Reload this Page >
ESM 82" Hawker Hurricane
Old 10-14-2012, 11:25 AM
  #226
affas
affas's Avatar
Default RE: ESM 82
Thanks!
Here are a picturecollection from the same day
ID:	1811192   Click image for larger version
ID:	1811193   Click image for larger version
ID:	1811194   Click image for larger version
ID:	1811195   Click image for larger version
ID:	1811196   Click image for larger version
ID:	1811197   Click image for larger version
ID:	1811198   Click image for larger version
ID:	1811200   Click image for larger version
Old 10-15-2012, 06:16 AM
  #227
Sandy69
Default RE: ESM 82
nice set pf pictures....looks like about 45 deg flap available, but looks like a lot less used in the landing picture...also, can't see any linkage for the flpas - did you hide them somehow?
Old 10-15-2012, 06:29 AM
  #228
affas
affas's Avatar
Default RE: ESM 82
ORIGINAL: Sandy69
It was a day with alot of landingcircuits and I tried different flapsettings. It was also a little crosswind and it ois easier to land with half flaps then.
When it is nice and calm condition I do use full flap which is approx 65degrees. But it is a lot of drag and very sluggish in ailerons.
The flap linkage are hidden. Servo are mounted in the flap hatch cover and then just a hole in the trailing edge, hidden with the flaps.
Pics below, the last one is weathering with alupaint. Just some airbrush and sealer to go...
ID:	1811493   Click image for larger version
ID:	1811494   Click image for larger version
Old 01-11-2013, 10:19 AM
  #229
smkrcflyer
smkrcflyer's Avatar
Default RE: ESM 82
Hi Ken
Did you get the DLE 35 mounted?
Old 01-11-2013, 10:33 AM
  #230
Tone Price
Tone Price's Avatar
Default RE: ESM 82
ORIGINAL: affas
Thanks!
WOW! This one is definitely my favorite shot:
Old 01-11-2013, 11:04 AM
  #231
glazier808
glazier808's Avatar
Default RE: ESM 82
Now that's a keeper of a shot!
Casey
Old 03-20-2013, 12:47 PM
  #232
kenair
My Feedback: (10)
kenair's Avatar
Default RE: ESM 82
HI, just ordered the DLE 35 rear exhaust version for this bird, but probably will not get around to do any work on it for a few months. If anyone else has info or photos to share, please post. cheers -ken
Old 04-15-2013, 06:44 AM
  #233
dgiatr
dgiatr's Avatar
Default RE: ESM 82
[youtube]http://www.youtube.com/watch?v=3p7cubc8WvQ[/youtube]
Old 06-25-2013, 06:20 AM
  #234
p51tom
Default RE: ESM 82
I am ready to start my ESM 82" Hurricane and need a spinner. Has anyone used the optional spinner that ESM sells. If so, is it a quality product or should I look into another brand. I am putting a DLE 35 rear exhaust and Sierra retracts in the plane. I am also going to change the elevator linkage to two servos with pushrods. I may change the tail wheel. Does anyone know where I can find pictures or drawings of the tail wheel?
Thanks, P51Tom
Old 06-25-2013, 09:32 PM
  #235
Destroyer of Airplanes
My Feedback: (25)
Destroyer of Airplanes's Avatar
Default RE: ESM 82
Tom,
I found this in my collection.
Paul
Old 06-26-2013, 12:55 AM
  #236
Johan Jacobs
Default RE: ESM 82
Hi,
I found one that I shot 2 years ago at Duxford.... hope this helps
Regards,
Johan
Old 06-26-2013, 05:48 AM
  #237
Prekin
My Feedback: (19)
Prekin's Avatar
Default RE: ESM 82
ORIGINAL: p51tom
I am ready to start my ESM 82'' Hurricane and need a spinner. Has anyone used the optional spinner that ESM sells. If so, is it a quality product or should I look into another brand. I am putting a DLE 35 rear exhaust and Sierra retracts in the plane. I am also going to change the elevator linkage to two servos with pushrods. I may change the tail wheel. Does anyone know where I can find pictures or drawings of the tail wheel?
Thanks, P51Tom
Hi, you can find some good detailed pictures in the book Squadron signal Walk around no. 14 Hawker Hurricane. Here is the link for the free download. http://www.ulozto.net/xpkeLJE/walk-a...-hurricane-pdf
Here are two pictures from the book.
ID:	1895251   Click image for larger version
Old 06-26-2013, 06:30 AM
  #238
p51tom
Default RE: ESM 82
Thanks, these photos are great. Now the hard part of making it. I made a corsair tail wheel for my ESM 73" Corsair.
P51Tom
ID:	1895255   Click image for larger version
ID:	1895256   Click image for larger version
Old 06-26-2013, 06:35 AM
  #239
Johan Jacobs
Default RE: ESM 82
beautiful job that corsair tailwheel ! compared to that the Hurricane tailwheel will be piece of cake for you
Old 06-26-2013, 08:11 PM
  #240
My Feedback: (25)
Default RE: ESM 82
Having forgotten that I have superior piloting skills and neglected to use said skills I am currently adding a new wing to my Hurricane. This time the outer wing panels will be removable. This is pretty simple really since the wing comes in three pieces anyway. I used the flaps off the old wings. On the first wing I used a torque tube to operate all four flaps with one servo. It worked well but to make the wings removable the torque tube had to part also. I used a universal joint out of an off road racing truck. I soldered one end on to a solid brass rod that was soldered into the outer wing panel. The center section has a solid rod with a flat ground on to it. To make the u joint remain straight when the wings were joined I used a piece of shrink tubing. Works like a champ. Next the lights and wiring. I'm trying to have her ready for Warbirds over the Cascades on July 20th.
ID:	1895428   Click image for larger version
ID:	1895429   Click image for larger version
ID:	1895430   Click image for larger version
ID:	1895431   Click image for larger version
ID:	1895432   Click image for larger version
Old 06-26-2013, 11:16 PM
  #241
Johan Jacobs
Default RE: ESM 82
wow nice job ! I really like the flap installation in particular !
Old 06-27-2013, 04:57 AM
  #242
p51tom
Default RE: ESM 82
I would also like to use one servo for my flaps. I was thinking of using a torque tube like the ones used for strip ailerons and use the connection for the outer flap as the plans call for. I would also install landing lights that would turn on with full flaps. What are the opinion on the ESM spinner for this model. What size wheels did you use (scale size)? I started my TW and will post some photos later.
P51Tom
Old 06-29-2013, 04:48 AM
  #243
p51tom
Default RE: ESM 82
I usually replace or reinforce the landing gear mounts on my ARFS, but these look very strong as they are. Has anyone perform any work on the landing gear mounts?
P51Tom
Old 06-29-2013, 08:17 AM
  #244
My Feedback: (25)
Default RE: ESM 82
p5tom,
Check out pages 2 and 7 of this forum for landing gear modifications.
Paul
Old 07-05-2013, 07:52 AM
  #245
p51tom
Default RE: ESM 82
Started my scale TW by bending and shaping a strip of brass. Drilled holes for axle and strut. Soldered a section of piano wire using a wheel collar for added support. Soldered a brass tube through axle holes then cut to size. Added brass tube to shape strut. I will try to load some photos today and as I complete the TW I will add more.
P51Tom
ID:	1897735   Click image for larger version
ID:	1897736   Click image for larger version
ID:	1897737   Click image for larger version
ID:	1897738   Click image for larger version
Old 07-05-2013, 08:34 AM
  #246
Prekin
My Feedback: (19)
Prekin's Avatar
Default RE: ESM 82
Nice job Tom. Thanks for the sharing your progress.
Old 07-05-2013, 09:26 AM
  #247
My Feedback: (25)
Default RE: ESM 82
Tom, When you look at it one part at a time it is really quite simple isn't it. Nice job, thanks for opening my eyes.
Paul
Old 07-07-2013, 09:45 AM
  #248
p51tom
Default RE: ESM 82
I have completed more work on my Hurricane TW. I carved 2 link halves out of hard wood and cut a section plastic tubing. I glued them together then mounted the link to the strut. I then coated the entire TW with JB Weld. This step takes some time because the JB takes a great deal of time to cure. After mixing I let it cure for about 1/2 hour. I keep an eye on it until it is firm but not too hard to spread. After coating the TW I sit for about an hour turning it so gravity lets it run where I want it. At times I do have to use a small screwdriver to shape it. After it cures I will sand and carve it to shape.
P51TOM
ID:	1898350   Click image for larger version
ID:	1898351   Click image for larger version
ID:	1898352   Click image for larger version
ID:	1898353   Click image for larger version
Old 07-09-2013, 12:11 PM
  #249
p51tom
Default RE: ESM 82
I carved the TW to the proper shape. I will add some details then work on mounting it. I will replace the original TW mount and make mine with a spring loaded strut. My strut is made from 5/32 piano wire so I think it would be a good idea to give some relief. The photos did not come out very clear with the white primer.
P51Tom
ID:	1898886   Click image for larger version
Old 07-10-2013, 06:36 PM
  #250
p51tom
Default RE: ESM 82
Finished shaping the TW then added some nuts and screws for detail. The TW is not true scale but looks good from a distance. I am working on the method of mounting it to the model.
P51Tom
ID:	1899305   Click image for larger version
