101" C-130 arf
My Feedback: (13)
IA
RE: 101" C-130 arf
Diablokid:
Can't get Saito 30 4 strokes here anymore..if you lived overseas, like Europe you could get them there..only 30 4-strokes available here are Magnums..this C-130 dosen't have flaps...would be nice to have them..shore would help...I have a Quality Fibereglass C-130 and it's going to weight 25 + Ibs...Going to install OS 40-4 strokes....have to order new cowls and reset the engines... also put everything back in it that was taken out of it...has retracts, 3-sectional flaps,and the cargo door opens on the back of the plane...will paint it this coming spring...The C-130 from Hobby People looks interesting,but will finish the one up I started ( QF),3 yrs. ago....back to the work bench.................
#31
My Feedback: (68)
RE: 101" C-130 arf
ORIGINAL: mugenkidd
OS still makes a .30 size four stroke also.....
http://www2.towerhobbies.com/cgi-bin...?&I=LXCNA5&P=0
#32
My Feedback: (24)
RE: 101" C-130 arf
ORIGINAL: DiabloKid
those would be perfect! nice find
ORIGINAL: mugenkidd
OS:
Displacement: 4.89cc (.299 cu in)
Bore: 19.5mm (.767") Stroke: 16.4mm (.648")
Power Output: .5 HP at 10,000 RPM
Weight with muffler: 10.4oz (295g)
Weight without muffler: 9.8oz (278g)
Practical RPM Range: 2,500 - 13,000 RPM
Crankshaft Thread Size: 1/4-28
Valve Clearance: Between .04mm and .1mm (.0015" and .004"),
Measured between the valve tip and rocker arm.
Length: 84mm (3.31") from the backplate to the front of the
drive washer.
Width: 29mm (1.14") width of engine neglecting the mounting flanges
36mm (1.42") mounting holes side-to-side on-center
Height: 86.5mm (3.41")
Suggested Prop(s): 9x6, 9x7, 10x4, or 10x6
Construction: Aluminum and aluminum alloys
Magnum:
Our testing produced 12,500 rpm with a 9 x 5 prop!!!
Specifications:
Displacement: 5.0cc (.30cu.in.)
Bore: 19.7mm
Stroke: 16.4mm
Practical RPM: 2,200 - 13,000
Weight(w/ muffler): 9.6oz
Crankshaft thread size: 1/4 - 28
Exhaust thread size: M10 x 1
#34
LA
RE: 101" C-130 arf
ORIGINAL: DiabloKid
which engines are you running? Seems some 25fx's might do the trick
#38
TX
RE: 101" C-130 arf
Heck guys I ate too much Turkey Bird. I became delirious and pre ordered the Herky Bird and gear last week.....can't wait. Twenty five flights on the C-160. I pulled everything out of her ( groan ) and am waiting for the C-130. Now I only Have to buy two more motors and systems. !QUOT! birp !QUOT! excuse me. I also pre ordered the Spectrum DX-7 Radio sys. to put in the 130. Now I will be sleepin' in tha shop cause I don't have any funds left for the wife's Christmas gift. Oh well, at least I have the right priorities.
#40
MD
RE: 101" C-130 arf
Alan
I understand it doesn't have flaps--how easy would you say it would be to cut, spar, and hinge them in?
What engines are you using? I want to use Saito .40s but Horizon Hobby don't carry them. I may try RCV's .52s if they will fit, but more than likely they will be OS .40s.
Your comments are welcomed...
Thanks...
Mr DJ
Thanks...
Mr DJ
#41
LA
RE: 101" C-130 arf
ORIGINAL: Mr DJ
#44
RE: 101" C-130 arf
I think it would just about fly on 2 (I mean only just). So if you lose an outer you simply shut the matching motor and fly a gentle decending curcuit back in to land. My dad has had a engine out on it but I haven't myself. I don't think it would be major hastle just as long as you know what to do. This is why I will always run 2 throttles on a 4 engine aircraft. Inners as normal and outers as a slider switch.
What does SOL mean?
Alan
What does SOL mean?
Alan
#47
MD
RE: 101" C-130 arf
ORIGINAL: awood12345
It has flaps and flys great with them. You do have to land with throttle on though as it just stops inflight otherwise.
Alan
Alan
My bird is supposed to be here by 15 Jan--don't think that's gonna happen, but I guess I'm in no rush since I just, as in just opened the 7.5' box and took out my Yellow Aircraft F-15 ARF [link=http://www.yellowaircraft.com/jets/f15.htm] Yellow Aircraft[/link]. It is freakin' awesome--expecting my 36lbs thrust SimJet turbine engine by Saturday [link=http://www.simjet.com/C1256F6600773F26/getPopup/00C25970BCE7457AC1256F6A0033D0AA?open]SimJet[/link]. I would like to have it ready to go by April but probably won't be 'til June or so.
I also have a Composite ARF giant a** Gee Bee with a DA 150 on its way [link=http://www.composite-arf.com.hk/] Comosite-ARF.com[/link]
Sorry to get off the subject--not I still can't wait to get my C-130.
Later...
Mr DJ
#48
My Feedback: (9)
RE: 101" C-130 arf
It amazes me how many New ARS's are due Jan 15th, KMP Cessna 180, Cox T-28 Trojan, the TF C-310, and the C-130, Must all be shipped from the same local. on the same Ship???
#50
MD
RE: 101" C-130 arf
I hope this answers you question. :P
Where is the location of servos, please?
And most curious, what size 4-strokes are you using? I know .30s will fit but just by comparing the measurements of OS’s .30 and .40, I’m thinking the .40s will fit. You’re opinion, please.
Many thanks…
Mr DJ
