Redcat Monsoon Thread
#402
KS
RE: Redcats Monsoon Thread
anyone have an issue with the mesh between the clutchbell and diff gear going to crap and stripping both gears? I had this happen to me yesterday(that is the second time now), and everything is just as tight as when I put it all back together. The main issue I see is that I can't push the clutch bell any farther in. and the mesh between the 2 gears is all the way towards the back of the clutch bell. What is the deal with this?
#403
I had to re-shim my clutch bell, I did so before I blew out my gears.
I also noticed the slots in the chassis are barely long enough to get the correct mesh.
You may have to file out the slots a bit to close up the gap between gears.
I am runing a 10 tooth clutch bell.
If you run a bigger bell gear it may help with the problem but I like the 10 tooth bell.
Dusty
Dusty
#404
does anyone know if the kyosho st-rr hub x-tensions wil work on the monsoon......i know that the ofna do........just wondering about the hex pin and axle will work. thanks
#405
KS
I was running the 10 tooth until it stripped, and then I went with the 12 tooth. I have gotten lucky so far and that one hasn't stripped, although I have had some minor issues that made it start to strip. I was pretty happy with my 10 tooth as well, until I got the 12 tooth, and I like it a heck of a lot better.
#406
Just a note on the 10 tooth, I'm running the monster truck wheels, thay are larger raising the gearing.
I take my bell apart to clean and lube the breaings after about 5 times running the vehicle, a lot of grit gets in the nose of the bell.
There is a thread on alternative clutch bell parts to run in here somewhere already.
There are several different options for parts, just have to find the thread!
Dusty
Dusty
#407
KS
I am running the stock rims on mine. I went and ran mine for a little today, and smacked a utility pole and busted a lower a-arm. Luckily I had a spare, so it will be a quick fix.
#408
ORIGINAL: vnmsgt
Here is a upgrade for the differentials in the monsoon. Some people have problems with them stripping out the ring gear. I installed CEN Matrix ring and pinion gears part #MX040 and MX037. The truck rolls smooth as glass now just like my ST-RR and Hyper and does not have the grinding noise and notchiness of the stock gears when you roll the truck. A friend did this to a Hurricane buggy and it ran 10 times better with this upgrade so I figured I would try it since I just stripped my ring gear.
Damn, you guys have totally got me convinced the Monsoon is the better buy over the Avalanche. Do a couple simple mods and this truck should be hard to touch.
Edit - and did you ever sell your truck? [8D]
#409
IA
Has anyone had problems with the front hubs strippin out during racing on big tracks with good size jumps? I have made sure they were tight and lock tighted but they continue to strip. Does anyone have a suggestion? That is the only issue I am having. The truck is great and I am winning just having that little issue. I want to go buggy racing but this issue is shying me away from the hurricane. I have a chance to pick up a kyosho inferno team addition on trade might go that route.
#410
simple fix...use screws approx. 4 to 5 mm longer..screw em all the way in to make sure the clear the drive shaft...then take em out and put a drop or 2 of tire glue (krazy glue) on the threads and put them in and tighten them up....after I've done this I havent had a problem since
#411
ORIGINAL: bigdaddywoo
http://www.thorintl.com/Helicoil%20S...%20Inserts.htm
#412
IA
RE: Redcat Monsoon Thread
Hey everyone just thought I would share my racomg setup with all monsoon owners. my camber is-2 f/r. toe in front +1 the rear -3
my diffs 7000f 10000c 3000r. also grease pinion gears with mugen high temp grease " lithium grease can be used also. I added a front sway bar. The two clips that hold the sway bar in place had to be bought seperate and they came off a ofna crt truggy. I added side protectors to the chasis. I found these also help getting air when jumping. The rear wing I have the rear of it as high as it can go. Do this and watch it rip in the straights. Scrape the tires and get yourself some proline hole shots make sure your rims you purchase have the same offset as factory. Losi rims work perfect. servos I run hitek hs-5985 steering and hd-5965 throttle. I have the spectrum 2 but spend the extra and get the 3. Oh add rear universals and greased all four with mugen grease. Make sure you lock tight everything that goes into metal. The only problem I have had was with the hubs in front the screws stripped out on me twice Redcat is currently working on the problem so hold tight. I have had a couple suggestions u can try helio coils our use a longer screw and add a little tire glue. I am tempted just to use some red lock tight and call it a day. u can still get it loose u just have to heat it up. Redcat please hurry!!!!! Well there you are. I am running a novarossi .28 8 port turbo engine but I also have the axial .28rr and that motor is also a beast.
#414
i purchased a redcat monsoon just recently and was wondering if the engine it comes with is the same old sh.28 that had so many problems coming undone and overheating!
#418
I'm pretty sure they haven't changed the engine, but by all accounts the SH is a really stout piece. Lots of good feedback, but like any engine there's going to be a few that don't have the quality. They're machined to 1/10000 of an inch in some cases, and a LITTLE bit off that is going to cause unacceptable slop or too much interference, and the engine is junk right from the factory.
From what I've been told, the only real recurring issues with the SH 28 is the leaking front bearing and LOTS of power - er, fuel consumption.
#419
well i guess we will just have to see! i am in the process of looking at other cars for my kids to race and make a full blown family hobby out of THIS of course the buggy,s are of the redcat variety!
#420
WA
Well been a while, I lost the pinch in the SH28 so I picked up a axial 28 1s for a back up motor till my piston and sleeve get repinched, now I'm thinking I'll keep the sh28 as a back up not that its a bad engine it's not it's been a really good engine but I'm really liking this axial a little better, with the axial I was getting a lot of wheel spin with the 10 tooth bell lot more then the sh ever did the axial was topping out in less then 50 feet with temps in the 250s I ended up going with a 14 tooth bell now it handles real well still has good low end and nice top end even lowered my temps by 30degs. havn't broke anything other then the pinch in a long time on this thing hmmm may be I should be running harder...
#421
AB, CANADA
I just finally got a proper tune on my monsoon the grub screws moved on the linkage(yes no lock tite my bad) they are now, was a pain to fix cause the brake linkage was screwed up too. Now that it's running properly this thing is scarry fast. I ended up in a neighbors yard 4 houses down and nailed 2 4x4 wood trim around thier spruce tree I cleared the 4x4's and landed on the flower bed under thier window( my steering servo stripped again) they just laughed about it. I went out tonight and bought her some more flowers and offered to help replant. Truck is fine lol flowers not so good.
#423
FL
The SH motors in the monsoons never had any problems. I had one of the first monsoons when they came out. It was the SH motors in the CEN Matrix's that were bad. I have had a ton of SH motor's, all out of Redcats and they are great motors.
#425
i just received my redcat tornado exp does anybody know how long the charge time is with the stock batterey charger? cant find this information anywhere. would appreciate any help i can get!
