Reload this Page >
How to Build a B-29
How to Build a B-29
Old 02-03-2016, 09:39 PM
  #176
kram
My Feedback: (7)
kram's Avatar
Tail Attached
ID:	2145120   Click image for larger version
Old 02-03-2016, 09:43 PM
  #177
kram
My Feedback: (7)
kram's Avatar
Time to finish tail gunner area
I will cut out an area for "Joe" after making a bottom hatch for access to pushrods
A little more filling around stabilizer and tail ball and we'll be done with tail-building
ID:	2145122   Click image for larger version
Old 02-04-2016, 06:28 AM
  #178
SWORDSN
My Feedback: (13)
What a speedy builder!
Old 02-04-2016, 06:52 AM
  #179
foodstick
foodstick's Avatar
We are lucky to still have a core group of good builders here in central Iowa... The percentage is low..but higher than most places (I think).
Its a lot more fun going to local events when planes like this show up. We also have a pretty dedicated group of 1/4 scale WW1 builders
(including me) So we have some fun when we all get together.
Last year early in the morning I had my 1/3 Sopwith Pup at the same time two of these bombers were doing some testing. We stayed out of each others way but it was an odd mix to be sure !
Old 02-04-2016, 09:00 AM
  #180
kram
My Feedback: (7)
kram's Avatar
Yeah, normally I would hold my tongue to avoid embarrassing my friends, but since he opened that door you should know that foodstick is "The Big Cahuna" of WW I planes in Iowa.
I can't even land the darned things on my simulator!
Old 02-04-2016, 10:24 AM
  #181
foodstick
foodstick's Avatar
hahah Big Cahuna? I am not sure about that...
But its much easier to be an enthusiast than an expert !
I need to get over to Franks and see if you can till open the door to his shop.. Or find out if he has built his way into a corner and needs a diet Pepsi !
Frank has me convinced that WW2 bombers and Diet Pepsi are interconnected .
Old 02-08-2016, 04:11 PM
  #182
kram
My Feedback: (7)
kram's Avatar
Details of tail gunner windows
Fortunately, I have a larger scale replica in my shop (the 14-ft'er)
ID:	2146070   Click image for larger version
Old 02-08-2016, 04:15 PM
  #183
kram
My Feedback: (7)
kram's Avatar
Removing, then capping the elevators with 1/64" ply
Then adding birch TE to elevators (just like rudder) and blending to the tail
ID:	2146075   Click image for larger version
ID:	2146076   Click image for larger version
ID:	2146077   Click image for larger version
ID:	2146078   Click image for larger version
ID:	2146079   Click image for larger version
Old 02-08-2016, 04:18 PM
  #184
kram
My Feedback: (7)
kram's Avatar
Balsa doublers to reinforce and help shape cockpit walls to the glass.
Much easier and nicer result than vice versa
Old 02-08-2016, 04:22 PM
  #185
kram
My Feedback: (7)
kram's Avatar
Underneath cockpit is nose gear well
Shape formers to make space for UP3 valve, main battery and door cylinders, airlines, etc
ID:	2146082   Click image for larger version
ID:	2146083   Click image for larger version
ID:	2146084   Click image for larger version
ID:	2146085   Click image for larger version
ID:	2146086   Click image for larger version
Old 02-08-2016, 04:25 PM
  #186
kram
My Feedback: (7)
kram's Avatar
Meticulously sand a perfect fit of nose glass to windshield, then attach with CA
Old 02-08-2016, 04:30 PM
  #187
kram
My Feedback: (7)
kram's Avatar
Cockpit floor will be removable to gain access to both cockpit and nose gear well, so it slides on rails and fixes with little dowel pins forward
It is also, of course, the dirt barrier between the wheel well and the innards and glass of the cockpit, so it should be a snug fit
ID:	2146092   Click image for larger version
ID:	2146093   Click image for larger version
ID:	2146094   Click image for larger version
ID:	2146095   Click image for larger version
Old 02-08-2016, 04:35 PM
  #188
kram
My Feedback: (7)
kram's Avatar
Dry fit the nose components so you can admire a preview of the mighty bomber's streamlined looks
Glass won't be glued in place until the cockpit details and the underside mechanical components have been installed
ID:	2146100   Click image for larger version
Old 02-16-2016, 07:21 AM
  #189
kram
My Feedback: (7)
kram's Avatar
Mounting the nosegear UP3, servo and lines in the wheel well. A 3,000 mAh NiCad will eventually be tucked forward, also
I prematurely attach all air lines to keep building dust and paint out of the lines and the mechanisms
ID:	2147612   Click image for larger version
ID:	2147613   Click image for larger version
ID:	2147614   Click image for larger version
ID:	2147615   Click image for larger version
Old 02-16-2016, 07:27 AM
  #190
kram
My Feedback: (7)
kram's Avatar
Cutting a pattern for the nosegear doors on the fuselage. They should be identical. To keep hinging simple and close-to-scale, hinge line cannot be straight, so has only two hinge points
Buttress fuse edges with 1/4" balsa, as usual
ID:	2147617   Click image for larger version
ID:	2147618   Click image for larger version
ID:	2147619   Click image for larger version
ID:	2147620   Click image for larger version
ID:	2147621   Click image for larger version
ID:	2147622   Click image for larger version
Old 02-16-2016, 07:30 AM
  #191
kram
My Feedback: (7)
kram's Avatar
Carefully repeat the process for both main gear bays
Here are several different angle shots of all 6 doors attached
ID:	2147624   Click image for larger version
ID:	2147625   Click image for larger version
ID:	2147626   Click image for larger version
ID:	2147627   Click image for larger version
Old 02-16-2016, 07:36 AM
  #192
kram
My Feedback: (7)
kram's Avatar
Fitting the nosegear door cylinders
Now available from RCScaleProducts in various lengths
ID:	2147629   Click image for larger version
ID:	2147630   Click image for larger version
ID:	2147631   Click image for larger version
ID:	2147632   Click image for larger version
Old 02-16-2016, 07:43 AM
  #193
kram
My Feedback: (7)
kram's Avatar
Building the Bellypan:
This is actually a bit complex. It has 4 bomb bay doors and two forward dowels and two rear 1/4" nylon bolts that disattach from the wing separately from the 4 wing-to-fuse bolts
So the rear 1/8" plywood plate that is the foundation of the aft bellypan has 4 large cutouts that fit over the wing bolts and two 1/4" holes for its own bolts
Wax paper the bottom of the wing, obviously, so it won't stick
ID:	2147634   Click image for larger version
ID:	2147635   Click image for larger version
ID:	2147636   Click image for larger version
Old 02-16-2016, 07:46 AM
  #194
kram
My Feedback: (7)
kram's Avatar
Finished bellypan, in-the-rough
ID:	2147639   Click image for larger version
ID:	2147640   Click image for larger version
Old 02-19-2016, 05:26 PM
  #195
kram
My Feedback: (7)
kram's Avatar
Glue balsa to make a back lip of aft bomb bay
Also reinforce side hinge lines of both bomb bays with balsa
Old 02-19-2016, 05:29 PM
  #196
kram
My Feedback: (7)
kram's Avatar
Similar balsa lip for the front edge of the front bomb bay
Old 02-19-2016, 05:36 PM
  #197
kram
My Feedback: (7)
kram's Avatar
Mark and fit front dowels and aft bolt holes for belly pan
(Belly pan is between fore and aft bomb bays)
ID:	2148357   Click image for larger version
Old 02-19-2016, 05:38 PM
  #198
kram
My Feedback: (7)
kram's Avatar
Belly pan dry fit, without the bomb bay doors
Old 02-21-2016, 07:06 PM
  #199
kram
My Feedback: (7)
kram's Avatar
5 hinge pockets must be perfectly aligned with each other in the vertical and horizontal planes, AND aligned with their mates on the other side, if you want the doors to open and close decently.
Getting this all lined up for both bomb bays took Dwayne, a really fast builder, an entire weekend
He says this will be the last "major building job," and all other tasks will be shorter, although not necessarily easier
ID:	2148720   Click image for larger version
ID:	2148721   Click image for larger version
Old 02-21-2016, 07:09 PM
  #200
kram
My Feedback: (7)
kram's Avatar
Fuzzy view of a little wooden support for the level tack-glued to the fuselage to minimize need for a third hand
