Adding weight to tanks
I tend to feel any weight you want to place onto a tank's hull should be placed inside. Attaching it to the outside of the hull bottom reduces your ground clearance, which is already reduced in the first place by the added weight. You could get beached or hung up on a rock propped up by your hull.
While adding the plate does reduce the ground clearance by 3mm the Sherman has plenty of ground clearance. You run the risk of getting hung up on a rock no matter how much ground clearance you have, it just depends on the size of rock you try to drive over. Personally I try to avoid those big ones.
Steve
Me too. Our tank field is outdoors with grass that we cut as short as possible, but lur experience is taht the heavier tanks tend to bog down a bit and deplete the batteries more quickly with the added resistance of the grass surface, even when it is cut short.
Really, I don't know a better way to lower the center of gravity than by putting weight on the lowest part of the tank, underneath the hull! In the original post he only mentions increasing the weight, but weight evenly distributed under the hull actually lowers the CG and provides the weight as well as stiffens the hull, and doesn't overload the suspension in only one area which other types of weight might do, so you get four benefits in one.
Steve
Steve
You are indeed correct with your analogy there Steve.
Jeff
#32
WA
I would concur with the stick on wheel weights being pretty effective since lead wins in the density department.
Was experimenting with the StuGIII I have, and ended up melting some wheelweights and casting them into blocks that fit between the torsion bars since that space is essentially wasted anyway.
Of course, another battery if possible would be a better option, since it is useful for something other than dead weight.
