How to Build a B-29
#151
Kram,
How are we gonna get Frank and Dwayne to build some German or Japanese bombers? These guys are starting to build the 17 and 29 in their SLEEP ! Actually I think they are both day building and sleep walk building !
hahahahahah
hahahahahah
#154
My Feedback: (7)
Continuing with vertical fin and rudder construction:
I use very soft lightweight 4 inch wide ("contest grade") balsa sheeting rather than the 1/16" X 3" from the kit
On the complex curves of the vertical fin, this gives you more depth for sanding to create a non-rippled surface, and in the end you wind up with no additional wood (weight)
#155
My Feedback: (7)
I have found it easier and more precise for a straight hinge line to build the rudder (and elevators) starting with a light ply center
5/32" control rod notched into rudder. I should have cut it an inch too long, then trimmed it after all the control junk installed down below (after mounting to fuse)
#161
My Feedback: (7)
Elevator Hinging and Control:
Bottom side of elevator, showing imbedded 5/32" piano wire. At final assembly, I will lube the exposed part of the wire with Teflon-based oil
Bushings at inner and outer hinge points are blue Nyrod
Sig 5/32" wheel collars hold the wire beside the control horns
#162
My Feedback: (7)
I use TWO nose gear control horns on each elevator control rod and secure them to a Dave Brown CF control rod with a 4-40 bolt to sandwich the ball link
Use scrap balsa to determine exact shape of complex little plywood parts
Bottom side of tip, I cut balsa wedge, epoxy the hinge tube in place, then replace the wedge before the epoxy sets
#163
My Feedback: (7)
Looking at the bottom of the elevator/stab assembly:
LE's are rounded, center pocket is open for control arm installation
Next step will be fitting the gap strips and that should be easy with the ledge we have on the stab TE
Elevators move freely and are easy to remove if you take the Sig wheel pant collar off
Of course, the 5/32" wire will get flat spots to help lock the control horns in place
Of course, I will Loctite anything with threads at final assembly
#165
My Feedback: (7)
Mopaerial recently did a masterful edit job on a 5 year-old video I thought was spoiled by too much backlighting, also cut a bunch of useless jibber-jabber out to make a 1-hour DVD we call
"Bomber School 101:" basically a 1-hour seminar by Dwayne in my shop giving his experience on how to build, set up and fly a 4-engine bomber
I'm toying with the idea of selling copies, but I suspect my target audience is very small.
Unlike this thread, which can be decent vicarious entertainment, the DVD is only worth something to flyers who plan to actually fly a 4-engine plane
It made the difference between success and failure for me
Mark
Mark
