Northwind 28 - Rigging question
Hey mfr02 - Sorry for the delay was out sick.
Great suggestions and I will definitly implement them. Hoping to get it on the water within the next month during a vacation so excited to see it on its maiden! Will update once complete.
Thanks again for your help and suggestions
Banned
What I have seen done for this type of hatch is to take what the airplane guys call wing saddle tape. It is a dense foam tape of various thicknesses and widths. They put it on the inside of the hatch along the outer edge so when the hatch is closed the tape contacts the edge of the lip on the boat. Guys have told me they have never had any water get in when using this method. The tape comes as thin as 1/8 inch and is not porous. Hence water will not soak through it.
Banned
I believe you're referring to the ELF system. And yes, northern Wisconsin contained part of the antenna with Minnesota containing the rest. What they did was to take upwards of 1500 miles of high power electrical transmission lines out of the power grid and that became the long wire antenna. I know they tried different lengths and what they settled at I don't know. It quite literally thumped the ground and took that route to the subs.
#31
Hey sorry about that -wast able to post. I used
