Official Nitro Evader ST Thread v2.0
#9377
PA
RE: Official Nitro Evader ST Thread v2.0
BEARBYSR what are the zipties on the motor for
Here are couple pics of my newer project vader
#9378
PA
Ive had two clutch bells stock ones that the gear has broken off of just sheared right from the bell.
#9379
IL
Yeah thats why im looking for one stronger than the stock one, everytime i use my evader with the os in it that happens. Everything seems to be setup right but i just cant figure it out. and i have stripped a couple of them too.
#9381
AR
BEARBYSR how well does the Evader run with those tires on the front? Does it still turn well and do you go through alot of steering servos
#9382
KY
my friend has that same tire set up with proline2000 and i think it turns better with that set up.i think he has gone through 1 servo and i think it was mostly because of the cold it was15degrese out
#9383
IL
I'll have to try that i have it loose enough to where i can hold the wheels in place and turn the gear by hand but i gotta get a new clutch bell before i try it.
#9384
PA
#9385
AR
sweet just wondering. I have the same problem being top heavy Im running moabs on the back. but didnt want to stick them on the fort because i thought I would burn up my servo
#9386
IL
a couple of pics of my nitro evaders, the last two are of a clutch bell i mentioned a few posts back that the gear ripped free from the bell.
#9387
KY
ORIGINAL: venom69_420
ok guys, i riped the 2 trucks apart and test fitted the 3.3 in the evader now every thing seems like it would work fine i just have to maybe drill some new holes for the engine mounts and abrace for the throttle linkage rotating arm. the big problem i have is the gear mesh between the spur and the cltch bell the teeth are to small for the 3.3.i was wondering if you guys had any ideas about what can be done about this heres a couple pics. can i get a diff spur gear and mod it? i dont know to much about gearing so any help would be appriceated thanks
did you ever get this engine to fit
#9388
AB, CANADA
i figured out how to put it in but i decided to get a savage 4.6 instead of putting a big block in my revo. so now i dont have a 3.3 for it...but that doesnt mean the project isnt over lol. ill just have to look for another 3.3 when my wife lets me spend more money lol i just dropped 800 bucks on my savage and some other stuff, so it might be awhile lol
#9389
hey,
my lhs has a used evader for sale , all it needs is a spur gear i think , and im thinking of getting it , is it a good truck? is it race worthy?is it durable?r the gears in the tranny strong?? and wat else can u tell me about the evader
thanks
thanks
#9390
IL
The evader is decent, only downside in my opinion is that if you tune it by factory specs it wears out early well the engine anyway
#9391
IL
aside from that the only real problem ive had is that the spur gear is plastic but you can order an aluminum one off ebay
#9392
wat r the most important upgrades to make the evader durable , as i have heard some people say that its weak and fragile , is that true??
#9393
IL
I honestly dont think so i run mine into stuff all the time, so far ive only broken one of my controll arms and that was because i ran full speed into the corner of a porch. Wreck a jato at 25 mph and i promise you its gonna break too. as far as upgrades id get metal gears, metal geared servos, and the os 18
#9394
NY
ORIGINAL: RUSTED
hey,
thanks
hey,
thanks
#9399
ill check with my lhs today if they still have it ,, if i get it ill convert it to electric , will buying an aluminum diff gear prevent the tranny gears from breaking or striping ???
