450XL swash problem
450XL swash problem
ok guys i am running a 450XL flys great all except for one thing. when i increase power/pitch the swashplate wants to move aft. not so much that it is hard to controll but enough that if you take your hands off the controlls for a spit second it can give you a scare. i have looked for binding but i really couldnt find any or i am looking in the wrong place. anyone else have this problem?
RE: 450XL swash problem
I would check the anti-rotation arm and make sure the pin is not grabbing. Also check the pivot on the elevator A-frame and make sure it's not binding.
the first pic is full down, #2 is full up and #3 is middle. i checked the for binding and haven't found any. may be it is the servos hs56's
I thought you had an HDE for some reason. Now that I see you have CDE, it makes more sense. I would say it's definately in the radio. Are all of the servo endpoints and sub-trims the same? This is the cause most of the time.
yep thats what it was, the endpoints. i kinda like the hde a little better it was less complicated lol. thanks for the help.
dave
dave
