ESM Spitfire 72.5
Old 04-29-2016, 02:11 AM
  #226
sandyjain
Thanx Oldtimer.... That seems doable.....
why are you up at 3am in the morning ??
Old 04-29-2016, 10:00 AM
  #227
sandyjain
Thanx for the idea Oldtimer.... I did exactly exactly as you suggested and I am done with the engine, ignition and cowl.
Now for the electronics and fuel Tank....
Old 04-29-2016, 04:22 PM
  #228
oldtimer4759
G'day Sandy, live in the land of Oz, great place down here, couple of hours time diff.
cheers, Oldtimer.
Old 04-29-2016, 04:27 PM
  #229
oldtimer4759
hello Sandy,
mount your batteries in the engine bay if you can, the CDI unit as far forward as you can, you will need the weight up front. also move the fuel tank back over the C of G if you can, that helps with ground handling. I have a heavy turned alloy spinner with a turned weight in front of that as well. my C of G is close to 100mm back from the front of the wing at the join point.
cheers, Oldtimer
Old 04-29-2016, 10:13 PM
  #230
sandyjain
Oops... I assumed u were in the USA !!! Well so u are 4.5 hrs. Ahead of me...
The cdi is up front, I too hv a heavy alloy turned 4.5" spinner and batts will also be up front.... Need to look into pulling the fuel tank back... That's a nice 4 blade prop on yours... Where is it from ? My spinner is also 4 blade but am using 2 blade as if now.
I will be visiting our kids in the us in May... Can get the 4 blade then...
Old 04-30-2016, 03:04 PM
  #231
oldtimer4759
hello Sandy,
the prop is only for looks factor, I dont fly with it, probably could I have never tried,
it is from here, http://www.aircraftinternational.com...rbonProps.aspx
I fly mine with a 2 blade 18 x 10 Mejzlik carbon prop, with the 35 DLE and that prop the model will be fast,
cheers, Oldtimer
Old 05-01-2016, 11:04 AM
  #232
sandyjain
Glad to hear that.... I have a 19x10 xoar...the 18 comes with a smaller bore of 8mm whereas the dle35 has a 10mm prop shaft....
Old 10-11-2016, 05:45 PM
  #233
BDK74
I just picked one of these up second hand. Im going thru it and making everything how I like. I have 2 engines, a DLE 35RA and 55RA. I know the 35 will fit no problem but Id really like to put in the 55. Anyone know if this has been done? I will have to move the firewall back a bit but I think the performance will be great.
Brandon
Old 10-11-2016, 08:28 PM
  #234
w1nd6urfa
w1nd6urfa's Avatar
Hi Brandon,
I wouldn't recommend the 55RA. The 35 will provide all the power you need for this model, anything more is overkill plus bear in mind ESM fuselage are polyester resin not epoxy, poly gets brittle with time and UV exposure. Plus the wing structure is weak (see many posts earlier in this thread), and you get the point.
Old 10-11-2016, 08:29 PM
  #235
w1nd6urfa
w1nd6urfa's Avatar
Apologies, the major thread I mentioned is this: http://www.rcuniverse.com/forum/rc-w...re-mk-xiv.html
Old 10-12-2016, 08:09 AM
  #236
Duplicator41
Duplicator41's Avatar
This is the same aeroplane as the EMS. You would have to re-build the entire model to handle the power of a 55. It was designed for a .90 to 1.20 glow, a 55 gasser will rip it apart.
Cheers,
Old 10-12-2016, 08:25 AM
  #237
BDK74
Yea, it's very apparent this fuse was not meant for anything with much power.
I plan on moving the firewall back and reinforcing the nose and seams substantially.
Old 10-12-2016, 08:46 AM
  #238
Duplicator41
And what are you planning on doing to the retract mounts, hinging of control surfaces and wing spar strength?
Old 10-12-2016, 09:02 AM
  #239
BDK74
Reinforcements will be made in the appropriate places.
I know a thing or two about fast planes
Old 10-12-2016, 10:57 AM
  #240
Duplicator41
I'm not questioning your knowledge. It's a lot of work to build this ARF into a plane that will withstand the stresses put on it with a 55 up front. I have this model with an 1.20 FS up front and what I had to do to it to make it solid after one of the ailerons ripped out due to the CA hinges tearing apart. It is an early model EMS bought from Andrew Kondor in Canada then known as KMP.
Cheers,
Cheers,
Old 10-12-2016, 09:31 PM
  #241
kittykatjaz
kittykatjaz's Avatar
Keep an eye on your fuselage behind the firewall. Mine developed a large crack going at least 1/3 the way around. This Spitfire has been a regular flyer for just under three years and this has only appeared in the last month. Am going to wrap a kevlar band with fibreglass inside and out to fix it.
Old 10-12-2016, 09:56 PM
  #242
BDK74
After going over everything I plan on installing a new firewall about 15mm aft and reinforcing the entire inside with glass and carbon. I also plan on replacing the wood dowel wing pins with solid carbon rods and filling the area holding the pins with reinforced epoxy. I will also glass over all the seams I can get to.
On the tail I will be removing the stabs and hinging with pin hinges 4 to a side. I will also replace the joiner rod with a much stronger one. I'm also considering ditching the pull-pull for a push (or maybe pull) rod.
Thats for now, as I get into this bash I'm sure I wil find more that needs to be done.
Old 10-13-2016, 01:25 PM
  #243
kittykatjaz
Keep us posted on your mods with photos. Am interested on how it works out.
Jaz
Old 10-13-2016, 09:50 PM
  #244
BDK74
Today I dove into the big stuff. This plane has previously flown so there's been a bunch of disassembly. I just can't leave well enough alone
To get the proper firewall depth I removed the cylinder and installed the standoffs. Set the engine on the original firewall and installed the cowl. 3/4" too long.
Marked and removed firewall. Cut a new one and installed with resin mixed with glass fibers and a bunch of tow to create a super strong fillet. I will now glass behind the firewall and add reinforcements here and there.
ID:	2185632   Click image for larger version
ID:	2185633   Click image for larger version
Old 10-14-2016, 01:52 AM
  #245
kittykatjaz
Nice job. That Spitfire is going to haul with the 55RA in it.
I have an 88" Pica Spit with the 55RA in it which took a huge amount of work to convert from a rail mount glow engine. It weighs 12+kg and is really quick.
The 20x12 Mejzlik is a great prop for speed and ground clearance. Also the small Bennett muffler will give you extra room around the rear of the cylinder for the cooling air flow. Just watch for fuel vaporisation from radiated heat around the carb and fuel lines. My Pica Spit suffered really badly and required and lot of baffling to keep the carby cool.
https://vimeo.com/155070689
Old 10-15-2016, 05:20 PM
  #246
BDK74
Some more work done. I get a lot of satisfaction from these kind of projects. I've never been able to leave well enough alone.
I glassed the inside with more glass that's in the fuse! Several layers of 8oz cloth with laminating resin has made the nose area very robust.
I decided to remove the cylinder to make life easier getting the engine mounted. It's all lined up nicely and I couldn't resist getting it on its feet. I'm also installing a tail wheel retract. Speaking of retracts, these ones are Sierra. They came with the plane and are obviously the incorrect angle. Ironically they are ME-109 retracts and struts.
With a 22x10 prop there's not much ground clearance.
Still a a good amount of work but I think the big stuff is behind me.
ID:	2185999   Click image for larger version
ID:	2186000   Click image for larger version
Old 10-17-2016, 08:55 AM
  #247
Bluffman
Looking good Brandon, I hope you can keep up with my Moulded KMP Bearcat with its G62��
Old 10-21-2016, 11:51 AM
  #248
BDK74
All finished up and ready to fly! For now I'll leave it as is and fly it a bunch. But I'd like to paint it and add some more detail some day.
The tailwheel is a Robart 121 .60 size. I used Kevlar string for the steering and up control. Down is via a spring attached to the rudder post. The servo is up front and locks over center when up.
The choke was a bit of work. I found some spare hardware that allowed me to rout it down next to the cylinder.
Weight is 17 pounds with 20oz over the engine to CG it. I put it at 110 based on info from threads on this plane.
ID:	2186705   Click image for larger version
ID:	2186706   Click image for larger version
ID:	2186707   Click image for larger version
ID:	2186711   Click image for larger version
Old 10-21-2016, 12:04 PM
  #249
kittykatjaz
It looks great and such quick work. If you can get a flight video and give us a report on what its like.
Especially like how you have done the choke.
Jaz
Old 10-21-2016, 10:25 PM
  #250
w1nd6urfa
w1nd6urfa's Avatar
Good job
Any reinforcement done to the wing and retract mounts?
