Official HPI Savage Flux XS thread...
#3501
MN
#3503
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXASTZ
it fits great. i did have to test it a few times to learn how to run the battery wires out. but once i had that figured out, it goes in and out easily.
#3505
To fit the above in the savage you would have to make or buy low profile plugs (Credit T9):
This but with a 30c pack/s.
#3506
A few new pics after 5 battery packs, thing is tougher then people made it out to be. I lost front wheel drive, set screw came out or is loose haven't looked yet, and a wire on the motor became un-solderd but i did the soldering so my own fault for that.
These are the wheels and tires from a the losi 1/18th rock crawler, and surprisingly hook up amazing in soft sugar sand and leaves. They might be small and cookie cutter'ish but my goodness does it handle now. Stock tires it couldn't track straight to save it's life.
#3507
#3509
The C-rating on the pack is what you need to be concerned about. With this truck, 30c is lowest. It is a light truck, but 25c lipos are for 2wd Traxxas vehicles which are really light and don't draw a lot of amps. If the battery cannot supply the amps the motor/esc are drawing, it will stutter.
#3510
Just finally got my Savage Flux back from HPI after just purchasing it new and having it delivered with issues...... At first glance its everything (good) they say about it.... I was very disappointed in the new "Futaba" transmitter the TF-11, and when I unpacked the item the first time, it ran for a few seconds the stopped. I checked everything over and decided to call HPI, i was hung up on by the first person who says they are normally in the air department and not the surface department, then the next guy (very nice) went through the hole thing over the phone and told me to send it in. I did, and they fixed it and sent it back. The repair ticket says the wire was off from the motor to the ESC(absolutely not) and that was the issue. Either way i have the truck back and its working now so thats a plus. The radio sucks and the shocks arent the "Golden" ive heard from URC at all, but over all for the $200 RTR oh wait it was $300 and i had to purchase batteries.... Fun truck but after all the issues not sure i made the right choice.. My issues I'm sure arent the norm and probably just represent my experience and nothing more but, I'm not a fan of this product so far.... I havent had an issue with my batteries not fitting and I havent tried a 3s due to the breaking parts issue I hear so much about but I think its fast enough the way it is. Here's hoping my ESC dont burn like i have heard some doing! Just my opinion and you should form yours from the true experts but just had to post something.
#3512
In my opinion after having the truck and running all stock with 2s and 3s lipo, anything aftermarket isn't necessary. HPI has always hade bulletproof transmissions, and this is one of them. What were your goals as far as an aftermarket slipper?
#3513
Hi , i just received today my savage , and i only have two 3s lipos to use during 10 days (in a week or so i will get 2 x 2s 4500 mah 35c).
I have read in the hpi web that for 3s you have to change the spur gear and pinion , and looking in the pdf manual it seems , at least for me (i am new in rc cars),that is a bit difficult to change them. Perhaps once i have the car in the table is easier to see what to do.
But my doubt is if for a week or 10 days of 3s use only it is worth to change the pinion and spur knowing that then i will use 2s lipos.
And as i never drive a rc car , i will not speed up too much xd.
#3514
I never changed any gears in my XS, whether I was running a 2s or a 3s lipo. The gear changing is o keep temps down on the motor. If you run full throttle for a whole pack or even two packs, you might have heat trouble. 3s lipo is insane power, so I doubt you will need to go full throttle.
#3515
#3517
Sometimes I kind of miss my XS. The blistering top speed and neck snapping backflips. But on the other hand, I'm glad I sold it to get my Ofna. More solid platform. I still stop by to help others lol
#3518
MN
Hello guys, I'm back again. See my video in post 3494 with my XS doing the "Jerky" thing when starting out. We finally got some nice weather here and I got out to do some bashing. I still have the same batteries 2s and 3s 4000 mah 20c's. A few had thought that the fact that the 20c batteries we my issue but it would hurt to run with them and just deal with the jerky starts until I get some new batteries. Today it was still jerky and then it would just go dead after maybe 5 mins of running and the pack still had plenty of charge in it. If I unhooked the battery and hooked it back up, it would run for bit longer and then go dead again. Any ideas? Is my ESC going? Or, is it just that these 20c batteries just not right? On a side note, I saw a Savage XS package deal with these batteries and that's why I chose them. I don't remember the truck doing this jerky deal on the first few packs, and it certainly didn't go dead when the pack was still fairly charged.
JSF
JSF
#3519
JSF
JSF
#3520
MN
Both are Venom batteries and Yes I always balance. Is there any place to buy batteries (affordable) besides hobby king? Love their site but I'm WAY tired of wrestling with their shopping cart / check out system.
#3522
MN
I went to my LHS and bought an $80 2s 30c 5200 mah pack and gave it a try. It made it better, but it still does the hesitation and it gets worse as the battery is drawn down again. I think I'll give all the onboard connections a once over and see if that helps. Maybe even apply a little dielectric grease?
JSF
JSF
