Setup LGC12 (XICOY)
My Feedback: (81)
Setup LGC12 (XICOY)
I need help in setting up my LGC12, after trying every way in the book. I use only retract and brake, but the brake
never works.The instruction are the following: (No data terminal, manual push button)
Switch off power, press the button and switch on the power on the receiver. Release button, the blue light will flash
intermittently, one short flash with a long pause between flashes. set the transmitter at the position you want the
gear retracted, push the button and hold until solid blue light, release button, the led will blink 2 short times.
Repeat the procedure for the brake, and steering.
1 blink -> Gear up command
2 blinks -> Gear Down (extended) command
3 blinks -> Brake OFF
4 blinks -> Brake maximum
5 blinks -> Steering servo retracted position
I know it is something simple that I am leaving out or doing, so any help is appreciated. TIA.
Johnny
Johnny
You will probably NOT be happy with the LGC12. I tried the 12, the 13 and finally they came out with the LCG15. I could not get the electric brakes to work effectively on the 12 or the 13. The 15 is a dream for braking. It is easy to program and works like a charm. Once you get the first 15 programmed, you can transfer the program to other planes for a good start, and then tweak it to address differences. I trashed the 12 and gave the 13 away. I have 3 LCG15s. They have the same programming as Electron's GS200. The 15 uses the brakes for steering to a smooth straight stop. I just push the lever on the Txer fully up, and the planes just stop. No skidding! no dancing! Just a smooth straight stop.
My Feedback: (53)
Johnny
Johnny
I don’t have a LG12 but I have a few RB45 (electron but same unit) and they work fine…
After thinking about this issue for a couple days, I recalled going through this issue before. Somewhere along all the frogging around with LGC 12, 13 and 15s, I discovered for the brakes, the Red wire in the brake unit's JR connector has to be in pin 3 position vs. the normal pin 2 position. I know that is the pinout for the LG15. I just went out to the trailer to check one in a LGC15. Pin 1 = ground, Pin 2 = empty, Pin 3 = +voltage. They do NOT mention this pin arrangement in any of the LGC manuals. But set up this way, it does not matter which way you plug the JR connector in. That was the tipoff for me.
My Feedback: (53)
but yes I forgot to mention red black into the 2 outside slots….
grbaker (06-07-2022)
My Feedback: (20)
What batteries and voltage are you feeding into the LGC-15 for gear and brakes?
Thanks, Gary
