Reload this Page >
Top Flite P-47D Thunderbolt ARF .60-.91: Building & Mods
Old 04-17-2011, 03:38 AM
  #501
ultimate2
Default RE: Top Flite P-47D Thunderbolt ARF .60-.91: Building & Mods
[8D]Tx, tx very much buddies, for your help.
Patrick, by now I choosed a new Futaba retract servo, but I think that will be and eventually option, cause I just called to my local hobby-shop and asked for the mate Corsair JockĀ“s two servos BMS option. They donĀ“t have these servos right now, but on some days they will get avaliable. By now, I preffer this retract option, cause I think is a very clever set-up if you keep on low cost, weight and continues with mech retracts. Electrics retracts options here are difficult to find, and the idea of using the same retract with two servos and maybe a robart robostruts is also very interesting. TX very much Corsair for your help.
I flew four more flights with the Futaba servo, and until know, it goes fine..., but as I said before I want to upgrade to two servos option.
Manolo.
ID:	1594944   Click image for larger version
ID:	1594945   Click image for larger version
ID:	1594946   Click image for larger version
Old 04-20-2011, 08:02 AM
  #502
jjkirby
My Feedback: (20)
I was wandering if any of your guys out there have installed the e-flite electric retracts in this bird if so, what modifications did you have to do and any pics would be helpful
Old 04-22-2011, 09:27 PM
  #503
VooDooVW
Had the canopy off while I was fixing the "near fire" damage so I though I would take some shots of LT Oiler.
ID:	1597693   Click image for larger version
ID:	1597694   Click image for larger version
ID:	1597695   Click image for larger version
ID:	1597696   Click image for larger version
Old 04-23-2011, 04:09 AM
  #504
ultimate2
ORIGINAL: VooDooVW
Had the canopy off while I was fixing the ''near fire'' damage so I though I would take some shots of LT Oiler.
[8D]Cool, mate...[8D][8D][8D][8D][8D]
Old 04-23-2011, 06:30 AM
  #505
VooDooVW
Glued the canopy back down with Super RCZ56. The bands worked well to keep it tightso the glue can dry.
Old 04-23-2011, 07:32 AM
  #506
JayBird26
JayBird26's Avatar
Keep E'm Flying!! Lets See more pics a video!
ID:	1597802   Click image for larger version
Old 04-23-2011, 09:07 AM
  #507
ultimate2
ORIGINAL: JayBird26
[8D]Yeap buddy...., we does for it the best of my own.....
http://www.acro3d.com/public/phpbb3/...php?f=2&t=8920
Cheers.
Manolo.
ID:	1597897   Click image for larger version
ID:	1597898   Click image for larger version
ID:	1597899   Click image for larger version
ID:	1597900   Click image for larger version
ID:	1597901   Click image for larger version
Old 04-23-2011, 09:12 AM
  #508
ultimate2
[8D]I think that this is the magic of modelling this bird. To try catch something of the spirit of this warbird and what is its meaning. A fight for the mankind freedom and against the darkness, somewhat to remember a era that gone, but never must be forget,... a travel on time...
Old 04-23-2011, 10:11 AM
  #509
sbrackets
sbrackets's Avatar
Hey Gang
Check out these videos of the P-47 Thunderbolt put together out of a crate.
#1 http://www.youtube.com/watch?v=GkrUM...eature=related
#2 http://www.youtube.com/watch?v=Xvzxm...eature=related
#3 http://www.youtube.com/watch?v=EUWM-..._order&list=UL
#4 http://www.youtube.com/watch?v=gtypN...eature=related
Old 04-23-2011, 11:37 AM
  #510
bacon104
That is awesome!
Old 05-04-2011, 08:31 PM
  #511
CustomPC
CustomPC's Avatar
Hi,
What diameter prop would be closest to scale in appearance on this .60 sized plane? Would it have sufficient ground clearance?
Also, for those that have the OS .91 four stroke or something very close in dimensions and weight, did you have to add any weight to the nose of the model? Could it handle another 8oz of engine weight?
And is there more than 1/2" of clearance between the cowl and the valve covers with the .91?
The reason for my questions are that i'm thinking of the new OS FSa 1.55 purely for the ability to run larger props. I think it would look neat with a 4 bladed 16" or 17" prop
Old 05-04-2011, 09:45 PM
  #512
Chad Veich
My Feedback: (60)
Scale diameter prop would be about 20 3/8 inches.
Old 05-05-2011, 01:39 AM
  #513
CorsairJock
My Feedback: (90)
CorsairJock's Avatar
ORIGINAL: CustomPC
Hi,........................What diameter prop would be closest to scale in appearance on this .60 sized plane? Would it have sufficient ground clearance?.................
...........The reason for my questions are that i'm thinking of the new OS FSa 1.55 purely for the ability to run larger props. I think it would look neat with a 4 bladed 16'' or 17'' prop
Not trying to pick on you, because a LOT of people are doing this, but when did warbirds become categorized by recommendedengine size rathar than SCALE size? This model is roughly 1/8 scale, and categorizing as such makes it much easier to determine scale sizes all parts and compentents.
Regarding a scale size 4 blade prop: on full scale warbirds: big props meant lot's of concentration and effort to keep them going straight down the runway on takeoffs, and anytime power was applied when airspeeds were relatively low. Same thing on R/C models, only you aren't in the cockpit to get the immediate sensations of that engine wanting to twist the aircraft upside down.
Point is: having a scale sized 4 blade prop may look "neat", but it also makes it more difficult to fly. Not to mention: having a heavier engine up front doesn't help either. By ALL acounts: a .91 will fly this model with all the power you will need, and can be hidden withing the cowl with room to spare.
Old 05-05-2011, 04:41 AM
  #514
jjkirby
My Feedback: (20)
I originally had an OS 91 4-stroke then swithced to electric but now back to the 91 cause i just cant get into the electrics as much as I have tried. To answer your question yes I did have to add nose weight but then again I like my birds a little nose heavy. I also had to have about 7 clicks of down trim for level flight it wanted to climb something fierce. Once it was trimmed out it flies like its on rails, none of the typical bad warbird characteristics. Its a good plane and I fly mine with a Master Airscrew 15x6 and it flys great with no need for more power. Hope this helps
Old 05-05-2011, 06:02 AM
  #515
VooDooVW
This gets you a little closer propwise without all the added weight.
RCV120SP - 4-Stroke Model Aero Engines
3 Blade - 15.75x13
4 Blade - 15.5x12
rcvengines.com/rcv120sp.htm
Old 05-05-2011, 03:22 PM
  #516
CustomPC
CustomPC's Avatar
CorsairJock, your comments are taken on board.
VooDoo, the RCV 1.20 is 3oz heavier than the new OS 1.55
I've ran the numbers for the OS and shopped around for props and determined that a 15x6 or 15x8 4-blade prop will be the best choice for it.
Menz props are available locally but at $90 a piece you don't wanna buy the wrong one based on theoretical guesswork.
The new OS .95v or 1.10a might be better (and cheaper) choices.
Old 05-05-2011, 03:40 PM
  #517
CorsairJock
My Feedback: (90)
ORIGINAL: CustomPC
......VooDoo, the RCV 1.20 is 3oz heavier than the new OS 1.55..............
I was thinking the same thing: those RCV engines are HEAVY for thier displacement. Able to swing big props: yes, because of 2:1 gearing effect, but there is no weight savings with.
Old 05-07-2011, 06:33 AM
  #518
aquarius36
I'm flying this bird with a gas engine zenoah 20 cc and it flies like a dream. Centre of gravity is spot on. With this engine it's a rocket and very stable (still breaking in the engine so power will still increase). Landing is smooth and no flaps needed (yet). I can recommend this engine for this bird (very reliable and always starting without any hassle).
Old 05-07-2011, 06:46 AM
  #519
VooDooVW
Looks like I should have looked a little closer. I just remembered the 2:1 gearing and thought that might be a good choice.
I have a Saito 1.15 in mine with a Master Airscrew 3 blade T1490 on it. Lots of power.
Old 05-07-2011, 10:19 AM
  #520
Chad Veich
My Feedback: (60)
I will be putting an RCV .90SP into my 1/8 scale Hellcat (64" span) and hope to swing an 18 inch three blader eventually. The largest 3 blader recommended by RCV is a 15 3/4" but several guys have reported using larger ones with no issue once the engine is broke in. If nothing else I will swing an 18" two blader which will at least give me a near scale propeller arc when the engine is running. As with most warbirds my Hellcat needs nose weight so the additional weight of the RCV is a non-issue. I'll let you guys know how it goes if you're interested.
Old 05-08-2011, 01:43 PM
  #521
VooDooVW
I found the cause of the near fire today. It looks like it is my Triton jr.
The weather is finally nice so I started charging up a few batteries. Set the Triton jr. to 1350ma/11.1V and started the charge. A couple of minutes later I look over and it says it's charging at 2100ma. I thought maybe I didn't set it correctly so I stopped the charge and tried it again. Within a few seconds it jumped up to 1600ma so I shut it down. Tried it again with a NiCd pack and the same thing happened again. Within a few seconds the screen was showing over 3 times the charge rate that I had set it for. Time for a new charger!
Old 05-24-2011, 07:00 PM
  #522
P47Tbolt
My Feedback: (20)
Here is my Top Flite P-47 modified to a Razorback.Thunder Tiger 91 4 stroke with E-Gas on-board glow for power.
Pilot is Duke from Slimline. Using the Eileen nose art.Pilot who flew Eileen in WWII flew a Razorback and Bubbletop version
with the Eileen scheme.Radio is a Futaba 9C 72 mhz. When I run the receiver antennae through the antennae tube it does not
exit the fuselage.Is it ok for it to be inside the fuselage at the tail? or does it need to exit any?
here is a pic of the stick kit version I built.
Roy
ID:	1614240   Click image for larger version
ID:	1614241   Click image for larger version
ID:	1614242   Click image for larger version
ID:	1614243   Click image for larger version
Old 05-24-2011, 07:43 PM
  #523
funkymeter2003
That razorback ROCKS! Do you have photos of how you did that or templates? Also where did you get the canopy. Really nice job. I had this bird, lost it to a radio problem and ordered a new one the same day. Great flying plane but I have always been partial to the razorback...
Old 05-24-2011, 09:17 PM
  #524
Chad Veich
My Feedback: (60)
ORIGINAL: P47Tbolt
Great looking conversion Roy, nice work. The razorback looks so much better to my eye. No need for the antenna to be outside the fuselage. As long as it is extended out so that it does not cross itself anywhere you should be good to go.
Old 05-25-2011, 12:36 AM
  #525
P47Tbolt
My Feedback: (20)
here is a link to how and what I used
if you need part numbers for the wood parts let me know.
The canopy is from the Top Flite Gold Edition P-47 wood kit.perfect fit.
I think the ARF is based from the kit version and built as a bubbletop because
razorback spine involves a little more work.
http://www.rcuniverse.com/forum/m_10...m.htm#10458390
