SUPER V 27 with 5s LIPO
GA
Has anyone ever done this? I seen a video on Youtube of a Super V 27 using one 2s and one 3s LIPO packs...fastest stock Super V 27 I have seen. The stock ESC is rated at 18 volts so using one 7.2 and one 11.1 volt packs addes up correctly? I think he also used a different prop. I will try to post video soon.
GA
GA
RE: SUPER V 27 with 5s LIPO
I quote him...
"im runing 2 packs one 3s1p and one 2s1p both from flight power keep the heavier pack on the lelt looking at the boat from the back."
NY
ORIGINAL: aviserated
GA
I think the stock Brushless Super Vee if set up correctly using 5s LIPO and good prop would be far from slow, but can it's 18 volt ESC handle 5s lipo?
OH
I doubt it. Alot of that performance can be attributed to that motor (although I don't know where you guys are getting your info about that boat). I'd say the weak point is the ESC. It may hanldle the 5s for a while but not too long. To get what you see in that vid you need to flow more amps. For that you need that motor and with the motor you need the speed control. That said that boat handled really well. Amazingly well. I watched the video of the one that was below it (nice contrast) set up horible at realistic speeds. Great video.
ON, CANADA
ORIGINAL: SV27dayton
Look at the video and where it says who made the vid ( on the right side of screen) it lists what is in the boat
OH
Never mind I figured you how you cleverly scrolled down below the vid and read the comments. I relieved I thought I was going to have to learn another language to continue commine here
NY
I will quote from the right upper side of the web page
"about this video
Sv27 with feigao 9xl hydra120 octurax442 " and the lipo setup is in the title.
it's not in the comments. or at least you dont have to scroll down at all. [sm=72_72.gif]
