Redcat Racing Volcano Thread
#351
CA
RE: Redcat Racing Volcano Thread
i was going to take a pic of it right now and post but i Forgot Truck in my car.... after i get back from the GYM.. ill bring it in and take a pic....
#354
I changed out the radio, reciever, and servos on my Volcano SV. I replaced them with the Spectrum 2.0 radio, reciever and servos. The throttle and steering response is much better. The truck also has a lot better turning radius and can go out as far as I want. The radio that comes with the truck is garbage. I guess it gets the job done if you just want to stay within 20 feet and not have very good control over the truck. I'm not bashing the truck, the truck is awesome, just a crappy radio.
#355
My suspension travel is crushing my dogbones. I've orderd the cvds, but they are too long and also get crushed. I've limited my suspension travel by putting spacers into my suspension, but would like full travel and am wondering if you can recomend shorted cvds? 08046 is the cvd I ordered, but they won't come even close to fitting in the rear.
Thats odd. Ive got a Volcano SV. I put on T-Maxx shocks (slightly more travel than Stock) and my dogbones have enough endplay throughout range of suspension.
#358
its a slide carb, you need a rotary carb to make it easier to install, if its a .18 or smaller it should fit, you also have to make sure it has a standard crank on it too.
#361
#362
I'm bending dogbones constantly, and I'm breaking axle ends left and right! The dogbones I buy are ae and are about 1.5mm shorter then I put a spring inside to keep them in the outer cups. I need cvds, but redcats are too long and won't allow full suspension travel in the front and nearly any in the rear! Does redcat or hpi or anyone make a cvd that is about 2mm shorter then the redcat p/n 08046?
#363
what rc do you have that keeps bending and breaking dogbones? i have had my volcano stx and tornado xp for 2 years and never broke or bent a dogbone
#364
An exceed dynamite. If you crush the front suspension, the dogbones bottom out and bend. I've tried their universals, but they are too long as well. Any ideas.
Livlrge
Livlrge
#365
did you put a small piece of fuel tubing in each drive cup to take up the slack? you need to leave a little slack but you need to keep it even with 2 pieces of tubing
#366
My volcano SV transmission gears teeth are all ate up, from when I took the engine off and put it back on. How do I know where to realign the engine where it won't happen again.
#367
My Feedback: (15)
NV
i just recently bought my son a volcano stx ...the radio that came with it is basically junk..
i am new to the whole rc thing ivebeen lookin on ebay for a new radio but really dont have a clue !!
if any one could help me out here that would be great
#368
TN
#372
TN
Most of the remote cars you get will have 27mhz crystals, which can only be used with a 27mhz transmitter and receiver, thats why I upgraded my transmitter and receiver to a 75mhz, it allows you to drive it at a farther distance and used my same servo's till I got new one's, which by the ebay link I posted gave it all transmitter receiver and servo's. I'm not sure of the mhz though 75 or more is what you want.
