Boomerang Nano!!!
#1176
RE: Boomerang Nano!!!
Thanks for that.. As I suspected.
I think I might stick to neat primer as the big tray would need a lot of prep work. You just saved me a load of work
Regards Al
Regards Al
#1177
Nice job boomerman - Very tidy install, especially so for a first timer. The Nano looks great in the USAF colours too.
Ali,
I coat all my trays with thinned resin and then paint them but to get that super smooth gloss painted finish takes quite a bit of elbow grease.
A few coats of gradually thinned resin with plenty of rubbing down between is what does the trick. Here's a pic of my Sprint install.
Colin
Ali,
Colin
#1178
ORIGINAL: Ali
Regards Al
Regards Al
#1179
Hi Colin.
Afraid not. Maybe once I get this little lot out of the way... I am doing a PST Revision for a customer, then a Skymaster Viper ( although just helping a friend wi this one) Then the toughie with the big tray is a 1.9 M Futura. This is another turnkey build/set up and fly with a twist.. It has to be ready to travel out to Florida jets with me, So I can fly it and hand it over to the customer all set up and tested!
Oh and in the middle of this I have a very unique job slotted in for the Gadget show that involves 2 x P200's and the Guinness book of records! So if you need to get hold of me, it looks as if I am going to be in the workshop for the month of February
Regards Al
Regards Al
#1180
ORIGINAL: gontflyer
Ali,
Colin
Ali,
Colin
#1181
ORIGINAL: Ali
Hi Colin.
Regards Al
Hi Colin.
Regards Al
#1182
Colin, I might suggest that you move your Aux antenna further away from the radio tray, maybe all the way up in the nose, and another one way back in the belly. just a concern.. the more distance the better between satellites. I usually stick one as far forward up in the nose as possible, and the other antenna in my nano is all the way down in the left wing well by the boom. ensures better signal diversity..
100% agree with you however...
The purpose of my post was to show how shiny my tray was - not to demonstrate the signal diversity in my installation
With that in mind you can't see the location of the second remote receiver in the fuselage and as for the first one, well my batteries are up front and I would generally not place remote rx's in a confined space surrounded by batteries. 44 flights on this airframe since 1st of Jan and no issues - now Im tempting fate arent I !!
all the best
Colin
#1183
ORIGINAL: boomerman
here are some pictures of my nano navy build. its now coming towards the end and is the first jet that i have actually built!. running a jetcat p60 turbine, robart spring air retracts with wire legs,
i am just waiting for my jet-tronics valve and dubro 50oz fuel tank to arrive from motors and rotors. then all that is left to go is the reciever and some gas fittings. i have an onboard gas tank set at an angle inder the board. also going to fit a air pressure guage for the retracts.
Why do you feel the need to have an air gauge? Will your air pump have a gauge? You cannot read the on board gauge in the air
It's just another place to leak...
Dave
#1185
Cheers Colin. I will send an SOS.. I guess you may be interested to see how a Futura goes together I can sort the Pizza, although I tend to need all the Kero for the planes, so you might have to make do with a cold Peroni!
LOL I have just noticed Boomermans custom model protector! There I was thinking it was the intro was the Boomer that was referred to as the baby.
Regards Al
Regards Al
#1187
ORIGINAL: Ali
Regards Al
Regards Al
#1188
I like to use an onboard air gaugeto give confidence duringinitial flights and testing in the workshop ,it is easy to see if you have a leak , leaving the model over night to see just how good your system is .
Recently I had a leak which took abouthalf anhour to leave me with no wheels ,if I hadn't noticed the gauge abnormally low when refueling Icould have had an uncomfortable belly landing
#1189
By far the majority of jets I have seen have air gauges in them, it seems to be a question of personnal preference, if you want to use them.
Mike
Mike
#1190
just a quick note to say that many thanks to dave from motors and rotors, who offered to help me out in the nasty job of bending the wire for my robart spring air retracts.
many thanks dave for all your help and advice on my nano build!!
#1192
ORIGINAL: gontflyer
Hi Goose,
all the best
Colin
all the best
Colin
#1193
well many thanks again dave!, my nano is pretty much done now!. just need to fit my rx and battery and ready to go! (when i pluck up enough courage!)
will get some pics when i can
#1194
Banned
1 Post
So now for the Million dollar question................. With a pull pull stearable nose wheel and quite a small slot to retract into how do you ensure that the wheel does not turn as you retract it and get jammed against the whole cover. Or will the airflow keep it straight ?
Dennis
Dennis
#1196
ORIGINAL: bigplumbs
Dennis
Dennis
#1198
Frank
Have you asked Andy seeing he collected that set up last week? I'm sure some guys on the original thread said that is what they were using.
Dave
Dave
#1199
ORIGINAL: bigplumbs
Dennis
Dennis
Retract noseleg units all should have a servo mount built into the retract plates, you can do your own direct linkage with a bit of thinking, the ones below work with a 3mm rod glued to the steering arm and a sliding aileron torque rod (remember them) type connector which allows for the push rod movement when retracted.
This method also keeps your nosewheel streight when retracted and no 'bits of string' to bind up and catch.
Use a MG mini servo for the smaller retracts, and those cheap TowerPro MG995 you see for sale on ebay are ideal for majority of nosewheel steering as they are high torque (not as high as they claim) and all metal geared and come with big strong arms.
#1200
Hi Dave,
I've dropped Andy an email. Id be surprised if he's got that far yet, but there again he's got to be a faster builder than me.
Frank
PS i stand corrected, just got an email saying its been done. Mains were easy, nose gear, bit of a headache but Ill pop around for a look and report back
Frank
