Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Amadeus
Old 06-28-2015, 12:01 PM
RodneyFord
RodneyFord's Avatar
Default Amadeus
Time for a new F3a model. Electric this time. Working name is Amadeus. The fuselage will be molded and the wings balsa on foam. I will cover the molding process, which is something not seen here much.
ID:	2106188   Click image for larger version
Old 06-28-2015, 12:42 PM
RodneyFord
RodneyFord's Avatar
Here are some dimensions.
Old 06-28-2015, 02:07 PM
RodneyFord
RodneyFord's Avatar
I will go through the process I use to make a composite fuselage. I'm up to about 10 now, the last 2 were 40% IMAC so this one is relatively small.
I dimension the drawing at 100mm stations and transfer it to 6mm MDF. The off cut will be the splitter plate, more on that later.
ID:	2106217   Click image for larger version
ID:	2106218   Click image for larger version
ID:	2106219   Click image for larger version
Old 06-28-2015, 02:33 PM
ppljr
My Feedback: (94)
ppljr's Avatar
Nice. Be watching with interest.
Old 06-28-2015, 02:37 PM
RodneyFord
RodneyFord's Avatar
From this point I will use different methods to build the fuselage shape. My first plan was to cut 100mm long cross sections derived from the Solidworks model. However I wasn't entirely happy with the shaping in solidworks so I am going to do the shaping free hand using profile gauges to get symmetry. I did use the CNC foam cutter to do the top view though.
ID:	2106221   Click image for larger version
Old 06-28-2015, 02:49 PM
RodneyFord
RodneyFord's Avatar
Vacuum bagged the other side on. Am using PU glue as it is fairly fast gap filling and works well in the vacuum bag. I have 2 vacuum pumps. This one is for white foam as is a diaphragm pump and is happy running at reduced pressure (5psi here) so it doesn't collapse the foam. The other pump is an oil filled vane pump for composites in molds and is best run at full vacuum or the oil drains out.
ID:	2106223   Click image for larger version
Old 06-28-2015, 03:03 PM
RodneyFord
RodneyFord's Avatar
Trimmed of the outline with a hand held hot wire. Powersupply is a transformer on a light dimmer.
Started roughing out the shape with a bread knife.
ID:	2106227   Click image for larger version
ID:	2106228   Click image for larger version
Old 06-28-2015, 03:09 PM
RodneyFord
RodneyFord's Avatar
The canopy/hatch got cut out of the profile and foam glued to it.
Old 06-28-2015, 03:23 PM
RodneyFord
RodneyFord's Avatar
The fin is built up for accuracy. I use Profilli pro for my airfoil work. The airfoil is SD 8020 with the trailing edge thickened to a blunt 6mm and the root high point moved back to blend into the fuselage. The solidworks model helped to visualise the fit. Once the design was sorted out I printed out the ribs and used a glue stick to attach the printouts to the balsa. Lots of ribs for stiffness. Also made some leading edge templates for accuracy.
ID:	2106235   Click image for larger version
ID:	2106236   Click image for larger version
ID:	2106237   Click image for larger version
Old 06-28-2015, 03:27 PM
RodneyFord
RodneyFord's Avatar
Did some rough sanding. 40 grit in one hand and vacuum cleaner in the other. Foam can get messy real fast.
Old 06-28-2015, 03:32 PM
RodneyFord
RodneyFord's Avatar
Added the hatch base. This is the zero line to set everything from.
Old 06-28-2015, 03:41 PM
RodneyFord
RodneyFord's Avatar
Used the canopy base to set the nose angle at 1/2 degree. There will be no right thrust as the model will have a contra drive or use throttle to rudder mixing if only one prop.
Old 06-28-2015, 04:08 PM
RodneyFord
RodneyFord's Avatar
Glued on the nose ring. Triangulated it for squareness.
Old 06-28-2015, 04:59 PM
RodneyFord
RodneyFord's Avatar
Gluing the canopy base on.
Old 06-28-2015, 05:45 PM
ppljr
My Feedback: (94)
ppljr's Avatar
What was wrong with the shaping in Solidworks? I have had good success with Rhino 3d.
Old 06-28-2015, 06:18 PM
RodneyFord
RodneyFord's Avatar
Solidworks is great. Use it for the 3D printer. For this kind of flowing curve shaping I think Rhino might be better, you know pulling it around with handles. Especially the nose area which is going to be quite complex. I am pretty comfortable with eyeballing it freehand, I think I will get a better result.
Talking about the 3D printer, I will use it to make some parts. I am thinking of inserts to go into the mold for air exhausts. Spat and leg patterns. Am experimenting with nylon filament with a view to doing the 95mm spinner.
Old 06-28-2015, 07:15 PM
RodneyFord
RodneyFord's Avatar
Did some rough shaping on the lower nose area. Actually nothing complex here, just want it fairly low drag and smooth here to get the air moving down the fuselage easily. Not worried about taking off too much foam as it is easy to build up later with bondo after it gets glassed. Much harder to take glass away and redo it.
ID:	2106277   Click image for larger version
ID:	2106278   Click image for larger version
Old 06-28-2015, 09:19 PM
RodneyFord
RodneyFord's Avatar
Double sided tape on some thin card to hold the canopy in place for shaping.
ID:	2106283   Click image for larger version
ID:	2106284   Click image for larger version
Old 06-29-2015, 04:04 PM
RodneyFord
RodneyFord's Avatar
Got some section lines on so I could see the curves more easily and to check symmetry with the profile gauge.
ID:	2106419   Click image for larger version
ID:	2106420   Click image for larger version
ID:	2106421   Click image for larger version
Old 06-29-2015, 10:17 PM
brustyrc
Very nice work as usual Rob, I'll follow this with interest, 'best, Barrie.
Old 06-30-2015, 12:24 PM
RodneyFord
RodneyFord's Avatar
Hi Barrie nice to hear from you.
The interesting bits for me are the things that are done differently or in a new way.
These are:
The free form shaping using the profile gauge for symmetry (I got pretty close by eye)
Polyester mold with gel coat sprayed in with popcorn gun (I got a new compressor that will run continuously)
Engineered mold locating and joining system.
1mm Rohacell for the sandwich material in the finished fuselage.
My first decent size electric model. I might do my own contra gearbox, I mean how hard can it be!
Old 06-30-2015, 02:49 PM
drac1
drac1's Avatar
These are:
If it were easy, everyone would be doing it. Lol.
Nah, just kidding. Would be well worth having a go. I haven't seen an exploded view of one, but I think there would be a fair bit of work involved. I'm a first class machinist by trade, so would be very interested. Post plenty of photos and give a good description of what you do if you decide to try.
Old 06-30-2015, 03:57 PM
RodneyFord
RodneyFord's Avatar
The Adverrun looks quite achievable. Need to cut spur gears and make shafts but I am set up for that. The Brenner system is more elegant to my mind but needs a high level of machining.
Old 06-30-2015, 03:58 PM
RodneyFord
RodneyFord's Avatar
Took the canopy off and lined the front and rear.
Old 06-30-2015, 03:59 PM
RodneyFord
RodneyFord's Avatar
An issue with this type of pattern is the lack of rigidity. At the moment it is a bit of a banana by 4 or 5 mm. I will need to stiffen it up or anything could happen when I glass it. I have put the laser line on it here to see how it is. I think I will inset some spruce strips along the sides and hold it straight while the glue dries.
ID:	2106679   Click image for larger version
ID:	2106680   Click image for larger version
