1/16th, 1/18th, Mini & Micro RC Cars Discuss 1/16, 1/18, Minis, Micros & any RC Cars smaller than 1/10th scale in this forum
Official HPI Savage Flux XS thread...
Old 10-26-2013, 04:37 PM
  #3451
suburban_hooligan
suburban_hooligan's Avatar
Originally Posted by whee-sconsin basher
You know, I never had a problem with my other HPI kits in the past. It kinda threw me off. The ones that hold the hinge pins in were the worst ones. Those are the ones that are gonna give me a run for my money come teardown time. The kit allen wrenches seemed sloppy in the heads to me.
it had to be a batch of bad screws then (or maybe they switched suppliers?) cause when i first started building mine the kit supplied L wrenches were a snug fit. i got both front and rear clips/diff housings/bulkheads/whatever you want to call them finished before they got a little looser than they should have been. at which point i just filed them down.
i do have one small screw that holds one of the a front hing pins in that's a little rounded, but it's do to the wrench being worn and the screw head being partially clogged with dirt. standard issue with any screw. i have to use a really fresh wrench to get it in and out.
Old 10-26-2013, 05:20 PM
  #3452
jason1980
Originally Posted by suburban_hooligan
that's the second hardware complaint iv heard. iv had absolutely no problems with the hardware on mine. i even used the kit supplied L wrenches to build it. i wonder if they made a run with a bad batch of screws
My L wrenches that came with the RTR have free play, will not use at all. i think the screws are probably a little rounded when they assembled it in the factory.
Part and parcel of a RTR i guess. I would probably buy stainless steel ones for all the screws that are often taken out. but for the stripped ones, guess i can;t do anything with it.
BTW, can i use the red loctite on the screws? any difference between the red and the blue? Could only find red ones in hardwares stores near me.
Old 10-26-2013, 05:43 PM
  #3453
suburban_hooligan
DON'T use red! you will never be able to take them out. red is like super strong.
different colors are different strengths. shy of torching the screw and damaging the surrounding plastic parts odds are you won't be able to remove a screw with red loctite on it.
let me put it to you this way. there's red loctite holding the 36mm flywheel gland nut on my 1:1 car. does that sound like something you want to use on a little RC screw?
you need the blue stuff for RC use.
Old 10-27-2013, 05:49 AM
  #3454
jason1980
LOL, got it, will look for the blue loctite. Is there a number for the blue loctite?
I have seen a few variations. Will loctite 243 do? its a medium strength one
ID:	1933542   Click image for larger version
ID:	1933543   Click image for larger version
Old 10-27-2013, 09:29 AM
  #3455
suburban_hooligan
i have a tube of blue thredlocker 242 i picked up from lowes.
had to google 243. it seems to be more for industrial applications. but it seems to be the same basic stuff. 242 and 243 are both medium strength so hell id use it.
Old 10-28-2013, 12:24 AM
  #3456
jason1980
Thanks man, sourced for it and will be getting today.
BTW, any recommendation for tyres with good grip?
Old 10-28-2013, 07:17 AM
  #3457
jason1980
Originally Posted by sparky 25
Finally pics will upload!
Pics of my xs ss with near 100% offset thunder tiger ssk rims with ssk tires,
Handling has improved hugely, no more tipping over going around corners at speed
The second last pic shows the offset on a stock hpi savage xs rim,
Are they an exact fit? Like the wide look
http://www3.towerhobbies.com/cgi-bin...?&I=LXTYP0&P=7
What rims can i get to fit these tyres? any recommendations?
Old 11-01-2013, 07:21 AM
  #3458
whee-sconsin basher
whee-sconsin basher's Avatar
Almost done! Tonight the body gets the masks put in and the main body color sprayed. Once that's dry, the masks are getting pulled and I'm letting my son brush in on the masked areas. After that's finished, he gets to help me finish the truck by putting on the body and wheels.
Old 11-01-2013, 04:18 PM
  #3459
suburban_hooligan
has anybody put RPM revolver 2.2 wheels on there truck?
if you have can you throw a part number at me and tell me how well they held up?
Old 11-01-2013, 07:39 PM
  #3460
jason1980
Had a nice run just today. some flips and tumble but the truck stayed well. had a little problem getting the steering trim right though.
At the last hop/tumble, the right rear dog bone dropped out. Still wondering how the heck it happened?
Old 11-03-2013, 04:36 PM
  #3461
whee-sconsin basher
And we're done! The star and flame stripes were brushed in by the boy first, then I backed them up with a few more coats to finish. First run was pretty smooth despite the little man kissing the curb a few times, but it just proved to me how durable this thing is. Didn't get to open it up all the way, but it shows some promise in the power department.
ID:	1936369   Click image for larger version
Old 11-04-2013, 06:36 PM
  #3462
jason1980
Nicely done, can i ask something? Are your front wheels straight? My RTR front wheel are a V shape.
Old 11-05-2013, 08:05 AM
  #3463
whee-sconsin basher
Thank you! It's hard to tell, but the color of the star and flames is pretty much purple. I had purple, blue and red for him to use and they sorta got blended
As for the front wheels, they point straight. Mine was a kit I built instead of the RTR though. If yours point inward, then you just need to disconnect the links and adjust them until the wheels point straight ahead. I little toe in (front of wheels pointing inward, rear pointing outward) is okay sometimes, but you only really need a couple degrees at most. Straight ahead is usually all you need.
Old 11-08-2013, 07:49 PM
  #3464
jason1980
can see the purple under the light.
Old 11-09-2013, 11:18 AM
  #3465
Savagexsfail
I'm in search of a spektrum receiver to use in my xs and I was wondering what the best one for it would be
Old 11-09-2013, 11:22 AM
  #3466
Savagexsfail
@savagexsfail, I see alot of negative comments on this over multiple forums and almost as many saying they don't have problems. I would love to know what circumstances they run under when this happens. I also wonder if they are setting the slipper right to help with drivetrain stresses.
I have the slipper clutch set loose and I'm not even getting over half throttle with it. It seems that I break the cups and bend the dogbones when it goes into a kart wheel but I have since upgraded to hpi racing axles and seems to be working great. Still nervous about the 3s batteries since I put the 3s gears that hpi recommends in and shelled my drive gear and my idler gear
Old 11-10-2013, 06:28 PM
  #3467
whee-sconsin basher
I guess I felt it wasn't noticeable. Need my eyes checked...
Did you get your wheels straightened out?
Old 11-10-2013, 06:30 PM
  #3468
whee-sconsin basher
I regret not hardening mine first, so I'm anxious to see how long they last.
Old 11-10-2013, 06:34 PM
  #3469
whee-sconsin basher
So I pulled the body off yesterday to pull the battery for charging, only to notice the fan blade on the esc was gone! 1 run and it's M.I.A. completely. Contact has been made with Viper, see what happens.
Old 11-11-2013, 06:25 AM
  #3470
jason1980
Yeah, got them sorted out, now they toe in a little.
Old 11-11-2013, 08:37 AM
  #3471
whee-sconsin basher
Good deal! How do you like this truck so far?
Old 11-14-2013, 06:22 AM
  #3472
jason1980
Love that truck. needs more space to run it though
Old 11-15-2013, 09:38 AM
  #3473
whee-sconsin basher
I haven't gotten to open mine up all the way yet. And now I have to wait on Viper. Sent the esc out, hope to get it back soon!
Old 11-21-2013, 02:47 AM
  #3474
Lewydfly
Lewydfly's Avatar
G'day guys. Im all new to this so im not sure if I'm in the right area so direct me if I'm wrong.
Im having issues with my savage xs. After a bash at the skate park today on 3S and 5mins into a 2S it suddenly stopped. The lights are flashing continuously and beeping with the fan running on the esc but I have no transmitter controls at all. I've hooked up a second esc and its still the same. Any ideas ???
Old 11-21-2013, 01:31 PM
  #3475
whee-sconsin basher
Hello and welcome to the forum!
Out of curiosity, do you have a 2.4ghz radio? If so, maybe try and bind the reciever to the transmitter again. It may have overheated also. Is this stock equipment or did you buy other stuff?
