LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
#276
MA
RE: LB Getting Ready for SNOW - Kyosho EP Blizzard DF-300 Thread!
Good luck, LB! I left the board for a very little while and bam! You have another new RC :P
I read through the entire thread the weekend before finals.
#277
Rubber shield ballbearings in da house! Hopefully w/ rubber shields, instead of metal shields, there will not be rust issue... (but then, I really doubt that I run my RC enough to worry about that!)
Should have time this weekend to take the diff out and install all the bearings, as well as making the diff LSD... !
#278
I've been watching this thread for a while, and I really want one of these! Don't know when that will happen though, but I think I'm hooked and I don't even own one!
#279
ORIGINAL: Yub, yub, cmdr!
Yeah LB can't wait for some photos...
#280
ON, CANADA
ORIGINAL: lee172
did you ever see this version LB? doesnt do much for me i must say..
#281
Oh, come on.. it is a short thread...
Welcome back!
#282
I pity the fool who doesn't like the Blizzard... (joke)
ORIGINAL: Codeblack
aaaw, that immediately reminded me of The A-Team van, but on tracks
#283
Why did you go with the rubber shield over the metal one? Do you think the rubber shield is water proof? Or will it just hold the water in the bearing longer once the water gets in.
#284
ON, CANADA
ORIGINAL: Lunchboxer
ORIGINAL: Codeblack
#285
My Feedback: (34)
ORIGINAL: saskjimmy
#286
Rubber shielded bearings seals better so it would be harder for water / snow to get in, in the first place..
But also, since it is not metal, reduce the chance of rust by itself as well..
But then, that's all just my guess... I got no proof.. ha! Try at your own risk!
ORIGINAL: saskjimmy
#287
ORIGINAL: saskjimmy
#288
MA
^_^ thanks guys.
LB, what brake material will you get? I think you might be able to cut up some 1/8 buggy brake pads.
#289
Yeah, I am too lazy.. so I just went with whatever the thing that guys at Making Trax are using!
#290
Time to put in some ballbearings..
While the wheel was out, snapped a pic of the suspension setup.. pretty simple, huh?!
#294
Interesting rear suspension setup! You can put in a spring and adjust the collar to increase the travel... Maybe later!
#296
Don't like the design here.. [:@] The driving wheel and chain driven wheel assembly rides on the shaft, with no bushings, so no option of changing to ballbearings! [:@]
I think I will apply some heavy grease and then clean it off on the outside (so it doesn't attract dirt..)..
They should have gone w/ a better design here! [:@]
#297
I have thought about getting a Blizzard in the past. I love the scale body of this new DF-300 model! I wish Kyosho still made a plow for it! The DF-300 would be so sweet with a plow and a set of RAM R/C flashing lights!
#298
Yeah, I am thinking about a flashing light unit myself.. we will see... ha! I like to get the mechanical aspect sorted out first before doing other stuff!
#299
Well, time for a custom mod then to run the bearings, take a drill and cut you some slots for ball bearings, if you want..
#300
Then the shaft will be too small in diameter and might not be rigid enough...
We will see.. stock for now.. will think of a better solution later.. maybe someone will make aluminum drive wheels w/ bearings?! I'd buy that!!
