Go Back  RCU Forums > RC Airplanes > Pylon Universe - RC Pylon Racing > Scale Racing
Reload this Page >
Ballerina 1/3 scale by hacker-model.com
Scale Racing Discuss all aspects of semi-scale pylon racing.
Old 01-19-2013, 09:12 AM
gadix
gadix's Avatar
Default Ballerina 1/3 scale by hacker-model.com
hello to all
i have just got my wet dream!
60cc gas Ballerina 1/3 scale , made by Hacker-model from the check Rebq'
i'm using a JC 60cc gas, all servos are CS-150, TH-HT645 and RUdd is HT5645
the manual, if u can call it like that is very poor...
is anyone here ever build this model?
can i get some help please for the construction part?
my concern is for the tail part, Ver-Hoz stab's and the correct actual CG. recommended is 90mm aft leading edge.
here some links and pics
thanks
gadi
http://www.zoomport.eu/Kits-and-Acce...263340400.aspx
http://www.zoomport.eu/Images2/ballerina-parts.jpg
http://www.zoomport.eu/images/xx_Cos...rina_02_xx.jpg
http://www.zoomport.eu/images/xx_Ballerina%20_01_xx.jpg
Old 02-02-2013, 01:02 PM
gadix
gadix's Avatar
Default RE: Ballerina 1/3 scale by hacker-model.com
well?
anyone??
Old 02-02-2013, 04:39 PM
Racewizard
Racewizard's Avatar
I have never built that particular model but I have built a 1/3 scale Cosmic Wind which that is. What is the wing span in inches? Here are a couple pictures of mine, it's powered with a Zenoah GT 80
Babe
ID:	1847280   Click image for larger version
ID:	1847281   Click image for larger version
Old 02-02-2013, 09:16 PM
jeffk464
ORIGINAL: gadix
well?
anyone??
Its cool, but not a US supplier.
Old 02-03-2013, 08:54 AM
dasquirrelisme
My Feedback: (81)
Those are badass! One of these days I will have one but no time soon [&o]
Old 03-18-2013, 02:07 AM
gadix
gadix's Avatar
hello
cool model, is it Hacker made?
mine is Hacker made, with 1900mm wing span so in Inch it wouls be 74.8~in.
untill now, all my work on the model was on hold as i suffered CRAZY back pain and spinal disk issues...so it is very difficult to work on my models
i feel better now and will continue the work hoping this week by installing the engine->cowl followed ny the rear servos as i want it to be perfectly balanced
so all the rest interior EG fuel tank, radio, Batt ...etc will be after that while making sure the CG is on the spot at all times.
CG is 90mm beyong leading edge of the wing acording to the manual
BUT, you never know till you get it up to the air...
my rule is , to keep it by the book, than make just a bit, nose heavey, go up...and than move the battery FwBw to get the perfect CG per the model performances.
i want to use a basic prop 23X10 for my JC60cc engine - that will get me up to 200KMh...
if i will use the racing props EG 19X16 - it will get me up to 250Kmh and each landing would be with engine cut as must, as it wont slow down.
what prop do you use on the G80?
did you convert the G80 to nitro? i know that at the time , modelers use to convert a bog GAS engines such as the Zenoha 80 to Nitro , which produces much more power with less weight , no ignition or magneto...
i'm adding the PDF here so you can get you impressions
happy landings
Gadi
ID:	1863345   Click image for larger version
ID:	1863346   Click image for larger version
ID:	1863347   Click image for larger version
File Type: pdf
Old 05-04-2013, 11:09 PM
gadix
gadix's Avatar
hello againworking on the Ballerina again, after suffering from mt back for the past 4 month...! oouch!
to be honest
this model is not an ARF...as theres a lot of work to do and lot of rethinking as well...
some defects that i found:
1. the main Alu bom was longer by 5 mm, so when the wings are attached, theres a 4-5 mm gap to the fuse...see pic...so i had to cut 4.2 mm from the boom
2. ELEV install is a crap! it is mounted to the fuse with 2 bolt and blind nuts while the nuts ar on the ELE surface, on top of them comes the RUDD... to everthing needs to be calculated percicly prior to any drilling, glueing...
3. the inner cover o fthe fibergalss isnot glued well to the composite fusealeg, to each cut that id on the fuse... servos, htacj and so on, i need to glue the the edges with Q glue..
until now i have done the following:
1. install the tail LDG
2. make room for 2XELEv servos and 1X Rudd Servo
4. cenetr line the ELEV with 2 VIA holes for the bolts and blind nuts
5. install wings
6. short the wing boom by 4.2 MM to compensate on the gap btween the wing and fuse.
see pics:
Old 05-07-2013, 01:19 PM
gadix
gadix's Avatar
pics are here..hopefull as RCU have problems of uploadibg pics...
ID:	1880016   Click image for larger version
ID:	1880017   Click image for larger version
ID:	1880018   Click image for larger version
ID:	1880019   Click image for larger version
ID:	1880020   Click image for larger version
ID:	1880021   Click image for larger version
ID:	1880022   Click image for larger version
Old 05-07-2013, 01:23 PM
gadix
gadix's Avatar
today i have manged to install the ELEV stab, still need to line with the wings A=A...!
then, to gkue on top of it the RUDD stab, while makeing 2 slots where the eleb stab blind nuts are..
glue in place the servo wood pieces...install 3 servos ...2Xelev and 1X Rudd...run the wires...
the main problem is the engine as it is a double firewall....
but this will be next week..
gadi
Old 05-12-2013, 11:16 PM
gadix
gadix's Avatar
shalom to all
here some more pics of the intensive work on this model which is not AN ARF!!!!
lot of sbading and modifications is needed.
3 rear servos were instaled lateley togather with the hatch locker for the canopy, the rear side of the canopy will be tighten with lock nuts on the canopy and 3/32 bolts.
i didi a mistake with the servo positions place - as i did it identecaly paralel to each other -> ELEV to ELEV-> a noraml servo wont fit in as they will touch each other...
so i will use HITECH BB77 which is 5.5Kg@6V per each ELEV surface, should be effcient
enjoy the pics and thank you for watching
comments are welcom
Old 05-21-2013, 10:50 AM
Scaleman3
Did not see latest pics on Hacker build, looks good so far from pics on the 7th. Your rt., it's not an ARF as we know today but it will look good when done, and a lot of experience during the build, will follow.
Scaleman3
Old 05-21-2013, 01:22 PM
gadix
gadix's Avatar
THX
RCU have a problem of uploading pics
sometimes it works and most not []
will try again though
gadi
Old 06-19-2013, 12:01 AM
gadix
gadix's Avatar
hello to All
step by step .. i'm getting there...
landinggear was installed as well as wheel pants
both wings servos and servo covers , pushrods, H.D 4-40, and ALIE installed as well
main canopy hatch . latch and locking screws installed.
will load more pics soon
thx for watching and please comment
Gadi
ID:	1893120   Click image for larger version
ID:	1893121   Click image for larger version
ID:	1893122   Click image for larger version
ID:	1893123   Click image for larger version
ID:	1893124   Click image for larger version
ID:	1893125   Click image for larger version
ID:	1893126   Click image for larger version
ID:	1893128   Click image for larger version
ID:	1893129   Click image for larger version
Old 06-19-2013, 12:04 AM
gadix
gadix's Avatar
some more pics:
see the ELEV stabilizer install - that was a chalenge
ID:	1893131   Click image for larger version
ID:	1893132   Click image for larger version
ID:	1893133   Click image for larger version
ID:	1893134   Click image for larger version
Old 06-21-2013, 02:28 AM
gadix
gadix's Avatar
Hi there
work is in the fast lane...
had some spare time to do some cosmetics...
have some issue with the engine mount as the original base is too smal in surface for the standoff's...!
i guess i'll need to buld a new wooden box from scratch! i hate when parts dont fit
ID:	1893733   Click image for larger version
ID:	1893734   Click image for larger version
ID:	1893735   Click image for larger version
ID:	1893736   Click image for larger version
ID:	1893737   Click image for larger version
ID:	1893738   Click image for larger version
ID:	1893739   Click image for larger version
ID:	1893741   Click image for larger version
Old 06-23-2013, 09:58 AM
yaron_k
My Feedback: (45)
Hi Gadi
Looking good
My El-Bandito flies realy great. We have measurred app. 190 KmH on a streight and leveled flight, with a rich-set engine, and with a JasProp 20*16 propeller
Waiting for your maiden
Yaron
Old 06-23-2013, 02:45 PM
gadix
gadix's Avatar
on going work...
trying to align the engine and cowl...will need a extra hand as it is difficult to do alone
ordered 40mm standoffs so the hights of the cowl edge and the spiner plate wont wont eceed 2 mm...
fuel tank is ready as wll as the "air flow" inner diverters, id di cut some VIA on the fuse for the AIR FLOW, will finialize after engine is intslled though...
canopy is done as well...
enjoy the pics
ID:	1894474   Click image for larger version
ID:	1894475   Click image for larger version
ID:	1894476   Click image for larger version
ID:	1894477   Click image for larger version
ID:	1894478   Click image for larger version
ID:	1894479   Click image for larger version
ID:	1894480   Click image for larger version
Old 06-29-2013, 10:01 AM
Scaleman3
Looking good!
What size wheels and fuel tank did you use?
Old 06-29-2013, 10:09 AM
Scaleman3
How did you attach the blind nuts, screw them down from the opposite side, or?
Old 06-29-2013, 10:35 AM
gadix
gadix's Avatar
Tank is 950cc
Wheels 5" du bro
It was hell to do the bolts for the elev...need to do via the fuse with leading tubes...
Do you have one like this? ?
Old 06-29-2013, 10:37 AM
gadix
gadix's Avatar
The nuts for the landing gear is easy. ..
Old 07-01-2013, 09:32 AM
Scaleman3
Watching your build and then maybe geting one from RCBaron.
How did you install the blind nuts, screw them down into the wood or pound them into the wood?
Old 07-03-2013, 07:12 AM
gadix
gadix's Avatar
Mate
which blind nuts you refer to??
the ones for the main gear were punched slowly while tighting the bolt from above - as always
gadi
Old 07-07-2013, 01:56 AM
gadix
gadix's Avatar
hello to all
have did some progress with the engine mount...took a while as the original stands are longer than the distance you will need to be clear with the cowl and spinner plate...should be 20.7 mm!!
this is the smalles gap i could get as the engine mounts and air/fuel needls should have good accses...!
did some dremel-ing for cowl and air cool passes in the fuse...
also, have uinstalled "toilet setting lid" as the wing bolt to the fuse - works great!! very cheap at any DIY
enjoy
ID:	1898282   Click image for larger version
ID:	1898283   Click image for larger version
ID:	1898284   Click image for larger version
ID:	1898285   Click image for larger version
ID:	1898286   Click image for larger version
ID:	1898287   Click image for larger version
ID:	1898288   Click image for larger version
ID:	1898290   Click image for larger version
ID:	1898291   Click image for larger version
ID:	1898292   Click image for larger version
Old 07-31-2013, 03:58 PM
gadix
gadix's Avatar
hello again
the Racer is 95% complette!!!!
engine +Ignition+fuel lines is in place+TH servo and pushrod+choke pull mechanisim
( AS THE JC60 EVO IS MOUNTED SIDE WAYS RT-> IT WOULD BE RECOMNDED TO USE A TWING BOXER ENGINE INSTED!!! THAT WAY LESS WORK ON COWLING AND KEEPING THE NICE SHAPE AND FIGURE!!!
muffler and cowl are placed and cut/trimed acordingly
Rudd+Elev sevos and pushrods are in place and calibrated+Tail wheel
TX+wires+Opto cut off unit+IGI batt NIMH 2600Mah are placed.
Vertical and horizontal stab cover was removed and replaced with wite silicon pate +screws insted of CA glue as originaly!!!
need to do:
1.CG!!
2. LIPO 3000 Mah 40C location - per CG
3. on-off SW X2 -> Main+Ignition
break in and test flight....
see the pictures
ID:	1905095   Click image for larger version
ID:	1905096   Click image for larger version
ID:	1905097   Click image for larger version
ID:	1905098   Click image for larger version
ID:	1905099   Click image for larger version
ID:	1905100   Click image for larger version
ID:	1905101   Click image for larger version
ID:	1905103   Click image for larger version
ID:	1905104   Click image for larger version
ID:	1905105   Click image for larger version
