Reload this Page >
NEW Top Flight P-40??? 1/5 scale
Old 07-17-2017, 09:22 AM
  #1801
rowdog_14
rowdog_14's Avatar
Originally Posted by Lifer
There is always the option of slightly rotating the engine to gain clearance within the cowl for the muffler. In many instances, even a factory muffler can be made to clear.
yep I agree, but I have already setup everything per manual and do not feel like adjusting at this point.
Old 07-17-2017, 09:55 AM
  #1802
Lifer
Lifer's Avatar
I understand. Rotating the engine can be a pain to do.
Old 07-25-2017, 05:38 AM
  #1803
rowdog_14
rowdog_14's Avatar
My plane is ready to fly but I have a 22x8 prop on the DLE 55. I noticed everyone is running a 22x10. I would like to get the plane in the air but not at the expense of crashing because of the wrong prop ... Has anyone ran a 22x8 prop on this plane. I tried searching but came up with nothing.
Old 07-25-2017, 06:15 AM
  #1804
ForcesR
The 22x8 is the correct prop for the DLE 55! I have 22x8 props on both my DLE powered TF P-51 and ESM Spitfire and they provide more than enough thrust to fly the WWII fighters the way they were designed to fly. You can always change to a 22x10 when you require a little more top end speed but then you lose a bit of prop braking power on landing with the 22x10.
Old 07-25-2017, 06:32 AM
  #1805
rowdog_14
rowdog_14's Avatar
Ok thanks, I have a Xoar 22x8 on the P-40 and I have a P-47 with a APC 22x10 that flies it around nice. I will try the 22x8 Since it is a newer engine with only a tank ran through it and try the 22x10 from my P-47 if I do not like the 22x8.
Old 07-27-2017, 04:35 AM
  #1806
rowdog_14
rowdog_14's Avatar
Stainless steel safety wire, where to get locally? I have searched a few places but I have to order. I am trying to get some safety wire for my exhaust bolts and seem to not be able to find any locally instock. Suggestions....
I threw away the wire for the rudder that came with the plane and could have used it
Old 07-27-2017, 11:07 AM
  #1807
chris923
My Feedback: (53)
I wire all my muffler bolts with 2-56 rods thru holes I drill in the sides of the cap bolt head. Then just bend the ends down. This makes it very easy to remove if need. I have been doing this for many years and my mufflers don't loosen up.
Old 07-27-2017, 11:35 AM
  #1808
rowdog_14
rowdog_14's Avatar
I found some wire at Advance Auto.
Old 07-27-2017, 01:12 PM
  #1809
Lifer
Lifer's Avatar
Just out of curiosity, are you using the gasket on your muffler?
Old 07-27-2017, 01:30 PM
  #1810
rowdog_14
rowdog_14's Avatar
Yes I am. I read people use RTV but I decided to use the gasket. Will see how it goes inaddtion to the security wires.
Old 07-27-2017, 01:33 PM
  #1811
chris923
My Feedback: (53)
With the wire, the gasket is all that is needed.
Old 07-27-2017, 04:03 PM
  #1812
Lifer
Lifer's Avatar
I quit using the gaskets years ago. Permatex copper and high-temp red threadlocker. Zero loose muffler issues....for years.
FWIW
Old 07-28-2017, 05:09 AM
  #1813
rowdog_14
rowdog_14's Avatar
I guess the RTV provides a better means of dampening with the vibration. I installed the jtec muffler with the factory gasket, factory bolts and red locktite...bolts came loose with with just a quick sound check of the Jtec muffler. I have not had any issues with the same combo on my other DLE with factory muffler. Either way I think I should be good since I have the wire in the bolts now. Ran it up yesterday and did a range check, especially since I am still running 72 on a gas setup . All was well with the bolts and range check. Hope to probably take the plane up next week.
Old 07-28-2017, 07:48 PM
  #1814
rowdog_14
rowdog_14's Avatar
Well balanced it out today. Without the retracts and with the fixed gear I balanced it out with about 5.25 oz on the tail. Total weight is about 19.5 lbs with the DLE 55, jtec muffler, futaba s3010, nimh 4500 mah RX battery, nimh 600 mah ignition battery. Hopefully next year I will get the retract main and tail gear.
Old 07-29-2017, 12:22 AM
  #1815
Lifer
Lifer's Avatar
Surprised to hear it needed that much weight in the tail.
Old 07-29-2017, 03:05 AM
  #1816
rowdog_14
rowdog_14's Avatar
i was too but I am guessing it is because I did not do the retracts. I am sure when I do the retracts next yer it will balance nice.
Old 07-29-2017, 04:28 AM
  #1817
Lifer
Lifer's Avatar
Never considered that!
You'll love the way it looks in the air. The plane has a lot of character and nothing else looks like it on a fly-by. My only recommendation is use factory low-rates to fly, and keep the speed on approach a little higher that you think it needs. 2-point landings are the best with this design. I studied about a dozen Youtube videos to learn its landing habits. The videos by Sam Fawaz and a guy named Affas are the best examples, in my opinion.
My oldest T.F. Giant P-40 is had its' 8th birthday. Not bad for a warbird.
Old 07-29-2017, 06:04 AM
  #1818
rowdog_14
rowdog_14's Avatar
Cool thanks and I will check out those videos.
Old 07-29-2017, 05:04 PM
  #1819
bhorton
My Feedback: (26)
Rowdog, I would want bigger battery on ignition. I had a 50cc engine that would not start using a 700mah battery. It would be bad to have the engine die in the air because of the ignition battery.
Old 07-29-2017, 06:37 PM
  #1820
rowdog_14
rowdog_14's Avatar
I have a 750mah in my p-47 that has a DLE55. I have done 4 flights and still had plenty left. I think the 600 will be fine for test flight but yes I am going to add a 750 into the P-40 too. My 600 though starts the engine just fine and rpm's are great.
Old 07-30-2017, 10:21 AM
  #1821
bhorton
My Feedback: (26)
Sounds good. My experience with the ignition batteries was several years ago with another brand of engine..Good luck with the maiden flight.
Old 07-31-2017, 03:19 AM
  #1822
SWORDSN
My Feedback: (13)
Great tip
Old 07-31-2017, 07:36 AM
  #1823
rowdog_14
rowdog_14's Avatar
Anyone using solid tail wheel controls with ball links on the tail wheel end versus the control wire?
Old 08-02-2017, 06:16 PM
  #1824
rowdog_14
rowdog_14's Avatar
Well took the plane up for first flight today. Flew like a dream. Only issues
1. I took off too slow on first takeoff and it did a hard turn left, so had to abort
2. Had the factory fixed gear in and one bent a little causing the left wing to scrape the ground after landing.
Forgot to add in some down trim for full flaps
Yes looked great in the air even with the fixed gear!!!!
22x8 flies it great. I think I will probably stick with the 22x8 at this field since it is a smaller field. Maybe try a 22x10 at a larger field.
Now want to get the Corsair, LOL
The 600 held up good. 1 long flight and 1 short I have 4.88 volts on the battery. I could probably get one more short flight out of it. I am done flying it and need to save up and get the landing gear and a pilot. When I get those I will get a 750mah battery like what is in my P-47.
Name:	Photo Aug 02, 8 15 13 PM.jpg
ID:	2226622   Click image for larger version
Name:	Photo Aug 02, 7 43 26 PM.jpg
ID:	2226623   Click image for larger version
Name:	Photo Aug 02, 8 15 43 PM.jpg
ID:	2226624   Click image for larger version
Name:	Photo Aug 02, 7 43 04 PM.jpg
Old 08-03-2017, 04:30 AM
  #1825
rowdog_14
rowdog_14's Avatar
First takeoff 🛫
