don't know if this group is still alive or not. Would the new K-45 with 9.9 # thrust be enough for just climbing to alt. no acro? or would the k-60 at 12.2 # be a better choice? Thanks for a reply, Don
Old 06-29-2015, 06:38 AM
  #246
chrigui
hello.... :-)
i have vt-80 detuned to 60n all aerobatic manouvres are possible...
Old 06-29-2015, 08:04 AM
  #247
Duncan
Duncan's Avatar
I've bought the K60 Ali had on his Blanik, and if it was ok for him, i'm sure it will be fine for me.
Old 06-29-2015, 02:25 PM
  #248
mullerr
I fly it with a Wren44 Gold, once on step you can do any maneuver you want.
The nice thing about the 44 is that once you set correct down thrust you will notice little to no trim changes between min and max throttle.
P.S get the spoilers, they work amazingly! Be carfule with them and they will add to the fun of this plane.
Richard
Old 07-01-2015, 05:27 AM
  #249
Capt D
Thanks Richard, I think I will go with the King tech K-45. It's a lot lighter than most, might cut down on the lead up front. Has anyone tried an air start? probably against AMA rule's.
Old 07-03-2015, 01:05 PM
  #250
Dave Wilshere
Pictures from a couple of weeks ago. P-60 powered, its plenty even from grass like this.
ID:	2107192   Click image for larger version
ID:	2107193   Click image for larger version
ID:	2107194   Click image for larger version
ID:	2107195   Click image for larger version
ID:	2107196   Click image for larger version
ID:	2107197   Click image for larger version
ID:	2107198   Click image for larger version
