Redcat Racing Support Moderated Support Forum for all Redcat Racing Cars, Trucks & Buggies
Kerosen
Old 04-08-2008, 06:03 PM
Cam_132
Cam_132's Avatar
Default Kerosen
Will our nitro engine's run on kerosen? with castor oil added ofcorse!
Old 04-08-2008, 06:12 PM
Kemo
Default RE: Kerosen
methanol with nitromethane and castor oil only.
Old 04-08-2008, 07:41 PM
firebird78
Default RE: Kerosen
I wouldnt know why u would want to try...lol....
Old 04-08-2008, 07:43 PM
need2drag
Default RE: Kerosen
I am guessing because kerosene is cheaper than nitro....I don't know though. I wouldn't want to try it.
Old 04-08-2008, 08:25 PM
Kemo
Default RE: Kerosen
the next best thing that engines may soon be running on is ethanol. OS was the first to make an ethanol rc engine for planes.
Old 04-08-2008, 09:42 PM
Cam_132
Cam_132's Avatar
Default RE: Kerosen
Well i guess you could use kerosen and ethonal and castor oil.. or just ethonal and castor oil... i will try that...
Old 04-08-2008, 09:45 PM
Kemo
Default RE: Kerosen
these engines are designed to only run on methanol
Old 04-08-2008, 10:56 PM
jumpanddrop
Default RE: Kerosen
lol, my friend put gassoline in his nitro lol. it did nothing. we have put a 50/50 mix of gasoline and 20%nito in his dirt bike and man did that thing ripp(well untill we blew a headgasket)
Old 04-09-2008, 12:01 AM
Cam_132
Cam_132's Avatar
Default RE: Kerosen
ORIGINAL: jumpanddrop
HA HA HA HA HA... that stuff is liquid NOS!
lol i should try that in my go cart! it is alredy a 13Hp Power fist brand i got at Princess auto! for about 350$ with electric start free!
But i will only put 25 nitro 75 gas mix! That will go!
Old 04-09-2008, 12:29 AM
el_tonto
Default RE: Kerosen
The methanol reacts with the glowplug to provide the spark, the nitromethane is for a bit more kick and also to ease tuning. Petrol for instance requires a air:fuel mixture between 16:1 (very lean) and 12:1 (very rich) - a fairly narrow range. Nitromethane on the other hand has a much wider range, as rich as 2:1 and as lean as 6:1 I believe, and it will still burn - so it's extremely tolerant of a wide range of tune, which is good because keeping the mixtures within a tight range over a wide rev/throttle range is difficult.
Planes - on the other hand - work over a smaller rev/throttle range and many can run with 0% nitro. But without that additive to widen the range of mixtures that the engine will run, they are probably more difficult to tune and run well only over a smaller rev/throttle range.
